Peggy LeeWenfei Huang
Published
The Martian
We detect the moisture, rigidity, and the slope to test whether the surface is suitable for constructions on Mars.
IntermediateShowcase (no instructions)Over 1 day25
The Martian
Things used in this project
Story
Read more
Code
The_Martian.ino
C/C++
We modified code from Arduino sample.
// wheels to move
#include <Stepper.h>
const int stepsPerRevolution = 1000;  // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper1(stepsPerRevolution, 4, 5, 6, 7 );
Stepper myStepper2(stepsPerRevolution, 8, 9, 10, 11);
int stepCount = 0;  // number of steps the motor has taken
  // nothing to do inside the setup
  // read the sensor value:
  int sensorReading = analogRead(A0);
  // map it to a range from 0 to 100:
  int motorSpeed = map(sensorReading, 0, 1023, 0, 100);
  // set the motor speed:
  if (motorSpeed >= 0) {
    myStepper1.setSpeed(motorSpeed);
    // step 1/100 of a revolution:
    myStepper1.step(stepsPerRevolution / 100);
    myStepper2.setSpeed(motorSpeed);
    myStepper2.step(stepsPerRevolution / 100);
// moisture
Moisture_Sensor.ino
C/C++
We modified code from Grove sample.
 Grove Moisture Sensor
 The following sketch demonstrates a simple application of sensing
 the moisture of the soil. You can determine whether a plant needs water
 or not by observing the results that the sensor outputs.
 The circuit:
 * 4-Digit Display attached to Pin 38 and 39 (J14 plug on Grove Base BoosterPack)
 * Moisture Sensor attached to Pin 24 (J6 plug on Grove Base BoosterPack)
 * Note:
 This example code is in the public domain.
 http://www.seeedstudio.com/depot/Grove-Moisture-Sensor-p-955.html
//4-Digit Display library
#include "TM1637.h"
/* Macro Define */
#define CLK               	39          /* 4-Digit Display clock pin */
#define DIO               	38          /* 4-Digit Display data pin */
#define MOISTURE_PIN      	43          /* pin of Moisture Sensor */
#define THRESHOLD_VALUE   	300         /* threshold for watering the plant */
#define LED 			RED_LED
/* Global Variables */
TM1637 tm1637(CLK, DIO);                  /* 4-Digit Display object */
int analog_value = 0;                     /* variable to store the value coming from Moisture Sensor */
int8_t bits[4] = {0};                     /* array to store the single digits of the value */
/* the setup() method runs once, when the sketch starts */
  /* Initialize 4-Digit Display */
  tm1637.init();
  tm1637.set(BRIGHT_TYPICAL);
  /* declare the LED pin as an OUTPUT */
  pinMode(LED, OUTPUT);
/* the loop() method runs over and over again */
    analog_value = analogRead(MOISTURE_PIN);      /* read the value from the sensor */
    /* if the value is smaller than threshold, turn on LED */
    if(analog_value < THRESHOLD_VALUE)
        digitalWrite(LED, HIGH);
    else
        digitalWrite(LED, LOW);
    memset(bits, 0, 4);                             /* reset array before we use it */
    for(int i = 3; i >= 0; i--)
        /* Convert the value to individual decimal digits for display */
        bits[i] = analog_value % 10;
        analog_value = analog_value / 10;
        tm1637.display(i, bits[i]);                 /* display on 4-Digit Display */
    delay(200);  //small delay so that the number doesn't change too quickly to read
Credits
Peggy Lee
Peggy Lee
1 project • 0 followers
Wenfei Huang
Wenfei Huang
Comments
Add projectSign up / Login
