Steve Massikker
Published © CC BY
The URB Unit – Making Arduinos Network
Your personal universal electronics kit. More I/O pins. More devices. More distances. Remote wireless control. No bunch wires.
IntermediateFull instructions provided30 minutes3,747
Things used in this project
Hardware components
Arduino Nano R3
Arduino Nano R3
×2
Seeed URB 2.7 unit
×2
Servo Module (Generic)
×1
HC-05 Bluetooth Module
×1
Level Shifter Board (3.3V 5V)
×1
Resistor 10k ohm
Resistor 10k ohm
×2
Infrared Module (Generic)
×2
Arduino IDE
Arduino IDE
Arduino Train DEMO
Story
Read more
Schematics
Network between two and more Arduino's
Urb2 7 hackster fn3z23slhe
Code
Sketch for URB #1
Arduino
Sketch for URB #1 (Master I2C mode)
// WWW.ARDUINORAILWAYCONTROL.COM
// V.1.0  10/18/2018
// URB #1
// Protocol V.2 & URB unit V.2.7 and higher
// Author: Steve Massikker
void(* resetFunc) (void) = 0; // RESET FUNCTION
#include <SoftwareSerial.h>
#include <Wire.h>
// I/O PINS
#define SENSOR_J1_PIN    9
#define SENSOR_J3_PIN    11
SoftwareSerial Bluetooth(12, 13); // RX, TX
// VARIABLES
  // SERIAL EVENT
  bool stringComplete = false;
  String inputString = "";
  // I2C
  int addressI2C;
  byte dataToI2C = 0;
// Initialize Serial & I2C
  Serial.begin(9600);
  Bluetooth.begin(9600);
  Wire.begin();
  inputString.reserve(4);
// Initialize Sensors
  pinMode(SENSOR_J1_PIN, INPUT);
  pinMode(SENSOR_J3_PIN, INPUT);
// ----  PARSING INCOMING APP COMMANDS
  if (stringComplete) {
    // CONTROL FUNCTIONS
    if (inputString.charAt(0) =='a') {
      if (inputString.charAt(1) =='d') {
        if (inputString.charAt(2) =='b') {
          dataToI2C = 30;
          addressI2C = 2;
          sendDataViaI2C();
          delay(150);
        if (inputString.charAt(2) =='f') {
          dataToI2C = 31;
          addressI2C = 2;
          sendDataViaI2C();
          delay(150);
    inputString = "";
  // ---- COLLECT SENSORS STATE
  if (digitalRead(SENSOR_J1_PIN) == HIGH) {
    dataToI2C = 30;
    addressI2C = 2;
    sendDataViaI2C();
    delay(150);
  if (digitalRead(SENSOR_J3_PIN) == HIGH) {
    dataToI2C = 31;
    addressI2C = 2;
    sendDataViaI2C();
    delay(150);
  bluetoothEvent();
// ----------- FUNCTIONS ----------- //
void serialEvent() {
  if (Serial.available()) {
    char inChar = (char)Serial.read();
    inputString += inChar;
    if (inChar == 'z') {
      stringComplete = true;
void bluetoothEvent() {
  if (Bluetooth.available()) {
    char inChar = (char)Bluetooth.read();
void sendDataViaI2C() {
  Wire.beginTransmission(addressI2C);
  Wire.write(dataToI2C);
  Wire.endTransmission();
Sketch for URB #2
Arduino
Sketch for URB #2 (Slave I2C mode)
// V.1.0  10/18/2018
// URB #2
#include <Wire.h>
#include <Servo.h>
// I/O PINS
#define JUNCTION_EN 8
// Servo J1;
// Servo J2;
Servo J3;
// VARIABLES
unsigned long millisJunction;
byte dataFromI2C;
// Initialize I2C
  Wire.begin(2);
  Wire.onReceive(receiveI2C);
// Initialize Servos
  // J1.attach(9);
  // J2.attach(10);
  J3.attach(11);
  // COMMAND PARSING
  if (dataFromI2C != 0) {
    switch (dataFromI2C) {
    // SERVO
    case 30: J3.write(180);
         delay(50);
         digitalWrite(JUNCTION_EN, HIGH);
         millisJunction = millis();
         break;
    case 31: J3.write(0);
         delay(50);
         break;
  dataFromI2C = 0;
  if (millis() > (millisJunction + 800)) digitalWrite(JUNCTION_EN, LOW); // AUTO ON/OFF POWER ON SERVO
void receiveI2C(int howMany) {
  while (Wire.available() > 0) {
    dataFromI2C = Wire.read();
Credits
Steve Massikker
Steve Massikker
3 projects • 63 followers
I'm Steve Massikker, a graphic and visual designer and former engineer of civil aviation.
Comments
Add projectSign up / Login
