Dhairya Parikh
Published © LGPL
The Environment Cube! Know the Land Beneath You using Sigfox
A cube with all the necessary sensors, suitable for a wide range of applications like agriculture, monitoring, ,etc.
IntermediateFull instructions provided4 hours766
Things used in this project
Hardware components
Grove - Temperature Sensor
Seeed Grove - Temperature Sensor
×1
Grove - Air quality sensor v1.3
Seeed Grove - Air quality sensor v1.3
×1
Grove - Light Sensor
Seeed Grove - Light Sensor
×1
SparkFun Soil Moisture Sensor (with Screw Terminals)
×1
Arduino MKR Fox 1200
×1
Sigfox
Sigfox
Arduino IDE
Arduino IDE
Arduino Web Editor
Arduino Web Editor
Arduino Cloud
Arduino Cloud
Story
Read more
Code
The code for temperature and humidity sensor DTH 11
Arduino
#include <ArduinoLowPower.h>
#include <SigFox.h>
#include <DHT.h>
#define DHTPIN 1
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
float temperature;
float t;
float h;
    ATTENTION - the structure we are going to send MUST
    be declared "packed" otherwise we'll get padding mismatch
    on the sent data - see http://www.catb.org/esr/structure-packing/#_structure_alignment_and_padding
    for more details
typedef struct __attribute__ ((packed)) sigfox_message {
  uint8_t status;
  int16_t moduleTemperature;
  int16_t t;
  int16_t h;
} SigfoxMessage;
// stub for message which will be sent
SigfoxMessage msg;
  if (!SigFox.begin()) {
    // Something is really wrong, try rebooting
    // Reboot is useful if we are powering the board using an unreliable power source
    // (eg. solar panels or other energy harvesting methods)
    reboot();
  //Send module to standby until we need to send a message
  SigFox.end();
  SigFox.debug();
  dht.begin();
  t = dht.readTemperature();
  msg.t = convertoFloatToInt16(t, 60, -60);
  h = dht.readHumidity();
  msg.h = convertoFloatToUInt16(h, 110);
  // Start the module
  SigFox.begin();
  // Wait at least 30ms after first configuration (100ms before)
  delay(100);
  // We can only read the module temperature before SigFox.end()
  temperature = SigFox.internalTemperature();
  msg.moduleTemperature = convertoFloatToInt16(temperature, 60, -60);
  // Clears all pending interrupts
  SigFox.status();
  delay(1);
  SigFox.beginPacket();
  SigFox.write((uint8_t*)&msg, 12);
  int lastMessageStatus = SigFox.endPacket();
  SigFox.end();
  //Sleep for 15 minutes
  LowPower.sleep(15 * 60 * 1000);
void reboot() {
   NVIC_SystemReset();
   while (1) ;
Credits
Dhairya Parikh
Dhairya Parikh
9 projects • 21 followers
An open source lover who loves to help and be helped from the community :). Interested in machine learning and iot projects. Arduino lover.
Contact
Comments
Add projectSign up / Login
