Peter MaSarah HanShin Ae HongGrace HanKevin Vo
Published © LGPL
SPCPM (Solar Powered City Pollution Monitor)
Low maintenance, high output air pollution, sound pollution that put throughout the city without wiring.
IntermediateFull instructions provided12 hours9,376
Things used in this project
Hardware components
Arduino UNO & Genuino UNO
×1
Helium Atom Xbee Module
×1
Grove - Air quality sensor v1.3
Seeed Grove - Air quality sensor v1.3
×1
Solar Charger and Battery
×1
Helium Element Access Point (Cellular)
×1
Seeed Sound Sensor
×1
Arduino IDE
Arduino IDE
Cloud IoT Core
Google Cloud IoT Core
Story
Read more
Schematics
Helium Architecture
This is Helium IoT Architecture
Helium arch 3nzs5rfdg2
Code
Arduino Air Quality Code
Arduino
Arduino Code with Helium Breakout Board
#include "AirQuality.h"
#include "Arduino.h"
#include "Board.h"
#include "Helium.h"
#include "HeliumUtil.h"
#include <TH02_dev.h>
#include "Wire.h"
#include <SeeedGrayOLED.h>
#include <avr/pgmspace.h>
AirQuality airqualitysensor;
#define CHANNEL_NAME "SPAQM"
Helium  helium(&atom_serial);
Channel channel(&helium);
void setDisplayToOriginalState()
    SeeedGrayOled.init(SSD1327);
  Serial.begin(9600);
  delay(150);
  /* Reset HP20x_dev */
  TH02.begin();
  delay(100);
  Serial.println("TH02_dev is available.\n");
  DBG_PRINTLN(F("Starting"));
  // Begin communication with the Helium Atom
  // The baud rate differs per supported board
  // and is configured in Board.h
  helium.begin(HELIUM_BAUD_RATE);
  // Connect the Atom to the Helium Network
  helium_connect(&helium);
  // Begin communicating with the channel. This should only need to
  // be done once. The HeliumUtil functions add simple retry logic
  // to re-create a channel if it disconnects.
  channel_create(&channel, CHANNEL_NAME);
  Wire.begin();
  airqualitysensor.init(14);
  //Set quality from 0 to 255, with one to 100 being normal
  //Air Quality Pollution
//  int sensorValue = analogRead(A0);
//  int airquality = map(sensorValue, 0, 1023, 0, 255);
    int airquality = airqualitysensor.slope();
    //Sound Pollution
    long sound = 0;
    for(int i=0; i<32; i++)
        sound += analogRead(A1);
    float temper = TH02.ReadTemperature();
    float humidity = TH02.ReadHumidity();
    String dataString = "air=" + String(airquality) + "&noise=" + String(sound) + "&temperature=" + String(temper) + "&humidity=" + String(humidity);
    char data[dataString.length()];
    dataString.toCharArray(data, dataString.length());
    channel_send(&channel, CHANNEL_NAME, data, strlen(data));
    Serial.println(data);
    setDisplayToOriginalState();
    SeeedGrayOled.clearDisplay();     //Clear Display.
    SeeedGrayOled.setNormalDisplay(); //Set Normal Display Mode
    SeeedGrayOled.setVerticalMode();  // Set to vertical mode for displaying text
    SeeedGrayOled.setTextXY(0,0);           //Set the cursor to 0th line, 0th Column
    if (airquality==0)
      SeeedGrayOled.putString("High pollution!!!!");
    else if (airquality==1)
      SeeedGrayOled.putString("High pollution!");
    else if (airquality==2)
      SeeedGrayOled.putString("Low pollution!");
    else if (airquality==3)
      SeeedGrayOled.putString("Fresh Air");
    SeeedGrayOled.setTextXY(2,0);
    String temperaturestring = String(temper) + " C";
    char tempbuffer[temperaturestring.length()];
    temperaturestring.toCharArray(tempbuffer, temperaturestring.length());
    SeeedGrayOled.putString(tempbuffer);
    SeeedGrayOled.setTextXY(3,0);
    String humidstring = "Humid: " + String(humidity);
    char humidbuffer[temperaturestring.length()];
    humidstring.toCharArray(humidbuffer, humidstring.length());
    SeeedGrayOled.putString(humidbuffer);
    SeeedGrayOled.setTextXY(5,0);
    if(sound > 5000)
      SeeedGrayOled.putString("Very Loud");
    else if(sound < 4000)
      SeeedGrayOled.putString("Very Quiet");
    else
      SeeedGrayOled.putString("Sound: Normal");
    delay(60000);
ISR(TIMER1_OVF_vect)
  if(airqualitysensor.counter==61)//set 2 seconds as a detected duty
      airqualitysensor.last_vol=airqualitysensor.first_vol;
      airqualitysensor.first_vol=analogRead(A0);
      airqualitysensor.counter=0;
      airqualitysensor.timer_index=1;
      PORTB=PORTB^0x20;
  else
    airqualitysensor.counter++;
Board.h
Arduino
Board.h is needed to run the code
 * Copyright 2017, Helium Systems, Inc.
 * All Rights Reserved. See LICENCE.txt for license information
#ifndef BOARD_H
#define BOARD_H
#if defined(ARDUINO_AVR_UNO)
#include "SoftwareSerial.h"
SoftwareSerial atom_serial(8, 9);
#define HELIUM_BAUD_RATE helium_baud_b9600
#elif defined(ARDUINO_AVR_MEGA2560)
SoftwareSerial atom_serial(10,11);
#elif defined(ARDUINO_SAM_ZERO)
// Arduino M0 Pro
#define atom_serial Serial5
#elif defined(ARDUINO_SAMD_ZERO)
// Arduino Zero
#define atom_serial Serial1
#elif defined(ARDUINO_SAM_DUE)
// Arduino Due with Serial3 (pin 15, 14)
// mapped to pin 8, 9 on the adapter
#define atom_serial Serial3
#endif
#if defined(CORE_TEENSY)
//Teensy with Serial1 (pin 0, 1)
extern "C"{
    int _write(int f, char *ptr,int len){
        int i;
        for(i=0;i<len;i++)
                atom_serial.write(*ptr++);
        return len;
    int _read (int f, char *ptr, int len)
        *ptr=atom_serial.read();
        return len;
#elif defined(ARDUINO_AVR_PRO)
//ProMini/Micro with Serial pins (8,9)
SoftwareSerial atom_serial(8,9);
#endif
#ifndef HELIUM_BAUD_RATE
#define HELIUM_BAUD_RATE helium_baud_b115200
#endif
#endif // BOARD_H
SPCPM Node.js
SPCPM Node.js from GCP
Credits
Peter Ma
Peter Ma
22 projects • 98 followers
Prototype Hacker, Intel Software Innovator, Hackathon Goer, World Traveler, Ecological balancer, integrationist, technologist, futurist.
Sarah Han
Sarah Han
2 projects • 13 followers
Software Engineer, UX/UI Designer, Graphic Designer, 3D modeling
Shin Ae Hong
Shin Ae Hong
3 projects • 9 followers
Global Startup Incubation Specialist @Innoway
Grace Han
Grace Han
0 projects • 2 followers
Kevin Vo
Kevin Vo
0 projects • 1 follower
Comments
Add projectSign up / Login
