Alexis Santiago Allende
Published © GPL3+
Eco-Thing #1 "Eco-Smart-Container V1.0"
An IoT device that could help keep the Sandy River Delta clean, as garbage is a very common problem.
IntermediateFull instructions provided10 hours4,985
Things used in this project
Hardware components
Arduino 101 & Genuino 101
×1
SparkFun Inventor's Kit for Arduino 101
×1
Raspberry Pi Zero Wireless
×1
DHT22 Temperature Sensor
×1
Grove starter kit plus for Intel Edison
Seeed Grove starter kit plus for Intel Edison
×1
Jumper wires (generic)
×1
Ultrasonic Sensor - HC-SR04 (Generic)
×1
SparkFun Soil Moisture Sensor (with Screw Terminals)
×1
Breadboard (generic)
×1
Li-Ion Battery 1000mAh
×1
USB-A to B Cable
USB-A to B Cable
×1
USB-A to Micro-USB Cable
×1
Blynk
Blynk
Arduino IDE
Arduino IDE
Hot glue gun (generic)
Story
Read more
Schematics
Example
Asa 6ypbaygxrw
Code
Main code arduino
Arduino
/*Made by Alexis Santiago Allende Last Update 17/07/17*/
#include <CurieBLE.h>
#include "CurieIMU.h"
#include <Wire.h>
#include "rgb_lcd.h"
#include <CurieTime.h>
BLEPeripheral blePeripheral;//BLE Peripheral Device (Arduino Device)
BLEService demo111("19b10000-e8f2-537e4f6c-d104768a1214"); // BLE demo111 Service
// BLE sensor rate Characteristic"
BLEUnsignedIntCharacteristic sensor1("19b10001-e8f2-537e4f6c-d104768a1214", BLERead | BLENotify);
BLEUnsignedIntCharacteristic sensor2("19b10002-e8f2-537e4f6c-d104768a1214", BLERead | BLENotify);
BLEUnsignedIntCharacteristic sensor3("19b10003-e8f2-537e4f6c-d104768a1214", BLERead | BLENotify);
BLEUnsignedIntCharacteristic sensor4("19b10004-e8f2-537e4f6c-d104768a1214", BLERead | BLENotify);
//Ble palabra sensor Characteristic
BLECharacteristic palabra("19b10005-e8f2-537e4f6c-d104768a1214", BLERead | BLENotify,10);
// BLE demo111 buttons Characteristic - custom 128-bit UUID, read and writable by central
BLEUnsignedCharCharacteristic buttons("19b10006-e8f2-537e4f6c-d104768a1214", BLERead | BLEWrite);
rgb_lcd lcd;
const int colorR = 198;
const int colorG = 78;
const int colorB = 25;
int lastOrientation = - 1; // previous orientation (for comparison)
long previousMillis = 0;  // last time the sensor was checked, in ms
const int green = 13; // pin to use for the green light
const int red = 11;// pin to use for the red light
boolean a = LOW, b = LOW; //Control variables
int temp=0;
long distancia;
long tiempo;
int orientation;
int valor=0,nivel=0,ndistancia;
  Serial.begin(9600);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  lcd.setRGB(colorR, colorG, colorB);
  // Print a message to the LCD.
  setTime(16, 56, 24, 3, 07, 2017);
  lcd.print("Have a nice day!");
  lcd.setCursor(12, 1);
  lcd.print("Off");
  pinMode(green, OUTPUT); // use the LED on pin 13 as an output
  pinMode(red, OUTPUT);
  pinMode(9, OUTPUT); /*activación del pin 9 como salida: para el pulso ultrasónico*/
  pinMode(8, INPUT);
  CurieIMU.begin();
  CurieIMU.setAccelerometerRange(2);
  // set the local name peripheral advertises
  blePeripheral.setLocalName("Demo111");
  // set the UUID for the service this peripheral advertises
  blePeripheral.setAdvertisedServiceUuid(demo111.uuid());
  // add service and characteristic
  blePeripheral.addAttribute(demo111);
  blePeripheral.addAttribute(buttons);
  blePeripheral.addAttribute(sensor1);
  blePeripheral.addAttribute(sensor2);
  blePeripheral.addAttribute(sensor3);
  blePeripheral.addAttribute(sensor4);
  blePeripheral.addAttribute(palabra);
  // assign event handlers for connected, disconnected to peripheral
  blePeripheral.setEventHandler(BLEConnected, blePeripheralConnectHandler);
  blePeripheral.setEventHandler(BLEDisconnected, blePeripheralDisconnectHandler);
  // assign event handlers for characteristic
  buttons.setEventHandler(BLEWritten, switchCharacteristicWritten);
 // sensors.setEventHandler(BLEWritten, switchCharacteristicWritten);
// set an initial value for the characteristic
  buttons.setValue(0);
  sensor1.setValue(0);
  sensor2.setValue(0);
  sensor3.setValue(0);
  sensor4.setValue(0);
  // advertise the service
  blePeripheral.begin();
  Serial.println(("Bluetooth device active, waiting for connections..."));
  // poll peripheral
  blePeripheral.poll();
  digitalWrite(9,LOW); /* Por cuestión de estabilización del sensor*/
  delayMicroseconds(5);
  digitalWrite(9, HIGH); /* envío del pulso ultrasónico*/
  delayMicroseconds(10);
  tiempo=pulseIn(8, HIGH); /* Función para medir la longitud del pulso entrante. Mide el tiempo que transcurrido entre el envío
  del pulso ultrasónico y cuando el sensor recibe el rebote, es decir: desde que el pin 12 empieza a recibir el rebote, HIGH, hasta que
  deja de hacerlo, LOW, la longitud del pulso entrante*/
  distancia= int(0.017*tiempo); /*fórmula para calcular la distancia obteniendo un valor entero*/
    char clockTime[8];
  //use sprintf to create a time string of the hour, minte and seconds
  sprintf(clockTime, "%02d:%02d:%02d", hour(), minute(), second());
  //set cursor to column 0, row 0
 lcd.setCursor(2, 1);
 //print the date string over lcd
 lcd.print(clockTime);
  long currentMillis = millis();
      // if 1s have passed, check the sensor:
      if (currentMillis - previousMillis >= 1000) {
        previousMillis = currentMillis;
        updateSensor();
  orientation = - 1;   // the board's orientation
  String orientationString; // string for printing description of orientation
  // read accelerometer:
  int x = CurieIMU.readAccelerometer(X_AXIS);
  int y = CurieIMU.readAccelerometer(Y_AXIS);
  int z = CurieIMU.readAccelerometer(Z_AXIS);
  // calculate the absolute values, to determine the largest
  int absX = abs(x);
  int absY = abs(y);
  int absZ = abs(z);
  if ( (absZ > absX) && (absZ > absY)) {
    // base orientation on Z
    if (z > 0) {
      orientationString = "up";
      orientation = 0;
    } else {
      orientationString = "down";
      orientation = 1;
  } else if ( (absY > absX) && (absY > absZ)) {
    // base orientation on Y
    if (y > 0) {
      orientationString = "digital pins up";
      orientation = 2;
    } else {
      orientationString = "analog pins up";
      orientation = 3;
  } else {
    // base orientation on X
    if (x < 0) {
      orientationString = "connector up";
      orientation = 4;
    } else {
      orientationString = "connector down";
      orientation = 5;
  // if the orientation has changed, print out a description:
  if (orientation != lastOrientation) {
    Serial.println(orientationString);
    lastOrientation = orientation;
void blePeripheralConnectHandler(BLECentral& central) {
  // central connected event handler
  lcd.clear();
  lcd.setCursor(0, 0);
  Serial.print("Connected event, central: ");
  Serial.println(central.address());
  lcd.print("On");
void blePeripheralDisconnectHandler(BLECentral& central) {
  // central disconnected event handler
  lcd.clear();
  Serial.print("Disconnected event, central: ");
  lcd.print("Off");
void switchCharacteristicWritten(BLECentral& central, BLECharacteristic& characteristic) {
  // central wrote new value to characteristic, update LED
  Serial.print("Characteristic event, written: ");
  Serial.print(buttons.value());
  if (buttons.value() == 1 && a == LOW) { // 1 in ASCII
          Serial.print("LED on");
          digitalWrite(green, HIGH);         // will turn the LED on
          a = HIGH;
        } else if (buttons.value() == 1 && a == HIGH)  {  //when 1 was read again (second time)
          Serial.println("LED off");
          digitalWrite(green, LOW);          // will turn the LED off
          a = LOW;
        else if (buttons.value() == 2 && b == LOW) { // 1 in ASCII
          digitalWrite(red, HIGH);         // will turn the LED on
          b = HIGH;
        } else if (buttons.value() == 2 && b == HIGH)  {  //when 1 was read again (second time)
          digitalWrite(red, LOW);          // will turn the LED off
          b = LOW;
void updateSensor() {
  temp=analogRead(A0);//dht.readTemperature();//read temperature
  valor=analogRead(A1);
  nivel = map(valor, 0, 1023, 100, 0);
  ndistancia = map(distancia, 38, 2, 0, 100);
  float sensorLevel = temp*(3.3/1023);
  int temp1=(sensorLevel-0.5)*100;
  sensor1.setValue(temp1);//send temperature value
  sensor2.setValue(distancia);//send distance value
  sensor3.setValue(orientation);//send orientation value
  sensor4.setValue(nivel);//send percentage of hummidity value
  Serial.println(temp1);
  Serial.println(distancia);
  Serial.println(orientation);
  Serial.println(nivel);
Main code Node JS
JavaScript
//Blynk
var Blynk = require('blynk-library');
var AUTH = 'adea86da8f774157b6a4997a6ed18a08';
var blynk = new Blynk.Blynk(AUTH);
var v1 = new blynk.VirtualPin(1);
var v9 = new blynk.VirtualPin(9);
var v8 = new blynk.VirtualPin(8);
var v7 = new blynk.VirtualPin(7);
var v6 = new blynk.VirtualPin(6);
var v5 = new blynk.VirtualPin(5);
var v4 = new blynk.VirtualPin(4);
var v3 = new blynk.VirtualPin(3);
//Bluetooth low energy
var noble = require('noble');
// Search only for the Service UUID of the device (remove dashes)
var serviceUuids = ['19b10000e8f2537e4f6cd104768a1214'];
// Search only for the led charateristic
var characteristicUuids = ['19b10001e8f2537e4f6cd104768a1214','19b10002e8f2537e4f6cd104768a1214','19b10003e8f2537e4f6cd104768a1214','19b10004e8f2537e4f6cd104768a1214','19b10005e8f2537e4f6cd104768a1214','19b10006e8f2537e4f6cd104768a1214'];
var sensor1=0;
var sensor2=0;
var sensor3=0;
var sensor4=0;
var temperatura=0;
var humedad=0;
var boton=0;
var contador1=0,contador2=0,contador3=0,contador4=0;
//Twilio
const twilio = require('twilio')
var accountSid = 'AC4c3a664e0475a08a4e0fdbd016555a70';
var authToken = '22ee6e5fe596967997a2d1a57d6d73eb';
const phone = new twilio(accountSid, authToken);
const sendMessage = () => {
  phone.messages.create({
    to: "+526462378678",
    body: 'WARNING!!!!!! take care, please review your Blynk app now!!!!!',
//Reading DHT22
var sensor = require('node-dht-sensor');
//Final
v1.on('write', function(param) {
  boton=param[0];
v9.on('read', function() {
  v9.write(new Date().getSeconds());
v8.on('read', function() {
  v8.write(sensor1);
v7.on('read', function() {
  v7.write(humedad);
v6.on('read', function() {
  v6.write(temperatura);
v5.on('read', function() {
  v5.write(sensor2);
v4.on('read', function() {
  v4.write(sensor3);
  v4.write(sensor4);
// start scanning when bluetooth is powered on
noble.on('stateChange', function(state) {
  if (state === 'poweredOn') {
    noble.startScanning(serviceUuids);
  } else {
    noble.stopScanning();
//Reading sensor
setInterval(function() {
sensor.read(22, 21, function(err, temperature, humidity) {
    if (!err) {
         temperatura=temperature.toFixed(1);
         humedad= humidity.toFixed(1);
        }, 1000);
// Search for BLE peripherals
noble.on('discover', function(peripheral) {
  peripheral.connect(function(error) {
    console.log('connected to peripheral: ' + peripheral.uuid);
    // Only discover the service we specified above
    peripheral.discoverServices(serviceUuids, function(error, services) {
      var service = services[0];
      console.log('discovered service');
      service.discoverCharacteristics(characteristicUuids, function(error, characteristics) {
        console.log('discovered characteristics');
        // Assign Characteristic
        var sensor1Characteristic = characteristics[1];
        var sensor2Characteristic = characteristics[2];
        var sensor3Characteristic = characteristics[3];
        var sensor4Characteristic = characteristics[4];
       //var botonCharacteristic = characteristics[4];
            sensor1Characteristic.read(function(error, data) {
            // data is a buffer
            console.log('Temperature is: ' + data.readUInt8(0));
            sensor1=data.readUInt8(0);
            if (data.readUInt8(0)>=32 && contador1===0) {
                    sendMessage();
                    contador1=1;
            else if(data.readUInt8(0)<=30 && contador1==1){
                      contador1=0;
             sensor2Characteristic.read(function(error, data) {
            // data is a buffer
            console.log('Trash percent is: ' + data.readUInt8(0));
            sensor2=data.readUInt8(0);
            if (data.readUInt8(0)<=4 && contador2===0) {
                    sendMessage();
                    contador2=1;
            else if(data.readUInt8(0)>=30 && contador2==1){
                      contador2=0;
             sensor3Characteristic.read(function(error, data) {
            // data is a buffer
            console.log('Orientation: ' + data.readUInt8(0));
            sensor3=data.readUInt8(0);
            if (data.readUInt8(0)!=2 && contador3===0) {
                    sendMessage();
                    contador3=1;
            else if(data.readUInt8(0)==2 && contador3==1){
                      contador3=0;
            sensor4Characteristic.read(function(error, data) {
            // data is a buffer
            console.log('Humidity: ' + data.readUInt8(0));
            sensor4=data.readUInt8(0);
            if (data.readUInt8(0)>=90 && contador4===0) {
                    sendMessage();
                    contador4=1;
            else if(data.readUInt8(0)<=30 && contador4==1){
                      contador4=0;
        }, 1000);
             //  var bufferToSend = new Buffer(1);
               // bufferToSend.writeUInt8(boton);
               // console.log(bufferToSend);
               // botonCharacteristic.write(bufferToSend, false);
           // setInterval(function() {
           //bufferToSend.writeUInt8(1); // you can pass this any integer, we just do this to alternate 0/1
       // }, 1000);
Credits
0 projects • 42 followers
Im a person who since young feel a passion for electronics, I also like to cook pizza and travel. Now Im working on the internet of things
Comments
Add projectSign up / Login
