Constantin Craciun
Published © GPL3+
Air quality/weather station
This is good starting project for people interested in Internet of Things devices and wishing to start with something both simple and fun.
EasyFull instructions provided8,090
Things used in this project
Hardware components
Arduino Ethernet
×1
Seeed Grove - CO2 Sensor
×1
Seeed Temperature sensor with steel head
×1
Seeed Grove - Sound Sensor
×1
Story
Read more
Code
Arduino code
C/C++
Air Quality/Weather station
  |--> device that monitors the temperature,
       noise and carbon dioxide levels via devicehub.net
 Hardware parts:
   1. Microcontroller board
       ---> Arduino Ethernet
        |-> http://arduino.cc/en/Main/arduinoBoardEthernet
   2. Sound sensor
       ---> Grove - Sound Sensor w/ LM358 amplifier and an electret microphone
        |-> http://www.seeedstudio.com/wiki/index.php?title=Twig_-_Sound_Sensor
   3. Temperature sensor
       ---> One Wire Temperature Sensor waterproof DS18B20
       |-> http://datasheets.maximintegrated.com/en/ds/DS18B20.pdf
   4. CO2 sensor
       ---> Grove - CO2 Sensor
        |-> http://www.seeedstudio.com/wiki/images/c/ca/MH-Z16_CO2_datasheet_EN.pdf
   5. Additional parts
       ---> 4.7K resistor
 Connections:
   1. Sound sensor
       ---> Arduino Analog A0
   2. Temperature sensor
      ----> Arduino Digital 2
       |--> 4.7K resistor between signal and the power pin
   3. CO2 sensor
       ---> Arduino Digital 3 ( TX )
        |-> Arduino Digital 4 ( RX )
 Libraries:
   1. OneWire
       ---> http://code.bildr.org/download/997.zip
   2. MQTT PubSubClient
       ---> https://github.com/knolleary/pubsubclient/archive/v1.9.1.zip
   3. Dallas Temperature
       ---> http://www.hacktronics.com/code/DallasTemperature.zip
 Web platform:
   DeviceHUB.net
 23.06.2015
 Author: Alexandru Gheorghe
#include <SPI.h>
#include <OneWire.h>
#include <Ethernet.h>
#include <PubSubClient.h>
#include <SoftwareSerial.h>
#include <DallasTemperature.h>
// MAC Address of Arduino Ethernet (Sheild)
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
#define API_KEY           "paste_apikey_here"
#define PROJECT_ID        "paste_projectid_here"
#define TEMPERATURE_NAME  "paste_temp_sensor_name_here"
#define NOISE_NAME        "paste_noise_sensor_name_here"
#define CO2_NAME          "paste_co2_sensor_name_here"
#define DEVICE_UUID       "paste_device_uuid_name_here"
#define sec               1000
char clientId[]        = "write_a_client_name_without_spaces"; // e.g. char clientId[] = "my_arduino"
char TempTopic[]       = "/a/"API_KEY"/p/"PROJECT_ID"/d/"DEVICE_UUID"/sensor/"TEMPERATURE_NAME"/data";
char NoiseTopic[]      = "/a/"API_KEY"/p/"PROJECT_ID"/d/"DEVICE_UUID"/sensor/"NOISE_NAME"/data";
char CO2Topic[]        = "/a/"API_KEY"/p/"PROJECT_ID"/d/"DEVICE_UUID"/sensor/"CO2_NAME"/data";
// server mqtt.devicehub.net ip
char server[]         = "104.155.7.31";
char message_buffer1[20];
char message_buffer2[20];
char message_buffer3[20];
EthernetClient apiClient;
void callback(char* topic, byte* payload, unsigned int length)
  // handle message arrived
PubSubClient client(server, 1883, callback, apiClient);
boolean conn = false;
unsigned long time;
#define DS18S20_Pin  2        // DS18S20 Signal pin on digital 2
OneWire ds(DS18S20_Pin);      // on digital pin 2
DallasTemperature sensors(&ds);
int counter = 0;
// CO2 sensor
#define pinTx  3
#define pinRx  4
SoftwareSerial sensorCo2(pinTx,pinRx);
const unsigned char cmd_get_sensor[] = {
0xff, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79};
const unsigned char cmd_c_sensor[] = {
0xff, 0x01, 0x87, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78};
// Noise variables
#define noise_pin        A0   // Microphone is connected to Analog 0
const int sampleWindow = 50;  // Sample window width in mS (50 mS = 20Hz)
unsigned int sample;
// variables for smoothing the microphone values
const int numReadings = 10;
int readings[numReadings];
int index = 0;
int total = 0;
int average = 0;
void setup(void)
  // init serial for debugging
  Serial.begin(9600);
  initPins();
  if (Ethernet.begin(mac) == 0)
    Serial.println(F("Failed to configure Ethernet using DHCP"));
    Ethernet.begin(mac);
  Serial.println(F("\nStarting connection to server..."));
  if(client.connect(clientId))
    conn = true;
    Serial.println(F("Successfuly connected and running!"));
  else
    Serial.println(F("Connection problem"));
  Serial.println(F("Starting..."));
  Serial.println(F("3 minutes warm-up CO2 sensor..."));
  // warm-up time for co2 sensor
  while(counter < 2)  {
    Serial.println(counter);
    delay(sec);
    counter++;
  Serial.print('\n');
  Serial.println(F("Warm-up completed"));
  Serial.print('\n');
  // start a serial communication with the CO2 sensor
  sensorCo2.begin(9600);
  // cablibrate the zero point for CO2 sensor
  Serial.println(F("Calibrating CO2 sensor..."));
    for(int i = 0; i < sizeof(cmd_c_sensor); i++)  {
    sensorCo2.write(cmd_c_sensor[i]);
  delay(3*sec);
  Serial.println(F("Calibration completed"));
void loop(void)
  //if client it's not connected or disconnects here we try to reconnect
  if (!client.connected())
    Serial.println(F("reconnecting ..."));
    client.connect(clientId);
    delay(3*sec);
    sendData();
  sendData();
void sendData(void)
  float ThermometerTemperature = getTemp();
  float Noise = getNoise();
  int gas;
  int tempCo2;
  // get co2 value from function getCarbonDioxide
  if(getCarbonDioxide(&gas, &tempCo2))  {
    gas;
  if(conn)
    //publishing new value every 5 seconds
    if (millis() > (time + 5*sec))
      time = millis();
      String pubString1 = "{\"value\": " + String(ThermometerTemperature) + "}";
      String pubString2 = "{\"value\": " + String(Noise) + "}";
      String pubString3 = "{\"value\": " + String(gas) + "}";
      pubString1.toCharArray(message_buffer1, pubString1.length()+1);
      pubString2.toCharArray(message_buffer2, pubString2.length()+1);
      pubString3.toCharArray(message_buffer3, pubString3.length()+1);
      Serial.println(F("Publishing new value: "));
      Serial.println(ThermometerTemperature);
      Serial.println(Noise);
      Serial.println(gas);
      client.publish(TempTopic,  message_buffer1);
      client.publish(NoiseTopic, message_buffer2);
      client.publish(CO2Topic,   message_buffer3);
    // MQTT client loop processing
    client.loop();
void initPins()
  pinMode(noise_pin, INPUT);
// returns the temperature from DS18S20 in DEG Celsius
float getTemp(void)
  sensors.requestTemperatures();
  float currentTemp;
  currentTemp = sensors.getTempCByIndex(0);
  return currentTemp;
void sendcommand(uint8_t *pcommand)
    uint8_t i;
    for (i=0;i<9;i++)
      sensorCo2.write(pcommand[i]);
// returns the gas strength from the CO2 sensor
bool getCarbonDioxide(int *gas_strength, int *temperatureGas)
  for(int i = 0; i < sizeof(cmd_get_sensor); i++)
    sensorCo2.write(cmd_get_sensor[i]);
  long cnt_timeout = 0;
  while(!sensorCo2.available())
    delay(1);
    cnt_timeout++;
    if(cnt_timeout > 1000)
      return 0;
  int len = 0;
  unsigned char dta[20];
  while(sensorCo2.available())
    dta[len++] = sensorCo2.read();
  if((9 == len) && (0xff == dta[0]) && (0x86 == dta[1]))
    *gas_strength = 256*dta[2]+dta[3];
    *temperatureGas = dta[4] - 40;
    delay(5*sec);
    return 1;
  return 0;
// returns the decibels from sound sensor
float getNoise()
  unsigned long startMillis= millis();
  unsigned int peakToPeak = 0;
  unsigned int signalMax = 0;
  unsigned int signalMin = 750;
  while (millis() - startMillis < sampleWindow)
    sample = analogRead(noise_pin);
    if (sample < 1024)
      if (sample > signalMax)
        signalMax = sample;
      else if (sample < signalMin)
         signalMin = sample;
  peakToPeak = signalMax - signalMin;
  // transform voltage to decibels
  double dB = 3.1 * 20.0  * log10 (peakToPeak  +1.);
  // smoothing the values from sensor
  total= total - readings[index];
  readings[index] = dB;
  total= total + readings[index];
  index = index + 1;
  if (index >= numReadings)
    index = 0;
  average = total / numReadings;
  int realdB = map(average, 100, 190, 40,100);
  delay(30);
  // not send false values
  if(realdB > 4)
    delay(6*sec);
    return realdB;
Credits
Constantin Craciun
Constantin Craciun
5 projects • 34 followers
Passionate about hardware development and IoT.
Contact
Comments
Add projectSign up / Login
