Suraj GehlotDhiraj Gehlot
Published
Swarm Bots: Assembly and Co-operative Transport
Objective of the Swarm-bots project is to study controlling the bot so assemble themselves, avoid obstacle and synchronization between bots.
EasyFull instructions provided8,317
Things used in this project
Hardware components
Arduino UNO & Genuino UNO
The master and slave are two arduino based bots, which cooperate together to carry out the desired task- in our case transportation of heavy objects. The master controls the movement and actions of the slave through the RF module.
×1
1Sheeld (Android shield for Arduino)
Gamepad control application in 1sheeld is use to control master bot.
×1
nRF24 module
The communication between the master and the slave takes place through the RF module. The Master sends the desired command through the transmitter module, which is received and followed by the Slave through the receiver module attached to it.
×1
Photodiode+LED
This is the eye of the bots. Obstacle avoider helps the bots to avoid unwanted obstacles and also prevents collision against each other. It comprises of a system of photodiodes and LEDs, which are placed on the master and the slave respectively
×1
LV-MaxSonar
Ultrasonic sensors are in air, non-contact object detection and ranging sensors that detect objects within an area. These sensors are not affected by the color or other visual characteristics of the detected object. Ultrasonic sensors use high frequency sound to detect and localize objects in a variety of environments.
×1
Story
Read more
Schematics
PCB shield: Interfaced all component in pcb
All components are interfaced in one pcb
Bottom
Top
Top
Code
Swarm Transmitter
C/C++
   1 - GND
   2 - VCC 3.3V !!! NOT 5V
   3 - CE to Arduino pin 9
   4 - CSN to Arduino pin 10
   5 - SCK to Arduino pin 13
   6 - MOSI to Arduino pin 11
   7 - MISO to Arduino pin 12
   8 - UNUSED
   Analog Joystick or two 10K potentiometers:
   GND to Arduino GND
   VCC to Arduino +5V
   X Pot to Arduino A0
   Y Pot to Arduino A1
 - V1.00 11/26/13
   Based on examples at http://www.bajdi.com/
   Questions: terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <OneSheeld.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define CE_PIN   9
#define CSN_PIN 10
#define JOYSTICK_X A0
#define JOYSTICK_Y A1
int LeftMotorForward = 7; // Pin 10 has Left
int LeftMotorReverse = 6; // Pin 9 has Left Motor
int RightMotorForward = 5; // Pin 12 has Right
int RightMotorReverse = 4; // Pin 13 has Right
// NOTE: the "LL" at the end of the constant is "LongLong" type
const uint64_t pipe = 0xE8E8F0F0E1LL; // Define the transmit pipe
float Inch=0.00;
float cm=0.00;
int SonarPin=A5;
int  sensorValue;
/*-----( Declare objects )-----*/
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
/*-----( Declare Variables )-----*/
int joystick[1];  // 2 element array holding Joystick readings
void setup()   /****** SETUP: RUNS ONCE ******/
    OneSheeld.begin();
//  Serial.begin(57600  );
 pinMode(LeftMotorForward, OUTPUT); //initialize the pin as an output.
pinMode(RightMotorForward, OUTPUT); //initialize the pin as an output.
pinMode(LeftMotorReverse, OUTPUT); // initializethe pin as an output.
pinMode(RightMotorReverse, OUTPUT); //initialize the pin as an output.
    pinMode(SonarPin,INPUT);
//Serial.begin(9600);
  radio.begin();
  radio.openWritingPipe(pipe);
}//--(end setup )---
void loop()   /****** LOOP: RUNS CONSTANTLY ******/
 /* Blink the cursor and for 5 seconds. */
    sensorValue=analogRead(SonarPin);
Inch= (sensorValue*0.497);
cm=Inch*2.54;
 if(GamePad.isUpPressed())
   // forward();
   if(cm<30)
    //for(int i=0;i<1000;i++)
      joystick[0]=3;
    left();
    delay(1500);
   // Serial.println("p=0");
  else
    forward();
    joystick[0]=8;
   // Serial.println("forward");
  /* If down is pressed, move the car backwards. */
  else if (GamePad.isDownPressed())
   if(cm<30)
    left();
        joystick[0]=3;
    delay(1500);
  else
  {back();
        joystick[0]=2;
    // Serial.println("back");
  /* If right is pressed, turn the car to the right. */
  else if (GamePad.isRightPressed())
    if(cm<30)
              joystick[0]=3;
    left();
    delay(1500);
  else
            joystick[0]=6;
    right();
    /* If left is pressed, turn the car to the left. */
  else if(GamePad.isLeftPressed())
    if(cm<30)
              joystick[0]=3;
    left();
    delay(1500);
  else
            joystick[0]=3;
   left();
  /* If nothing is pressed stop all motors. */
  else
  // forward();
          joystick[0]=5;
   Stop();
 radio.write( joystick, sizeof(joystick) );
 Serial.println(joystick[0]);
//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
//NONE
//*********( THE END )***********
void forward()
digitalWrite(RightMotorForward, HIGH); // turnthe Right Motor ON
digitalWrite(LeftMotorForward, HIGH);
void back()
  digitalWrite(RightMotorReverse, HIGH); // turnthe Right Motor ON
digitalWrite(LeftMotorReverse, HIGH);
void Stop()
 digitalWrite(RightMotorForward,LOW); // turn Right Motor OFF
 digitalWrite(LeftMotorForward, LOW);
void left()
void right()
  digitalWrite(RightMotorForward,HIGH); // turn Right Motor OFF
void softright()
void softleft()
digitalWrite(RightMotorReverse,HIGH); // turn Right Motor OFF
Swarm Receiver
C/C++
/* YourDuinoStarter Example: nRF24L01 Receive Joystick values
 - WHAT IT DOES: Receives data from another transceiver with
   2 Analog values from a Joystick or 2 Potentiometers
   Displays received values on Serial Monitor
 - SEE the comments after "//" on each line below
 - CONNECTIONS: nRF24L01 Modules See:
 http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
   1 - GND
   8 - UNUSED
 - V1.00 11/26/13
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
int p = 3;
pinMode(p, INPUT);
  Serial.begin(9600);
  Serial.println("Nrf24L01 Receiver Starting");
  radio.begin();
  radio.openReadingPipe(1,pipe);
  radio.startListening();;
  if ( radio.available() )
    // Read the data payload until we've received everything
    bool done = false;
    while (!done)
      // Fetch the data payload
      done = radio.read( joystick, sizeof(joystick) );
      //Serial.println("X = ");
     /* if(joystick[0]==10)
        digitalWrite(2,HIGH);
      //Serial.print(" Y = ");
      //Serial.println(joystick[1]);*/
       if(joystick[0]==8)
     forward();
  if(digitalRead(p)==0)
  left();
  else if (joystick[0]==2)
   back();
  else if (joystick[0]==6)
    right();
  else if(joystick[0]==4)
   left();
  else if (joystick[0]==3)
   left();
  else
  // forward();
   Stop();
  else
      Serial.println("No radio available");
              digitalWrite(2,LOW);
}//--(end main loop )---
//NONE
void forward()
void back()
void Stop()
void left()
void right()
void softright()
void softleft()
Credits
Suraj Gehlot
Suraj Gehlot
1 project • 4 followers
Dhiraj Gehlot
Dhiraj Gehlot
2 projects • 12 followers
I'm an Electronics Engineer A innovator/ tinkerer/ Maker/ Sketch artist?Guitarist/ Cube crazy.
Comments
Add projectSign up / Login
