Geeve George
Published © MIT
WEAR : One Click Smart Women Safety Wearable Button
WEAR is an open source low cost smart wearable device to ensure safety of women by giving the caregivers security alerts.
AdvancedFull instructions provided4,091
Things used in this project
Hardware components
LinkIt ONE
MediaTek Labs LinkIt ONE
×1
Grove Starter Kit for LinkIt ONE
Seeed Grove Starter Kit for LinkIt ONE
×1
Breadboard (generic)
×1
Resistor 10k ohm
Resistor 10k ohm
×1
Pushbutton switch 12mm
SparkFun Pushbutton switch 12mm
×1
Android device
Android device
×1
Arduino IDE
Arduino IDE
MIT App Inventor
AWS Cognito
Amazon Web Services AWS Cognito
AWS IoT
Amazon Web Services AWS IoT
Story
Read more
Custom parts and enclosures
WEAR 3D Casing
Schematics
Amazon Web Services Account Creation
You can use the AWS for connecting the Button to the Cloud and then track the user in real time.
Aws
Materials Required
Materials%20required!
Button Circuit
Button
Code
Arduino Source Code
Arduino
 * Women Safety Wearable
 * Author : Geeve George
#include <LTask.h>
#include <LWiFi.h>
#include <LWiFiServer.h>
#include <LWiFiClient.h>
#define WIFI_AP "Your Wifi SSID"
#define WIFI_PASSWORD "Your Wifi Password"
#define WIFI_AUTH LWIFI_WPA
int serverPort = 80;
LWiFiServer server(serverPort);
int LED = 13;
#include <Wire.h>
#include <rgb_lcd.h>
#include <LGPS.h>
gpsSentenceInfoStruct info;
char buff[256];
rgb_lcd lcd;
int ButtonPin = 7;
int BuzzerPin = 2;
double latitude;
double longitude;
int buttonState;
static unsigned char getComma(unsigned char num,const char *str)
  unsigned char i,j = 0;
  int len=strlen(str);
  for(i = 0;i < len;i ++)
     if(str[i] == ',')
      j++;
     if(j == num)
      return i + 1;
  return 0;
static double getDoubleNumber(const char *s)
  char buf[10];
  unsigned char i;
  double rev;
  i=getComma(1, s);
  i = i - 1;
  strncpy(buf, s, i);
  buf[i] = 0;
  rev=atof(buf);
  return rev;
static double getIntNumber(const char *s)
  char buf[10];
  unsigned char i;
  double rev;
  i=getComma(1, s);
  i = i - 1;
  strncpy(buf, s, i);
  buf[i] = 0;
  rev=atoi(buf);
  return rev;
void parseGPGGA(const char* GPGGAstr)
  double latitude;
  double longitude;
  int tmp, hour, minute, second, num ;
  if(GPGGAstr[0] == '$')
    tmp = getComma(1, GPGGAstr);
    hour     = (GPGGAstr[tmp + 0] - '0') * 10 + (GPGGAstr[tmp + 1] - '0');
    minute   = (GPGGAstr[tmp + 2] - '0') * 10 + (GPGGAstr[tmp + 3] - '0');
    second    = (GPGGAstr[tmp + 4] - '0') * 10 + (GPGGAstr[tmp + 5] - '0');
    sprintf(buff, "UTC timer %2d-%2d-%2d", hour, minute, second);
    Serial.println(buff);
    tmp = getComma(2, GPGGAstr);
    latitude = getDoubleNumber(&GPGGAstr[tmp]);
    tmp = getComma(4, GPGGAstr);
    longitude = getDoubleNumber(&GPGGAstr[tmp]);
    sprintf(buff, "latitude = %10.4f, longitude = %10.4f", latitude, longitude);
    tmp = getComma(7, GPGGAstr);
    num = getIntNumber(&GPGGAstr[tmp]);
    sprintf(buff, "satellites number = %d", num);
  else
    Serial.println("Not get data");
  Serial.begin(9600);
  lcd.begin(16,2);
  LGPS.powerOn();
  Serial.println("LGPS Power on, and waiting ...");
  delay(3000);
  pinMode(ButtonPin,INPUT);
  pinMode(BuzzerPin,OUTPUT);
  pinMode(LED, OUTPUT);
  LWiFi.begin();
  // keep retrying until connected to AP
  Serial.println("Connecting to AP");
  while (0 == LWiFi.connect(WIFI_AP, LWiFiLoginInfo(WIFI_AUTH, WIFI_PASSWORD)))
    digitalWrite(LED, HIGH);
    delay(100);
    digitalWrite(LED, LOW);
    delay(100);
    delay(100);
    delay(600);
  printWifiStatus();
  Serial.println("Start Server");
  server.begin();
  Serial.println("Server Started");
int loopCount = 0;
  String str = "";
  String url = "";
  int i;
  delay(500);
  loopCount++;
  LWiFiClient client = server.available();
  if (client)
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected())
      if (client.available())
        // we basically ignores client request, but wait for HTTP request end
        char c = client.read();
        Serial.print(c);
        if(c != '\n')
          str += c;
        if(c == '\n')
          //Serial.println(str);
          if(str.startsWith("GET "))
            url = str.substring(4, str.lastIndexOf(" "));
            Serial.print("URL:");
            Serial.print(url);
            Serial.println(":");
          str = "";
        if (c == '\n' && currentLineIsBlank)
          Serial.println("send response");
          // send a standard http response header
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println();
          if(url != String("favicon.ico"))
            client.println("<!DOCTYPE HTML>");
            client.println("<html>\n<head>\n<title>LED Control</title>\n</head>");
            IPAddress ip = LWiFi.localIP();
            client.println("<body><center>");
            client.println("<form action='");
            client.println("' method='GET'>Tell your device what to do!<br><br><input type='radio' name='q' value='on'>Turn the LED on.<br><input type='radio' name='q' value='off'>Turn the LED off.<br><br><input type='submit' value='Do it!'></form>");
            //i = digitalRead(LED);
            url.toLowerCase();
            if(url == String("/?q=on"))
              lcd.clear();
              lcd.println("Lat:");
              lcd.println(latitude);
              lcd.setCursor(0,1);
              lcd.println("Lon:");
              lcd.println(longitude);
              Serial.println("http://www.latlong.net/c/?lat=");
              Serial.println(latitude);
              Serial.println("&long=");
              Serial.println(longitude);
              digitalWrite(BuzzerPin,HIGH);
              delay(2000);
              digitalWrite(BuzzerPin,LOW);
              lcd.clear();
              client.println("LED on<br>");
            else if(url == String("/?q=off"))
              client.println("LED off<br>");
              lcd.clear();
            else
              client.println("Doing nothing<br>");
              lcd.clear();
            client.println("</center></body>\n</html>");
            client.println();
            break;
        if (c == '\n')
          // you're starting a new line
        else if (c != '\r')
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(50);
    // close the connection:
    Serial.println("close connection");
    client.stop();
    Serial.println("client disconnected");
  buttonState = digitalRead(ButtonPin);
  if(buttonState == HIGH){
              lcd.clear();
              lcd.setCursor(0,1);
              Serial.println("LINK : http://www.latlong.net/c/?lat=");
    delay(2000);
    lcd.clear();
  else
    lcd.clear();
void printWifiStatus()
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(LWiFi.SSID());
  // print your WiFi shield's IP address:
  Serial.print("IP Address: ");
  Serial.println(ip);
  Serial.print("subnet mask: ");
  Serial.println(LWiFi.subnetMask());
  Serial.print("gateway IP: ");
  Serial.println(LWiFi.gatewayIP());
  // print the received signal strength:
  long rssi = LWiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
AWS Lambda Function
JavaScript
var aws = require('aws-sdk');
var sns = new aws.SNS();
exports.handler = function(event, context) {
    console.log('message log');
    var params = {
        Message: 'Women Safety Wearable Button!',
        Subject: 'Alert! Button Triggered!',
        TopicArn: 'arn:aws:sns:us-east-1:123456789:aws-iot-button-sns'
    sns.publish(params, function(err, data) {
        if (err) {
            context.fail('ERROR:Calling SNS from Lambda: ' + err)
        } else {
            console.log('Great success! JSON: ' + JSON.stringify(data, null, ' '));
            context.succeed('SUCCESS');
Credits
Geeve George
Geeve George
6 projects • 32 followers
I work on arduino, intel edison and android development for making assistive technologies for specially abled people.
Contact
Comments
Add projectSign up / Login
