Mitchell ChristenberryChad Messick
Published © GPL3+
Mail In Your Box IoT
Ever wonder if the mailman has been by the house yet? Use this IoT project to know exactly when your important package has been delivered!
IntermediateFull instructions provided6 hours14
Things used in this project
Hardware components
Photon
Particle Photon
×2
Solderless Breadboard Half Size
×2
Male/Female Jumper Wires
×3
Male/Male Jumper Wires
×4
5 mm LED: Yellow
5 mm LED: Yellow
×1
Resistor 221 ohm
Resistor 221 ohm
×1
Buzzer
Buzzer
×1
Grove - PIR Motion Sensor
Seeed Grove - PIR Motion Sensor
×1
USB-A to Micro-USB Cable
×1
Maker service
IFTTT Maker service
Google Sheets
Google Sheets
Story
Read more
Schematics
Sensor Photon Circuit
Diagram for sensor rh24ntydn5
Buzzer/LED Photon Circuit
Diagram for buzzer wd6kxv6p2m
Code
Sensor Code
C/C++
This code is used to notify the photon of a signal from the motion sensor. From this signal the photon will communicate to the other photon on the same network that they are both connected to.
int pirState = LOW;
int value = 0;
int inputpin = D0;
int calibratetime = 5000;
int mail = 1;
int LED = D7;
pinMode(inputpin, INPUT);
pinMode(D7, OUTPUT);
Particle.subscribe("got_mail",sensor, "410037000b47363330353437");
 void sensor(const char *event, const char *data){
        digitalWrite(LED, HIGH);
        digitalWrite(LED, LOW);
    if (calibrated())
    sensorread();
    reportdata();
void sensorread() {
    value = digitalRead(inputpin);
    delay(10000);
bool calibrated() {
    return millis() - calibratetime > 0;
void reportdata() {
    if (value == HIGH) {
        mail = mail;
        Particle.publish("YGM", "1");
        delay(10000);
    else if (value == LOW) {
        mail = 0;
Buzzer/LED Code
C/C++
This purpose of this code is to receive the signal from the other photon and transfer that signal to the buzzer and the LED light when the mailbox has been opened.
int Buzzer = D0;
int state = 0;
int sensor = 1;
void setup ()
    pinMode(Buzzer,OUTPUT);
    Particle.subscribe("YGM",mail, "380029000b47363330353437");
void mail(const char *YGM, const char *mail)
     Particle.publish("got_mail", String(sensor));
      digitalWrite(Buzzer,HIGH);
      digitalWrite(Buzzer,LOW);
      delay(500);
      delay(500);
Credits
0 projects • 0 followers
Chad Messick
Chad Messick
Comments
Add projectSign up / Login
