Juan Carlos
Published © MIT
Automatic control of wine store
The wine store should be a place that is constantly monitored and regularized. This automatic control of wine store solution can do that.
AdvancedWork in progress3 hours186
Things used in this project
Hardware components
SparkFun ESP8266 Thing - Dev Board
Wifi controller
×1
DHT22 Temperature Sensor
×1
Grove - Light Sensor
Seeed Grove - Light Sensor
×1
Cayenne
myDevices Cayenne
cronniot
3D Printer (generic)
Story
Read more
Schematics
Circuit map
Cava bb tugstpisqz
Code
ESP8266 firmware
C/C++
Comunicate the ESP8266 device with Cronniot IOT Service
    Cronniot_ESP8266
    Purpose: Comunicate the ESP8266 device with Cronniot IOT Service
    @author Juan Carlos Gras
    @version 1.0 07/29/17
    @licence MIT
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#define MQTT_SERVER "cronniot.com"
#define MQTT_PORT 8883
void callback(char* topic, byte* payload, unsigned int length);
typedef struct {
  String deviceId;
  uint8_t pin;
} pinDevice;
//######## Fill data ################
const char* ssid = "#############";       //wifi name
const char* password = "##############";          //wifi password
const char* controllerId = "#############";     //ESP8266 identifier
const char* secretKey = "#############";    //user secret code
const pinDevice digitPins[] {               //definition of pins to use: device Id / pin number
  {"w3mm6ajzu", 10},
  {"deviceId", 10}
WiFiClientSecure wifiClient;
PubSubClient client(MQTT_SERVER, MQTT_PORT, callback, wifiClient);
  for(uint8_t i = 0; i < sizeof(digitPins)/sizeof(pinDevice); ++i) {
      pinMode(digitPins[i].pin, OUTPUT);
      digitalWrite(digitPins[i].pin, LOW);
  delay(100);
  WiFi.begin(ssid, password); //start wifi subsystem
  reconnect();
  delay(2000);
  if (!client.connected() && WiFi.status() == 3) { reconnect(); }   //reconnect if connection is lost
  client.loop();
  delay(10);
void callback(char* topic, byte* payload, unsigned int length) {
  String msDeviceId;
  String msSecretKey;
  bool readDevice = true;
  for(int i = 2; i < length; i++) {
      if(payload[i] == '_') {
        readDevice = false;
        continue;
      if(readDevice) { msDeviceId += (char)payload[i]; }
      else { msSecretKey += (char)payload[i]; }
  char* outputQueue = new char[length + 3];
  strcpy(outputQueue, msDeviceId.c_str());
  strcat(outputQueue, "_");
  strcat(outputQueue, msSecretKey.c_str());
  strcat(outputQueue, "_out");
  if(msSecretKey != secretKey) {
    client.publish(outputQueue, "-1");                               //publish to the MQTT server an error message
    return;
  uint8_t pin = 0;
  uint8_t a = 0;
  const uint8_t arrLength = sizeof(digitPins)/sizeof(pinDevice);
  while(pin == 0 && a < arrLength) {
    if(digitPins[a].deviceId == msDeviceId) { pin = digitPins[a].pin; }
    else { a++; }
  if(pin == 0) {
    return;
  if(payload[0] == '1'){
    digitalWrite(pin, HIGH);                                        //turn the device pin 'on'
    client.publish(outputQueue, "1");                               //publish to the MQTT server a confirmation message
  else if (payload[0] == '0'){
    digitalWrite(pin, LOW);                                         //turn the device pin 'off'
    client.publish(outputQueue, "0");                               //publish to the MQTT server a confirmation message
  else if (payload[0] == 'S'){
    client.publish(outputQueue, String(digitalRead(pin)).c_str());  //publish to the MQTT server an status confirmation message
    Connect to the WIFI network and to the MQTT server
void reconnect() {
  if(WiFi.status() != WL_CONNECTED) {
    Serial.print("Connecting to ");
    Serial.println(ssid);
    while (WiFi.status() != WL_CONNECTED) {
      delay(500);
      Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
    Serial.println(WiFi.localIP());
  if(WiFi.status() == WL_CONNECTED){
    while (!client.connected()) {
      Serial.print("Attempting MQTT connection...");
      uint8_t mac[6];
      WiFi.macAddress(mac);
      if (client.connect((char*) macToStr(mac).c_str(), "#############", "#############")) {
        Serial.print("\tMTQQ Connected");
        client.subscribe(controllerId);
      else { Serial.println("\tFailed."); abort(); }
    Generate unique name from MAC address
    @param numeric array of mac address
    @return a String mac address
String macToStr(const uint8_t* mac) {
  String result;
  for (uint8_t i = 0; i < 6; ++i) {
    result += String(mac[i], 16);
    if (i < 5) { result += ':'; }
  return "esp8266-" + result;
Credits
Juan Carlos
Juan Carlos
0 projects • 0 followers
Contact
Comments
Add projectSign up / Login
