Revathi Kannan
Published
Auto_Power_Controller(APC)
An IoT device to automatically switch on/off electronic appliances based on the availability of human beings, especially in public services.
IntermediateProtip6 hours2,464
Things used in this project
Hardware components
Jumper wires (generic)
×1
9V battery (generic)
×1
Resistor 221 ohm
Resistor 221 ohm
×1
Relay (generic)
×1
PIR Motion Sensor (generic)
×1
Arduino UNO & Genuino UNO
×1
Arduino IDE
Arduino IDE
Hot glue gun (generic)
Story
Read more
Schematics
APC
Apc fc auihfrphwf
Code
Python
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
Serial.begin(9600);
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
} else {
digitalWrite(ledPin, LOW); // turn LED OFF
if (pirState == HIGH){
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
Credits
Revathi Kannan
Revathi Kannan
2 projects • 10 followers
Application Developer : A| - BlockChain - Mainframes - Vision plus expertise - IBM Watson - IBM Code Challenge Winner 2018 (Top 3/India)
Comments
Add projectSign up / Login
