Justin_time23Logan Williams
Published © GPL3+
Particle Photon Mail Detector Fall 2018 3171
Do you ever wonder when the mail man delivers your mail? Well worry no more, we have the device for you.
Easy24 hours45
Things used in this project
Hardware components
Photon
Particle Photon
×2
Grove - PIR Motion Sensor
Seeed Grove - PIR Motion Sensor
×1
Male/Male Jumper Wires
×7
Male/Female Jumper Wires
×3
Adafruit SSD1306 OLED Display
×1
Micro-USB to USB Cable (Generic)
×1
Solderless Breadboard Half Size
×2
Particle Pi
Particle Pi
Fritzing
Maker service
IFTTT Maker service
Story
Read more
Schematics
Display Pin Diagram
Pin out for Particle Photon to OLED display
Display qniem2vuv4
PIR Motion Sensor Pin Diagram
Pin out for the PIR Sensor
Pir 6qfimmufeu
Code
Motion Detector
C/C++
// This #include statement was automatically added by the Particle IDE.
#include <Adafruit_SSD1306.h>
int PIRSensor = D0;
int led = D7;
int var=0;
int last=0;
    pinMode(led, OUTPUT);
    Particle.subscribe("LEDoff2018", myHandler, "2f0017000d47363330353437");
void myHandler(const char *event, const char *data)
    digitalWrite(led, LOW);
    var=digitalRead(PIRSensor);
    if((digitalRead(PIRSensor) == HIGH) && (last == LOW))
        digitalWrite(led, HIGH);
        String data = String(var);
        // stuff happens here
        Particle.publish("YHM2018", "motion is detected");
    last = var;
    if(digitalRead(PIRSensor) == LOW)
        last = 0;
    delay(10000);
OLED Display
C/C++
// use hardware SPI
#define OLED_DC     D3
#define OLED_CS     D4
#define OLED_RESET  D5
Adafruit_SSD1306 display(OLED_DC, OLED_RESET, OLED_CS);
//int  x, minX; // variables for scrolling code
    Particle.subscribe("YHM2018", myHandler, "2f0021000d47363330353437");
void loop() {delay(1);
void myHandler(const char *event, const char *data) {
  display.begin(SSD1306_SWITCHCAPVCC);
 display.setTextSize(2);       // text size
  display.setTextColor(WHITE); // text color
  display.clearDisplay();
  display.println("You Have");
  display.println("Mail");
  display.display();
  delay(10000);
  display.setCursor(0,0);
  display.display();
Particle.publish("LEDoff2018", "led off");
Credits
Justin_time23
Justin_time23
0 projects • 0 followers
Logan Williams
Logan Williams
Comments
Add projectSign up / Login
