UW-Makeathon: Deepwater Swarm Probe
Running for: NASA- Out of this world; Best Project; Formech Sustainability Award; Digi-Key Award; Isthmus Engineering Award
IntermediateWork in progress40
Things used in this project
Hardware components
Arduino Uno Rev3
Arduino Uno Rev3
×1
Grove - Barometer Sensor (BMP280)
Seeed Grove - Barometer Sensor (BMP280)
×1
Servos (Tower Pro MG996R)
×1
9V battery (generic)
×1
9V Battery Clip
9V Battery Clip
×1
Arduino Web Editor
Arduino Web Editor
SolidWorks
MakerCase
Adobe Illustrator
Formech Thermoformer
Used to create the waterproof casing for the project
Materia 101
Arduino Materia 101
3D Printer (Ultimaker 3)
Used to print the cap for the probe
Laser cutter (generic)
We used the laser cutter to create a box that became the mold used in the thermoformer to create the casing for our probe
Soldering iron (generic)
Generic hand tools (see comments)
a hacksaw, rubber mallet, and box cutters were all used in imparting slight modifications on our probe casing after the thermoforming process
Multimeter (generic)
wave generator (generic
Story
Read more
Custom parts and enclosures
Probe Lid
This piece was used to cap off the top of the probe. When attached with silicone caulk, it created a water-tight seal with the thermoformed case.
Box
Schematics
Circuit Sensor
Circuit diagram sensors 6uweqzxasm
Code
Main program file
C/C++
This is uploaded to the arduino uno and run to collect data.
  Thomas Hansen
  Yash Wani
  This is the code for installing on the arduino for the run,
  and it will collect the necessary data.
#include <Adafruit_BMP280.h>
#include <EEPROM.h>
#include <Servo.h>
#define BMP_SCK 13
#define BMP_SDO 12
#define BMP_SDI 11
#define BMP_CS 10
#define SERVO 8
int eepromIndex = 0;
int loopIterations = 0;
Servo weightServo;
Adafruit_BMP280 bmp280(BMP_CS, BMP_SDI, BMP_SDO,  BMP_SCK);
  Serial.begin(9600);  //Set the baud rate of serial monitor as 9600bps
  // setup servo
  weightServo.attach(SERVO);
  weightServo.write(0);
  if (!bmp280.begin())
    Serial.println("Unable to connect to barometer.");
    while (true);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Continually loops throug
  Serial.print(F("Temperature: "));
  float curTemp = bmp280.readTemperature();
  Serial.print(curTemp);
  Serial.println(" deg C");
  Serial.print(F("Pressure: "));
  float curPress = bmp280.readPressure();
  Serial.print(curPress);
  Serial.println(" Pa");
  Serial.print(F("Depth: "));
  float curDepth = realDepth();
  Serial.print(curDepth);
  Serial.println(" m");
  // write data to EEPROM
  EEPROM.put(eepromIndex, curTemp);
  eepromIndex = eepromIndex + sizeof(float);
  EEPROM.put(eepromIndex, curPress);
  EEPROM.put(eepromIndex, curDepth);
  Serial.println();
  delay(5000);
  ++loopIterations;
  Serial.println(loopIterations);
  if (loopIterations > 24) {
    weightServo.write(140);
  Calculates the depth of the probe in m below
  sea level based off pressure.
float realDepth() {
  int pTotal = bmp280.readPressure();
  int pAtm = 99964;
  return (pTotal - pAtm)/(1025 * 9.806);
Read Data
C/C++
This code is used to read the data off of the probe.
#include <EEPROM.h>
float f = 0.00f;
int eeAddress = 0;
int i = 0;
void setup(){
  Serial.begin( 9600 );
  while (!Serial) {
  int eeAddress = 0;
  Serial.print( "Temperature: " );
  EEPROM.get( eeAddress, f );
  Serial.print( f, 3 );
  for (int i=1; i < 10; i++) {
    eeAddress = eeAddress + sizeof(float);
    Serial.print( "Pressure: " );
    Serial.print( "Depth: " );
Credits
Malachi Alvarez
Malachi Alvarez
1 project • 5 followers
Ricka Edwards
Ricka Edwards
1 project • 4 followers
Yash Wani
Yash Wani
Thomas Hansen
Thomas Hansen
HAWRA ALJAWAD
HAWRA ALJAWAD
Comments
Add projectSign up / Login
