Dhairya Parikh
Published © LGPL
WiSor - The Wireless Sensor Hub
A new way to connect sensors! Connect up to five sensors to the particle powered WiSor and obtain real-time data on your mobile phone!
IntermediateFull instructions provided5 hours810
Things used in this project
Hardware components
Photon
Particle Photon
×1
4xAA battery holder
4xAA battery holder
To power the photon
×1
switch
To switch on/off the particle photon.
×1
Linear Regulator (7805)
To provide steady 5V to the photon
×1
Jumper wires (generic)
for connections
×1
AA Batteries
AA Batteries
powering the WiSor
×1
LED (generic)
LED (generic)
Indicator that the device is ON
×1
DHT11 Temperature & Humidity Sensor (4 pins)
For testing the Hub
×1
Grove - Air quality sensor v1.3
Seeed Grove - Air quality sensor v1.3
For testing the Hub
×1
Blynk
Blynk
Particle Build Web IDE
Story
Read more
Schematics
WiSor schematic
The Schematic diagram for WiSor.
Code
The Particle Build code
C/C++
The Code for WiSor
#include <Adafruit_DHT.h>
#include "Adafruit_DHT/Adafruit_DHT.h"
#include "SPI.h"
#include "blynk.h"
#include "MQ135.h"
// DHT parameters
#define DHTPIN 1
#define DHTTYPE DHT11
#define BLYNK_PRINT Serial
// Variables
int temperature;
int humidity;
int boardLed = D7;
int number = 0;
int state = 0;
MQ135 gasSensor = MQ135(2);
float rzero = gasSensor.getRZero();
int ppm = gasSensor.getPPM();
// DHT sensor
DHT dht(DHTPIN, DHTTYPE);
char auth[] = "your authentication code";
    pinMode(boardLed,OUTPUT); // Our on-board LED is output as well
    Serial.begin(9600);
    Blynk.begin(auth);
    // Start DHT sensor
    dht.begin();
    Blynk.run();
    int co2_ppm = gasSensor.getPPM();
    int ppm = co2_ppm / 4;
    digitalWrite(boardLed,HIGH); //indicator LED on WiSor turns on
     // Humidity measurement
    temperature = dht.getTempCelcius();
    humidity = dht.getHumidity();
     //virtual pin 1 will be the temperature
  Blynk.virtualWrite(V1, temperature);
   //virtual pin 2 will be the Humidity
  Blynk.virtualWrite(V2, humidity);
    //virtual pin 3 will be the ppm value of CO2 gas
  Blynk.virtualWrite(V3, co2_ppm);
    //virtual pin 4 will be the final ppm value
  Blynk.virtualWrite(V4, ppm);
    //virtual pin 5 will be the temperature
  Blynk.virtualWrite(V5, int(rzero));
Credits
Dhairya Parikh
Dhairya Parikh
11 projects • 33 followers
An open source lover who loves to help and be helped from the community :). Machine Learning and IoT Enthusiast. Arduino lover.
Comments
Add projectSign up / Login
