Meilily Li
Published
Hacking the Stairs at Seeed's New Office
Turn the stairs at the office into an interactive installation, and even a cool way to convey the message "STAFF ONLY" to visitors.
IntermediateWork in progress6 hours3,193
Things used in this project
Hardware components
Seeed Digital RGB LED Strips of 2 meters
×5
Seeeduino V4.2
×1
Seeed Grove Ultrasonic Sensor
×2
Base Shield V2
Seeed Base Shield V2
×1
LED Logo projector
×1
Seeed Breadboard Jumper Wire Pack
×1
twin-core cable of 8 meters
×1
5V power supply
×1
Arduino IDE
Arduino IDE
Hot glue gun (generic)
Soldering iron (generic)
Story
Read more
Code
HackTheStairs.ino
Arduino
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
#ifdef __AVR__
  #include <avr/power.h>
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#define PIN            5
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS   160
#include "Ultrasonic.h"
Ultrasonic ultrasonic(7);
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 500; // delay for half a second
  Serial.begin(9600);
  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#if defined (__AVR_ATtiny85__)
  if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
  // End of trinket special code
  pixels.begin(); // This initializes the NeoPixel library.
    long RangeInCentimeters;
    RangeInCentimeters = ultrasonic.MeasureInCentimeters(); // two measurements should keep an interval
    Serial.print(RangeInCentimeters);//0~400cm
    Serial.println(" cm");
    delay(1);
  if(RangeInCentimeters<150)
  // For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one.
  for(int i=0;i<NUMPIXELS;i++){
    // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
    pixels.setPixelColor(i, pixels.Color(0,60,0)); // Moderately bright green color.
    pixels.show(); // This sends the updated pixel color to the hardware.
    delay(1); // Delay for a period of time (in milliseconds).
 if(RangeInCentimeters>150)
    pixels.setPixelColor(i, pixels.Color(0,0,0)); // Moderately bright green color.
Credits
Meilily Li
Meilily Li
2 projects • 3 followers
Love all things related to creativeness.
Thanks to Bill, Seeed Technical Support Team, Jiamou Yang, Seeed Technical Support Team, Danny, Workshop Manager at Seeed x.factory, and Violet Su, Community Manager at Seeed x.factory.
Comments
Add projectSign up / Login
