Adithya TG
Published © GPL3+
Alexa Based Smart Home Monitoring
You're at your Office and want to know about your home? Control your household devices and get alerts about home no matter wherever you are!
AdvancedFull instructions provided2 days8,359
Things used in this project
Hardware components
Arduino UNO & Genuino UNO
×1
ESP8266 ESP-01
Everything ESP ESP8266 ESP-01
×1
LinkIt Smart 7688 Duo
MediaTek Labs LinkIt Smart 7688 Duo
×1
DHT11 Temperature & Humidity Sensor
×1
4-CHANNEL RELAY CONTROLLER FOR I2C
ControlEverything.com 4-CHANNEL RELAY CONTROLLER FOR I2C
×1
IR obstacle sensor
×1
camera
×1
Jumper wires (generic)
×1
Arduino IDE
Arduino IDE
Alexa Skills Kit
Amazon Alexa Alexa Skills Kit
Amazon Alexa echosim.io
ThingSpeak API
ThingSpeak API
Backendless
Pushingbox
Story
Read more
Schematics
Circuit for uploading the code to ESP8266
Espprograming mx1buyeagr
Circuit Setup
Circuit qiv2ivxxbr
Code
Smart_bell_ESP8266.ino
Arduino
Code for ESP8266 to get alert about intruder and guest
 *  This sketch is implementation of smart bell and home security
#include <ESP8266WiFi.h>
#include<String.h>
//       variables
int intruder=0,guest=2;                     // pin 0 as intruder alert and pin2 as guest alert
const char* ssid     = "SSID";            //your SSID of WIFI
const char* password = "password";       // password of Wifi
const char* host = "api.thingspeak.com";
  delay(10);
  // We start by connecting to a WiFi network
  Serial.println();
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  /* Explicitly set the ESP8266 to be a WiFi-client, otherwise, it by default,
     would try to act as both a client and an access-point and could cause
     network-issues with your other WiFi-devices on your WiFi-network. */
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
int value = 0;
int x,y=0,z,k=0;
  ++value;
  Serial.print("connecting to ");
  Serial.println(host);
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  const int httpPort = 80;
  if (!client.connect(host, httpPort)) {
    Serial.println("connection failed");
    return;
  Serial.print("Requesting URL: ");
 //                                        intruder alert
 x=digitalRead(intruder);
//Serial.println(x);
  if(x==0)
    y=0;
  if(x==1&&y==0)
    Serial.println("Sending Alert Pls Wait.....");
  String host1="api.pushingbox.com";
    client.print(String("GET ")  + "/pushingbox?devid=<deviceID_intruderAlert> HTTP/1.1\r\n" +
               "Host: " + host1 + "\r\n" +
               "Connection: close\r\n\r\n");                       // executing pushing box api
    client.print(String("GET ")  + "/update?api_key=<write_key_intruderAlert>&field1=1 HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");                        //updating intruder notification
    y=1;
//                                         End of intruder alert
 //                                        guest alert
long t1;
 z=digitalRead(guest);
  if(z==0 && (millis()>=t1+300000)) // wait for 5 min to avoid multiple alert sending due to multiple door bell press
    k=0;
  if(x==1&&k==0)
    t1=millis();         // storing curent time stamp in t1
    delay(1000);                      //delay for sending alert and switch debouncing
    client.print(String("GET ")  + "/pushingbox?devid=<deviceID_guestAlert> HTTP/1.1\r\n" +
    client.print(String("GET ")  + "/update?api_key=<write_key_guestAlert>&field1=1 HTTP/1.1\r\n" +
               "Connection: close\r\n\r\n");                        //updating guest notification
    k=1;
//                                         End of guest alert
  unsigned long timeout = millis();
  while (client.available() == 0) {
    if (millis() - timeout > 5000) {
      Serial.println(">>> Client Timeout !");
      client.stop();
      return;
 //Serial.println("closing connection");
Home_monitor_arduino.ino
Arduino
Code for Arduino to control appliances
//This sketch in the implementation of home automation
#include <SoftwareSerial.h>// import the serial library
#include<String.h>
//    pin definations
#define Light 2              // pin 2 to control light
#define fan 3                 // pin 3 to control fan
//       variables
char e;
int p=0,q=0;        //these variables prevent switching ON/OFF of already turned ON/OFF devices
SoftwareSerial home_monitor(10, 11); // RX, TX
char control_data; // the data transmitted over Bluetooth
  home_monitor.begin(115200);
  Serial.begin(9600);
  pinMode(13,OUTPUT);
  if (home_monitor.available()){
     control_data=home_monitor.read();   // getting control information from ESP8266 serially
     e=control_data;
     Serial.print(control_data);
 //                                        Device Control
 // Performing required operations based on the value of channel
    //                        LIGHT
    if(e=='0'&&p==0)         //Light ON
      digitalWrite(Light,LOW);
      p=1;
     if(e=='1'&&p==1)        //Light off
      digitalWrite(Light,HIGH);
      p=0;
    //                        Heater
    if(e=='2'&&q==0)
      digitalWrite(fan,HIGH);
      q=1;
    if(e=='3'&&q==1)
      digitalWrite(fan,LOW);
      q=0;
Home_Monitor_ESP8266.ino
Arduino
Code For ESP8266 to update humidity and temperature in thingspeak and also retrieve control information from thingspeak
 * This sketch updates wheather information in thingspeak.com and also retrieve control information from thingspeak.com
 * It send the control information to arduino serially
#include<String.h>
#include "DHT.h"        // including the library of DHT11 temperature and humidity sensor
#define DHTTYPE DHT11   // DHT 11
#define dht_dpin 2      // define GPIO2 as data input
DHT dht(dht_dpin, DHTTYPE);
//       variables
//dht DHT;
char c,e;                       // stores the bytes coming from the server
float temp,h;                   //stores float value of temp and humididty
String humidity,temperature,line;    //stores string value of temp and humididty
int co=0;                       //control the sending of Alert
  dht.begin();
  delay(10);
  Serial.println();
  Serial.println();
    delay(500);
    Serial.print(".");
  Serial.println("");
int value = 0;
  ++value;
  WiFiClient client;
    return;
 //                                        Mini Weather Station
  h = dht.readHumidity();                    //reads humidity and temperature
  temp = dht.readTemperature();
  if(temp<50.0)
    co=0;
  if(temp>=50.0&&co==0)      // send alert if temperature is above 50 degrees and co is used to avoid multiple alert sending
    Serial.println("Sending Alert please wait.......");
    client.print(String("GET ")  + "/pushingbox?devid=<deviceID_fireAlert> HTTP/1.1\r\n" +
               "Connection: close\r\n\r\n");           //pushingbox api to send alert
     client.print(String("GET ")  + "/update?key=<write_key_fireAlert>&field1=1 HTTP/1.1\r\n" +
               "Connection: close\r\n\r\n");           //updating thingspeak fire alert channel
    co=1;
  humidity=String(h);
  temperature=String(temp);
  Serial.println(h);
  Serial.println(temp);
  client.print(String("GET ")  + "/update?key=<write_key_humidity>&field1="+humidity+" HTTP/1.1\r\n" +
               "Connection: close\r\n\r\n");                                                         //update humidity in thingspeak channel
  client.print(String("GET ")  + "/update?key=<write_key_temperature>&field1="+temperature+" HTTP/1.1\r\n" +
               "Connection: close\r\n\r\n");                                                         ////update temperature in thingspeak channel
//                                         End of Weather Station
//                                Sending Control info to arduino Serially
  // This will send the request to the server
  client.print(String("GET ")  + "/channels/<channelID_control>/field/field1/last.html HTTP/1.1\r\n" +
               "Connection: close\r\n\r\n");         // get information about device control
      client.stop();
      return;
  // Read all the lines of the reply from server and print them to Serial
  while(client.available()){
    String line = client.readStringUntil('\r');
  Serial.print(line);                         // received by arduino serially
Credits
Adithya TG
Adithya TG
1 project • 9 followers
Studying Electronics and communication engineering
Contact
Comments
Add projectSign up / Login
