Shahariar
Published © LGPL
Trigonometric Height Measurement with 3D Magnetic Sensor
A device to measure the height of walls/buildings with high school trigonometry: sensing angle with a 3D magnetic sensor, dot laser & level.
EasyFull instructions provided4 hours258
Things used in this project
Hardware components
XMC2GO - industrial microcontroller kit
Infineon XMC2GO - industrial microcontroller kit
×1
Sparkfun breadboard holder
×1
Seeed Dot Lase
×1
e-Paper Eink display
×1
Amazon Web Services Spirit Level
×1
Pushbutton switch 12mm
SparkFun Pushbutton switch 12mm
×1
Ultrasonic Sensor - HC-SR04
SparkFun Ultrasonic Sensor - HC-SR04
×1
Arduino IDE
Arduino IDE
Soldering iron (generic)
Hot glue gun (generic)
Story
Read more
Schematics
Sch
ver 1
Sch v1 dzd6af40ww
Code
Code
C/C++
Ver 0.5b fina,l Download full code for font support !
#include <SPI.h>
#include "epd1in54.h"
#include "epdif.h"
#include "epdpai#include <SPI.h>
#include "epdif.h"
#include "epdpaint.h"
#include <Tle493d_w2b6.h>
#include <RTC.h>
#include <DeviceControlXMC.h>
int TRIGpin = 14;
int ECHOpin = 8;
int SWCHpin = 13;
int COLORED  = 0; // White in Black
int UNCOLORED = 1;  // Black in White
int pos = 20;
XMCClass xmc2go;
// TLV493 variables //
float Xm = 0.0;
float Ym = 0.0;
float Zm = 0.0;
float angleD = 0.0; // angle in degree
float angleR = 0.0; // angle in radian
long adjacent = 0.0; // base to device distance + offset 5 cm
long offset =5.0;
float height = 0.0; // height of wall
unsigned char image[8192];   // takes 8k RAM
// width must be multiple of 8
Paint paint(image, 0, 0);
Epd epd;
Tle493d_w2b6 Tle493dMagnetic3DSensor = Tle493d_w2b6();
pinMode (TRIGpin,OUTPUT);
pinMode (ECHOpin,INPUT);
pinMode (SWCHpin,INPUT);
///// Init Full Display Update ///////////
  if (epd.Init(lut_full_update) != 0)
  {return;}
///// Init Partial Display Update ////////
  if (epd.Init(lut_partial_update) != 0)
  {return;}
////////// Clears Up Full Disp ///////////
// bit set = white, bit reset = black
  epd.ClearFrameMemory(0xFF);
  epd.DisplayFrame();
  epd.DisplayFrame();
  /// Get Mag sensor running here ///
  Tle493dMagnetic3DSensor.begin();
  delay(50);
  Tle493dMagnetic3DSensor.enableTemp();
  delay(50);
  Tle493dMagnetic3DSensor.updateData();
    Xm = Tle493dMagnetic3DSensor.getX();
    Ym = Tle493dMagnetic3DSensor.getY();
    Zm = Tle493dMagnetic3DSensor.getZ();
 // angleD = 180+(57.3*Tle493dMagnetic3DSensor.getAzimuth());
 // offset for level
    angleD = (57.3*Tle493dMagnetic3DSensor.getAzimuth())-90;
    angleR = abs(angleD/57.3);
    digitalWrite(TRIGpin,LOW);
    delayMicroseconds(5);
    digitalWrite(TRIGpin,HIGH);
    delayMicroseconds(10);
    long duration_cm = pulseIn(ECHOpin,HIGH);
    adjacent = offset+ (duration_cm/58);
   height = tan(angleR)*adjacent;
   //height = tan(angleR)*200;
  char VAL[4];
  //  Data Optained From Mag /////
   SPI.begin();
   SPI.setClockDivider(SPI_CLOCK_DIV4);
   SPI.setBitOrder(MSBFIRST);
   SPI.setDataMode(SPI_MODE0);
  // Set Active Area on Disp with Orientation and Color //
  // more RAM allows more disp area to be used at once
   paint.SetWidth(200);
  paint.SetHeight(200);
  paint.SetRotate(ROTATE_270);
  paint.Clear(UNCOLORED);
  paint.DrawVerticalLine (110,120,50,COLORED);
  paint.DrawStringAt(120,140, "Height", &Font16, COLORED);
  paint.DrawHorizontalLine (30,170,80,COLORED);
  paint.DrawStringAt(40,180, "Adjacent", &Font16, COLORED);
  paint.DrawLine (30,170,110,120,COLORED);
  // itoa int to string conv
  paint.DrawStringAt(5,90, "Height", &Font20, COLORED);
  paint.DrawStringAt(130,90, itoa(height,VAL,10), &Font24, COLORED);
  paint.DrawStringAt(5,65, "Angle", &Font20, COLORED);
  paint.DrawStringAt(130,65, itoa(abs(angleD+180),VAL,10), &Font24, COLORED);
  paint.DrawStringAt(5,40, "Adjacent", &Font20, COLORED);
  paint.DrawStringAt(130,40, itoa(adjacent,VAL,10), &Font24, COLORED);
  paint.DrawStringAt(10,10, "Units in cm & deg", &Font16, COLORED);
   epd.SetFrameMemory(paint.GetImage(), 0, 0, paint.GetWidth(), paint.GetHeight());
   epd.DisplayFrame();
   delay(200);
} // loop ends here //
TrigMeasure.zip
C/C++
Full Code
No preview (download only).
Credits
Shahariar
Shahariar
27 projects • 93 followers
Tired of Life, Sick of Death! Torn by Failure, Worn by Faith! Effed by Time & Lost my Mind! 'Coz I'm Idiot, One of a Kind! ____Fake Engineer
Comments
Add projectSign up / Login
