Javier LeonBryan Doria Gomez
Published
Motion Alarm 9000
The Motion Alarm 9000 will alert you when anyone enters your room.
IntermediateFull instructions provided1 hour20
Motion Alarm 9000
Things used in this project
Hardware components
5 mm LED: Red
5 mm LED: Red
×3
5 mm LED: Yellow
5 mm LED: Yellow
×3
Photon
Particle Photon
×2
5mm LED:White
×1
Grove - PIR Motion Sensor
Seeed Grove - PIR Motion Sensor
×1
Buzzer
Buzzer
×1
Maker service
IFTTT Maker service
Google Sheets
Google Sheets
Story
Read more
Schematics
Motion alarm schematic
Schematic iehq00ewzx
Code
Motion Sensor
Arduino
// First photon, Motion sensor
int inputPin = D0;
int ledPin = D1;
int pirState = LOW;
int val = 0;
int light = D7;
int calibrateTime = 10000;
  pinMode( ledPin, OUTPUT );
  pinMode(inputPin, INPUT);
  digitalWrite(light, LOW);
  pinMode(light, OUTPUT);
  Particle.subscribe("bothways", event2, "400021000c47363433353735");
void setLED( int state )
  digitalWrite( ledPin, state );
void event2(const char *event, const char *data)
  digitalWrite(light, HIGH);
  delay(500);
  //Particle.publish("test", "on");
  if ( calibrated() )
    readTheSensor();
    reportTheData();
void readTheSensor() {
  val = digitalRead(inputPin);
bool calibrated() {
  return millis() - calibrateTime > 0;
void reportTheData() {
  if (val == HIGH) {
    if (pirState == LOW) {
      Particle.publish("Motion1", "Detected");
    //  delay(1500);
      pirState = HIGH;
      setLED( pirState );
  } else {
    if (pirState == HIGH) {
      pirState = LOW;
      setLED( pirState );
Led alarm
Arduino
//Second Photon, LED
int led = D7;
int led2 = D4;
int led3 = D3;
pinMode(led, OUTPUT);
digitalWrite(led, LOW);
pinMode(led2, OUTPUT);
digitalWrite(led2, LOW);
pinMode(led3, OUTPUT);
digitalWrite(led3, LOW);
Particle.subscribe("Motion1", motion_detected, "34001b000947363339343638");
void motion_detected(const char *event, const char *data)
  Particle.publish("bothways", "on");
 // digitalWrite(led, HIGH);
  	unsigned long startTime = millis();
	while (digitalRead(D6) != LOW && millis() - startTime < 10000) {
        digitalWrite(led2, HIGH);
        delay(100);
        delay(100);
        digitalWrite(led3, HIGH);
        delay(100);
//    digitalWrite(led, LOW);
Credits
Javier Leon
Javier Leon
0 projects • 0 followers
Bryan Doria Gomez
Bryan Doria Gomez
Comments
Add projectSign up / Login
