Pooja Baraskar
Published © GPL3+
Alcohol Detection Using Linkit One
Let us create a simple breathalyzer with LinkIt One microcontroller.
EasyFull instructions provided694
Things used in this project
Hardware components
LinkIt ONE
MediaTek Labs LinkIt ONE
×1
Seeed Grove mq5 sensor
×1
Seeed Grove buzzer
×1
Story
Read more
Code
breathalyzer
Arduino
int buzzer = 2;
int sensor = A0;
// The setup routine runs once when you press reset
pinMode(buzzer, OUTPUT); // Initialize the digital pin2 as buzzer output
Serial.begin(9600); // Initialize serial communication at 9600 bits per second
// The loop routine runs over and over again forever
var sensorValue = analogRead(sensor); // Read the input on analog pin 0 ('sensor')
Serial.println(sensorValue); // Print out the value on serial monitor
if (sensorValue > 650)
// If sensorValue is greater than 650
digitalWrite(buzzer, HIGH); }
else {
digitalWrite(buzzer, LOW);
Credits
Pooja Baraskar
Pooja Baraskar
6 projects • 143 followers
Intel Software Innovator and developer at Geek Monkey Studios. She is a Microsoft Certified Professional and C# specialist.
Comments
Add projectSign up / Login
