Peter Ma
Published © GPL3+
Netduino WiFi Lock
Unlock your deadbolt remotely through WiFi using Netduino.
IntermediateFull instructions provided12 hours1,738
Things used in this project
Hardware components
Netduino3
Wilderness Labs (Netduino) Netduino3
×1
Base Shield V2
Seeed Base Shield V2
×1
Grove - Relay
Seeed Grove - Relay
×1
Android device
Android device
×1
Visual Studio 2015
Microsoft Visual Studio 2015
Story
Read more
Schematics
Unit Wiring Frame
Wiring Frame
Img 20180810 122229 zjzqn7mmgb
Code
Netduino C# Code
C#
This is the Netduino Socket server and receiver code to control the lock
using Microsoft.SPOT.Hardware;
using Microsoft.SPOT.Net.NetworkInformation;
using SecretLabs.NETMF.Hardware;
using SecretLabs.NETMF.Hardware.Netduino;
namespace Lock
    public class Program
        // Main method is called once as opposed to a loop method called over and over again
        public static void Main()
            Thread.Sleep(5000);
            App app = new App();
            app.Run();
            OutputPort led = new OutputPort(Pins.ONBOARD_LED, false);
            OutputPort relay = new OutputPort(Pins.GPIO_PIN_D5, false);
            int port = 80;
            Socket listenerSocket = new Socket(AddressFamily.InterNetwork,
                                   SocketType.Stream,
                                   ProtocolType.Tcp);
            IPEndPoint listenerEndPoint = new IPEndPoint(IPAddress.Any, port);
            Debug.Print("setting up socket");
            // bind to the listening socket
            listenerSocket.Bind(listenerEndPoint);
            // and start listening for incoming connections
            listenerSocket.Listen(1);
            Debug.Print("listening");
            while (true)
                Debug.Print(".");
                // wait for a client to connect
                Socket clientSocket = listenerSocket.Accept();
                // wait for data to arrive
                bool dataReady = clientSocket.Poll(5000000, SelectMode.SelectRead);
                // if dataReady is true and there are bytes available to read,
                // then you have a good connection.
                if (dataReady && clientSocket.Available > 0)
                    byte[] buffer = new byte[clientSocket.Available];
                    clientSocket.Receive(buffer);
                    string request =
                      new string(System.Text.Encoding.UTF8.GetChars(buffer));
                    Debug.Print(request);
                    if (request.IndexOf("ON") >= 0)
                        led.Write(true);
                        relay.Write(true);
                        Thread.Sleep(5000);
                        led.Write(false);
                        relay.Write(false);
                    string statusText = "Lock is " + (led.Read() ? "ON" : "OFF") + ".";
                    // return a message to the client letting it
                    // know if the LED is now on or off.
                    string response = statusText ;
                    clientSocket.Send(System.Text.Encoding.UTF8.GetBytes(response));
                // important: close the client socket
                clientSocket.Close();
    public class App
        NetworkInterface[] _interfaces;
        public string NetDuinoIPAddress { get; set; }
        public bool IsRunning { get; set; }
        public void Run()
            //this.IsRunning = true;
            bool goodToGo = InitializeNetwork();
            this.IsRunning = false;
        protected bool InitializeNetwork()
            if (Microsoft.SPOT.Hardware.SystemInfo.SystemID.SKU == 3)
                Debug.Print("Wireless tests run only on Device");
                return false;
            Debug.Print("Getting all the network interfaces.");
            _interfaces = NetworkInterface.GetAllNetworkInterfaces();
            // debug output
            ListNetworkInterfaces();
            // loop through each network interface
            foreach (var net in _interfaces)
                // debug out
                ListNetworkInfo(net);
                switch (net.NetworkInterfaceType)
                    case (NetworkInterfaceType.Ethernet):
                        Debug.Print("Found Ethernet Interface");
                        break;
                    case (NetworkInterfaceType.Wireless80211):
                        Debug.Print("Found 802.11 WiFi Interface");
                        break;
                    case (NetworkInterfaceType.Unknown):
                        Debug.Print("Found Unknown Interface");
                        break;
                // check for an IP address, try to get one if it's empty
                return CheckIPAddress(net);
            // if we got here, should be false.
            return false;
        public void MakeWebRequest(string url)
            var httpWebRequest = (HttpWebRequest)WebRequest.Create(url);
            httpWebRequest.Method = "GET";
            httpWebRequest.Timeout = 1000;
            httpWebRequest.KeepAlive = false;
            httpWebRequest.GetResponse();
            using (var streamReader = new StreamReader(httpResponse.GetResponseStream()))
                var result = streamReader.ReadToEnd();
                Debug.Print("this is what we got from " + url + ": " + result);
        protected bool CheckIPAddress(NetworkInterface net)
            int timeout = 10000; // timeout, in milliseconds to wait for an IP. 10,000 = 10 seconds
            // check to see if the IP address is empty (0.0.0.0). IPAddress.Any is 0.0.0.0.
            if (net.IPAddress == IPAddress.Any.ToString())
                Debug.Print("No IP Address");
                if (net.IsDhcpEnabled)
                    Debug.Print("DHCP is enabled, attempting to get an IP Address");
                    // ask for an IP address from DHCP [note this is a static, not sure which network interface it would act on]
                    int sleepInterval = 10;
                    int maxIntervalCount = timeout / sleepInterval;
                    int count = 0;
                    while (IPAddress.GetDefaultLocalAddress() == IPAddress.Any && count < maxIntervalCount)
                        Debug.Print("Sleep while obtaining an IP");
                        Thread.Sleep(10);
                        count++;
                    // if we got here, we either timed out or got an address, so let's find out.
                        Debug.Print("Failed to get an IP Address in the alotted time.");
                        return false;
                    Debug.Print("Got IP Address: " + net.IPAddress.ToString());
                    return true;
                    //NOTE: this does not work, even though it's on the actual network device. [shrug]
                    // try to renew the DHCP lease and get a new IP Address
                    //net.RenewDhcpLease ();
                    //while (net.IPAddress == "0.0.0.0") {
                    //    Thread.Sleep (10);
                else
                    Debug.Print("DHCP is not enabled, and no IP address is configured, bailing out.");
                    return false;
            else
                Debug.Print("Already had IP Address: " + net.IPAddress.ToString());
                return true;
        protected void ListNetworkInterfaces()
                        break;
                        break;
                        break;
        protected void ListNetworkInfo(NetworkInterface net)
            Debug.Print("MAC Address: " + BytesToHexString(net.PhysicalAddress));
            Debug.Print("DHCP enabled: " + net.IsDhcpEnabled.ToString());
            Debug.Print("Dynamic DNS enabled: " + net.IsDynamicDnsEnabled.ToString());
            Debug.Print("IP Address: " + net.IPAddress.ToString());
            Debug.Print("Subnet Mask: " + net.SubnetMask.ToString());
            Debug.Print("Gateway: " + net.GatewayAddress.ToString());
            if (net is Wireless80211)
                var wifi = net as Wireless80211;
                Debug.Print("SSID:" + wifi.Ssid.ToString());
            this.NetDuinoIPAddress = net.IPAddress.ToString();
        private static string BytesToHexString(byte[] bytes)
            string hexString = string.Empty;
            // Create a character array for hexadecimal conversion.
            const string hexChars = "0123456789ABCDEF";
            // Loop through the bytes.
            for (byte b = 0; b < bytes.Length; b++)
                if (b > 0)
                    hexString += "-";
                // Grab the top 4 bits and append the hex equivalent to the return string.
                hexString += hexChars[bytes[b] >> 4];
                // Mask off the upper 4 bits to get the rest of it.
                hexString += hexChars[bytes[b] & 0x0F];
            return hexString;
        public string getIPAddress()
            return this.NetDuinoIPAddress;
Android code
Java
This is Android code to unlock the bolt
package com.demo.netduinolock;
import android.os.AsyncTask;
import android.os.Bundle;
import android.support.v7.app.AppCompatActivity;
import android.util.Log;
import java.io.BufferedWriter;
import java.io.DataOutputStream;
import java.io.IOException;
import java.io.OutputStreamWriter;
import java.io.PrintWriter;
import java.net.InetAddress;
import java.net.Socket;
import java.net.UnknownHostException;
import cheekiat.slideview.SlideView;
public class MainActivity extends AppCompatActivity {
    SlideView mSlideView;
    private Socket socket;
    private static final int SERVERPORT = 80;
    private static final String SERVER_IP = "192.168.1.90";
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        mSlideView = (SlideView) findViewById(R.id.slide_view);
        mSlideView.setOnFinishListener(new SlideView.OnFinishListener() {
            @Override
            public void onFinish() {
            new ConnectTask().execute();
            mSlideView.reset();
    public class ConnectTask extends AsyncTask<String, String, String> {
        @Override
        protected String doInBackground(String... message) {
            try {
                InetAddress serverAddr = InetAddress.getByName(SERVER_IP);
                socket = new Socket(serverAddr, SERVERPORT);
                if(socket.isConnected()) {
                    PrintWriter out = new PrintWriter(new BufferedWriter(
                            new OutputStreamWriter(socket.getOutputStream())),
                            true);
                    out.println("ON");
                    out.flush();
                    out.close();
                    socket.close();
                    socket = null;
                else
                    Log.d("doh", "not conneected");
            } catch (UnknownHostException e) {
                e.printStackTrace();
            } catch (IOException e) {
            } catch (Exception e) {
            return null;
        @Override
        protected void onProgressUpdate(String... values) {
            super.onProgressUpdate(values);
            //response received from server
            Log.d("test", "done ");
            //process server response here....
Repo
The Android and Netduino C# project repo
Credits
Peter Ma
Peter Ma
22 projects • 92 followers
Prototype Hacker, Intel Software Innovator, Hackathon Goer, World Traveler, Ecological balancer, integrationist, technologist, futurist.
Comments
Add projectSign up / Login
