Thermal Divider
Temperature Controlled Food Transport for Commercial Applications
AdvancedFull instructions provided20 hours1,786
Things used in this project
Hardware components
SparkFun Inventor's Kit for Arduino 101
×1
Grove - Temperature Sensor
Seeed Grove - Temperature Sensor
×2
Android device
Android device
×1
Arduino IDE
Arduino IDE
3D Printer (generic)
Soldering iron (generic)
Story
Read more
Custom parts and enclosures
Thermoelectric Module Assembly
Schematics
Circuit Diagram
Power lunch circuit diagram igwvecmqgu
Code
Arduino Code
Arduino
#include <CurieBLE.h>
int a;
int c;
float temperature1;          //temperature sensor on A0
float temperature2;          //temperature sensor on A1
int B=3975;                  //B value of the thermistor
float resistance;
float resistance1;
const int ledPin = 4; // set ledPin to use on-board LED
BLEPeripheral blePeripheral; // create peripheral instance
BLEService ledService("19B10000-E8F2-537E-4F6C-D104768A1214"); // create service
// create switch characteristic and allow remote device to read and write
BLECharCharacteristic switchChar("19B10001-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);
BLEUnsignedCharCharacteristic temperatureService1("19B10000-E8F2-537E-4F6C-D104768A1217", BLERead | BLENotify); // create service for temp1
BLEUnsignedCharCharacteristic temperatureService2("19B10000-E8F2-537E-4F6C-D104768A1218", BLERead | BLENotify); //create service for temp2
  Serial.begin(9600);
  pinMode(ledPin, OUTPUT); // use the LED on pin 13 as an output
  // set the local name peripheral advertises
  blePeripheral.setLocalName("LUNCHBOX");
  // set the UUID for the service this peripheral advertises
  blePeripheral.setAdvertisedServiceUuid(ledService.uuid());
  // add service and characteristic
  blePeripheral.addAttribute(ledService);
  blePeripheral.addAttribute(switchChar);
  blePeripheral.addAttribute(temperatureService1);
  blePeripheral.addAttribute(temperatureService2);
  // assign event handlers for connected, disconnected to peripheral
  blePeripheral.setEventHandler(BLEConnected, blePeripheralConnectHandler);
  blePeripheral.setEventHandler(BLEDisconnected, blePeripheralDisconnectHandler);
  // assign event handlers for characteristic
  switchChar.setEventHandler(BLEWritten, switchCharacteristicWritten);
// set an initial value for the characteristic
  switchChar.setValue(0);
  // advertise the service
  blePeripheral.begin();
  Serial.println(("Bluetooth device active, waiting for connections..."));
  // poll peripheral
  a=analogRead(0);
  c=analogRead(1);
    resistance=(float)(1023-a)*10000/a; //get the resistance of the sensor1;
    resistance1=(float)(1023-c)*10000/c; //get the resistance of the sensor2;
    temperature1=1/(log(resistance/10000)/B+1/298.15)-273.15;//convert to temperature via datasheet&nbsp;;
    temperature2=1/(log(resistance1/10000)/B+1/298.15)-273.15;//convert to temperature via datasheet
    temperatureService1.setValue(temperature1);
    temperatureService2.setValue(temperature2);
    Serial.print("Current temperature is ");
    Serial.println(temperature1);
    Serial.println(temperature2);
    digitalWrite(ledPin, HIGH);;
void blePeripheralConnectHandler(BLECentral& central) {
  // central connected event handler
  Serial.print("Connected event, central: ");
  Serial.println(central.address());
void blePeripheralDisconnectHandler(BLECentral& central) {
  // central disconnected event handler
  Serial.print("Disconnected event, central: ");
void switchCharacteristicWritten(BLECentral& central, BLECharacteristic& characteristic) {
  // central wrote new value to characteristic, update LED
  Serial.print("Characteristic event, written: ");
  if (switchChar.value()) {
    Serial.println("LED on");
  } else {
    Serial.println("LED off");
    digitalWrite(ledPin, LOW);
Android App
Credits
Brian Cottrell
Brian Cottrell
8 projects • 7 followers
I am a software developer with a background in physics and low level programming and I am currently focused on web and mobile development.
Emily Lam
Emily Lam
3 projects • 0 followers
Ruby Hsu
Ruby Hsu
1 project • 2 followers
Mimi Almero
Mimi Almero
0 projects • 0 followers
Chris Buonocore
Chris Buonocore
Comments
Add projectSign up / Login
