Peter MaJustin ShenkShin Ae HongSarah Han
Published © LGPL
Clean Water AI
Using AI to detect dangerous bacteria and harmful particles in the water.
AdvancedFull instructions providedOver 1 day8,846
Things used in this project
Hardware components
UP² Grove IoT Development Kit
×1
Movidius Neural Compute Stick
Intel Movidius Neural Compute Stick
×1
Helium Starter Kit
Helium Starter Kit
×1
Arduino UNO & Genuino UNO
×1
Snappy Ubuntu Core
Snappy Ubuntu Core
Microsoft Azure
Microsoft Azure
NASA World Wind
Story
Read more
Custom parts and enclosures
Up2 Board
Up2 Board
Schematics
Helium IoT
Using Helium IoT to connect to Google IoT Core
Helium arch i8wmdltovl
Code
Arduino water pump
Arduino
Arduino of Water pumping
#define ROTARY_ANGLE_SENSOR A0
#define LED 3  //the Grove - LED is connected to PWM pin D3 of Arduino
#define ADC_REF 5 //reference voltage of ADC is 5v.If the Vcc switch on the seeeduino
                    //board switches to 3V3, the ADC_REF should be 3.3
#define GROVE_VCC 5 //VCC of the grove interface is normally 5v
#define FULL_ANGLE 300 //full value of the rotary angle is 300 degrees
const int ledPin =  6;      // the number of the LED pin
const int ledPin2 =  5;      // the number of the LED pin
int incomingByte = 0;   // for incoming serial data
const int buttonPin = 2;     // the number of the pushbutton pin
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  Serial.begin(9600);     // opens serial port, sets data rate to 9600 bps
  pinMode(ROTARY_ANGLE_SENSOR, INPUT);
  pinMode(LED,OUTPUT);
    buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
    Serial.println("on");
  } else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
    Serial.println("off");
      float voltage;
    int sensor_value = analogRead(ROTARY_ANGLE_SENSOR);
    voltage = (float)sensor_value*ADC_REF/1023;
    float degrees = (voltage*FULL_ANGLE)/GROVE_VCC;
    //Serial.println("The angle between the mark and the starting position:");
    //Serial.println(degrees);
    if(degrees < 100)
      digitalWrite(ledPin2, HIGH);
    else
      digitalWrite(ledPin2, LOW);
    delay(100);
Clean Water AI Repo
Clean Water AI Repo
Credits
Peter Ma
Peter Ma
22 projects • 92 followers
Prototype Hacker, Intel Software Innovator, Hackathon Goer, World Traveler, Ecological balancer, integrationist, technologist, futurist.
Justin Shenk
Justin Shenk
3 projects • 12 followers
Machine learning and computer vision research engineer with background in neuroscience.
Shin Ae Hong
Shin Ae Hong
3 projects • 9 followers
Global Startup Incubation Specialist @Innoway
Sarah Han
Sarah Han
2 projects • 13 followers
Software Engineer, UX/UI Designer, Graphic Designer, 3D modeling
Comments
Add projectSign up / Login
