Seeed
Published
DIY Smart Home Assistant with Raspberry Pi and ReSpeaker
ReSpeaker Mic Array, as the “ear” of Raspberry Pi here, can listen to your speech commands and send them to Raspberry Pi.
IntermediateFull instructions provided3 hours415
Things used in this project
Hardware components
ReSpeaker Mic Array - Far-field w/ 7 PDM Microphones
Seeed ReSpeaker Mic Array - Far-field w/ 7 PDM Microphones
×1
Seeed Raspberry Pi 3 Model B+
×1
Wio Link Starter Kit
Seeed Wio Link Starter Kit
×1
SD card
×1
Seeed USB Cable Type A to B - 30CM Black
×2
Story
Read more
Code
Code snippet #6
Plain text
git submodule init
git submodule update
cd snowboy/swig/Python
sudo apt-get install python-dev libatlas-base-dev swig           # requiremetns to compile snowboy
echo 'from snowboydetect import *' >__init__.py     # create__init__.pyfor a python module
cd ../../..                                          # chang to the root directory of the repository
ln -s snowboy/swig/Python snowboydetect
python kws_doa.py
Code snippet #8
Plain text
from respeaker.bing_speech_api import BingSpeechAPI as Bingimport wave
from mic_array import MicArray
import Queue
from pixel_ring import pixel_ring
import sys
import numpy as np
import collections
from snowboydetect import SnowboyDetect
import time
import json
from urllib import urlencode
from urllib2 import Request, urlopen, URLError, HTTPError# write your Wio token hereWIO_TOKEN = "**************"# write your Bing key hereKEY = "**********"
bing = Bing(key=KEY)RATE = 16000
CHANNELS = 8
KWS_FRAMES = 10     # ms
DOA_FRAMES = 800    # msdetector = SnowboyDetect('snowboy/resources/common.res', 'snowboy/resources/snowboy.umdl')
detector.SetAudioGain(1)
detector.SetSensitivity('0.5')# about 5seconds
q = Queue.Queue(maxsize=768)def gen_queue(q):
    try:
        data = q.get(timeout=1)
        while data:
            yield data
    except Queue.Empty:
        passdef controlLED(onoff=0):
    try:
        if onoff == 1:
            rgb_hex_string = '000080'
        else:
            rgb_hex_string = '000000'
        url = 'https://cn.wio.seeed.io/v1/node/GroveLedWs2812D0/clear/4/{}?access_token={}'.format(rgb_hex_string, WIO_TOKEN)
        request = Request(url, data='')
        response = urlopen(request)
        data = response.read()
        result = json.loads(data)
        if result['result'] == 'ok':
            return True
        else:
            return False
    except Exception as err:
        return Falsedef main():
    history = collections.deque(maxlen=int(DOA_FRAMES / KWS_FRAMES))
    global q    try:
        with MicArray(RATE, CHANNELS, RATE * KWS_FRAMES / 1000)  as mic:
            for chunk in mic.read_chunks():
                history.append(chunk)
                # Detect keyword from channel 0
                ans = detector.RunDetection(chunk[0::CHANNELS].tostring())
                if ans > 0:
                    print("wake up")
                    print("start recording")
                    pixel_ring.arc(12)
                    q.queue.clear()
                        q.put(chunk[0::CHANNELS].tostring())
                        if q.full():
                            break
                    print "queue full"
                    pixel_ring.spin()
                    text = bing.recognize(gen_queue(q))   # data can be generator
                    if text:
                        print('{}'.format(text))
                        if 'turn on' in text:
                            controlLED(1)
                        if 'turn off' in text:
                            controlLED(0)
                    pixel_ring.off()    except KeyboardInterrupt:
        pass    pixel_ring.off()
    # except ValueError:
    #     passif __name__ == '__main__':
    main()
Credits
Seeed
Seeed
6 projects • 5 followers
Seeed R&D Team
Comments
Add projectSign up / Login
