Achraf Oukheir
Published
Automatic Brightness Sensor
This small tool checks brightness, and if there is fog or night out, will turn on without human action or worry.
EasyShowcase (no instructions)12 minutes2,400
Things used in this project
Hardware components
Arduino UNO & Genuino UNO
×1
Resistor 221 ohm
Resistor 221 ohm
×1
Photo resistor
Photo resistor
×1
LED (generic)
LED (generic)
×1
Grove - Relay
Seeed Grove - Relay
×1
Arduino IDE
Arduino IDE
Story
Read more
Schematics
Photoresistance
I use voltage divider to check brightness
Photoresistor tq4nxi9lid
Code
Code
Arduino
//OUKHEIR Achraf
const int LumPin = A0;    // select the input pin for Senosr
const int RidPin1 = 9;      // select the pin for Rideaux
const int RidPin2 = 8;      // select the pin for Rideaux
int LumValue = 0;  // variable to store the value coming from the sensor
int SiLum =0 ; //Etat rideau 0
  // declare the ledPin as an OUTPUT:
  pinMode(RidPin1, OUTPUT);
  pinMode(LumPin, INPUT);
  Serial.begin(9600);
 Serial.print("Luminoste value = ");
Serial.println(ReadLum());
SiLum= LightDark();
if(SiLum==1){
   Rideaux1(1);
}else {
  Rideaux1(0);
//fonction de Luminosite read
int ReadLum(){
LumValue =analogRead(LumPin);
delay(100);
  return  LumValue;
//fonction de check Luminosite
int LightDark(){
 //check ifDark or light
  if ( LumValue  < 28) {
    // turn  on:
    digitalWrite(RidPin1, HIGH);
    return 1;
  } else  if ( LumValue  >33){
    // turn  off:
    digitalWrite(RidPin1, LOW);
  return 0;
//fonction de Rideau
int Rideaux1(int act){
  if(act==1){
  return 1;
  }else{
  return 0;
//OUKHEIR Achraf
Credits
Achraf Oukheir
Achraf Oukheir
6 projects • 8 followers
Comments
Add projectSign up / Login
