Rishabh BangaPriyanka Jain
Published © CC BY-NC-ND
Air Quality System using LinkIt ONE and MCS
Monitor the Temperature, Humidity, Pressure, Air Quality, Dust particle concentration online & even detect Fire using LinkIt ONE & Sensors.
AdvancedShowcase (no instructions)2,698
Things used in this project
Hardware components
LinkIt ONE
MediaTek Labs LinkIt ONE
×1
Grove Starter Kit for LinkIt ONE
Seeed Grove Starter Kit for LinkIt ONE
Barometer Sensor, Dust Sensor, and Temperature and Humidity Sensor Pro. Air Quality Sensor I had lying around and is not a part of this kit.
×1
Arduino IDE
Arduino IDE
LinkIT ONE SDK for Arduino
Story
Read more
Schematics
Final Setup
Shows the final setup of sensors and WiFi Antenna
Finale
Final Setup
Shows complete setup of sensors and WiFi Antenna
Finale
Code
WiFi Connection
Arduino
Skeleton code for connecting to WiFi. Replace WiFi SSD & Key, Device ID & Key with your own.
#include <LTask.h>
#include <LWifi.h>
#include <LWiFiClient.h>
#include <HttpClient.h>
#include <LDateTime.h>
#define WIFI_AP "" //WiFi SSID
#define WIFI_PASSWORD "" //WiFi Key
#define WIFI_AUTH LWIFI_WPA2 //Authentication Mode
#define per 50
#define per1 3
#define DEVICEID "" // Device ID given by cloud sandbox
#define DEVICEKEY "" //Device key given by cloud sandbox
#define SITE_URL "api.mediatek.com" //the site of the API
LWiFiClient c; //wifi client
LWiFiClient c2;
HttpClient http(c2); //http client
unsigned int rtc; //real-time clock
unsigned int lrtc;
unsigned int rtc1;
unsigned int lrtc1;
char port[4]="   ";
char connection_info[21]="                    ";
char ip[21]="              ";
int portnum;
int val = 0;
String tcpdata = String(DEVICEID) + "," + String(DEVICEKEY) + ",0";
String TCPCMD_LED_ON = "LED_controller,1"; //tcp command to controll LED ON/OFF
String TCPCMD_LED_OFF = "LED_controller,0";
  //initialize
  LTask.begin();
  LWiFi.begin();
  Serial.println("Connecting to AP");
  while (0 == LWiFi.connect(WIFI_AP, LWiFiLoginInfo(WIFI_AUTH, WIFI_PASSWORD)))
  Serial.println("WiFi succeed");
  Serial.println("calling connection");
  while (!c2.connect(SITE_URL, 80))
  Serial.println("Connection to site succeed");
  getconnectInfo();
  Serial.println("getConnectionInfo succeed");
  connectTCP();
  Serial.println("connectTCP() succeed");
Grove Kit - Barometer and RGB LCD
Arduino
Code for connecting and pushing sensor data to cloud. Since the process is more or less the same for each sensor, I'd be explaining only two in this instance.
#include <Wire.h> //include wire library to enable Grove
#include <Barometer.h> //include library of Barometer sensor
#include <rgb_lcd.h>
Barometer myBarometer;
float humidity;
float temperature;
float pressure;
float atm;
float altitude;
Int colorR = 255;
Int colorG = 255;
Int colorB = 0;
  myBarometer.init();
  pinMode(13, OUTPUT);
  lcd.begin(16, 2);
  lcd.setRGB(colorR, color G, colorB)
  int val = analogRead(pinTemp);
  float r = (float) (1023-val)*10000/val;
  humidity = 1/ (log(r/10000)/b+1/298.15);
  pressure = myBarometer.bmp085GetPressure(myBarometer.bmp085ReadUP());
  altitude = myBarometer.calcAltitude(pressure);  //calculate the ideal altitude
  //  atm = pressure / 101325;
  //print some information on serial monitor
  temperature = myBarometer.bmp085GetTemperature(myBarometer.bmp085ReadUT());
  if (temperature < 25)
    colorR=0;
    colorG=0;
    colorB=255;
    lcd.setRGB(colorR, colorG, colorB);
    lcd.print("It's cool at: ");
    lcd.print(temperature);
  else
    colorR=255;
    colorG=0;
    colorB=0;
    lcd.print("It's hot at: ");
void uploadstatus(){
  //Uploading datapoint to MCS(Meditek Cloud Sandbox)
  LWiFiClient c2;
  char bufferH[5];
  char bufferT[5];
  char bufferA[7];
  char bufferP[7];
  sprintf(bufferH, "%.2f", humidity);
  sprintf(bufferT, "%.2f", temperature);
  sprintf(bufferA, "%.2f", altitude);
  sprintf(bufferP, "%.0f", pressure);
  String uploadHumidity = "humidity_display,," + String(bufferH);
  String uploadTemperature = "temperature_display,," + String(bufferT);
  String uploadAltitude = "altitude_display,," + String(bufferA);
  String uploadPressure = "pressure_display,," + String(bufferP);
    Serial.println("Re-Connecting to WebSite");
  delay(100);
  if(digitalRead(13)==1)
    uploadLED = "LED_display,,1";
  else
    uploadLED = "LED_display,,0";
  String uploadData = uploadHumidity + "\n" +
                      uploadTemperature + "\n" +
                      uploadAltitude + "\n" +
                      uploadPressure;
  c2.print("POST /mcs/v2/devices/");
  c2.print(DEVICEID);
  c2.println("/datapoints.csv HTTP/1.1");
  c2.print("Host: ");
  c2.println(SITE_URL);
  c2.print("deviceKey: ");
  c2.println(DEVICEKEY);
  c2.println("Content-Type: text/csv");
  c2.println("Connection: close");
  c2.println();
  c2.println(uploadData);
  //upload the data
  delay(500);
  int errorcount = 0;
  while (!c2.available())
    Serial.print("waiting HTTP response: ");
    Serial.println(errorcount);
    errorcount += 1;
    if (errorcount > 10)
      c2.stop();
      Serial.println("uploadStatus failed");
      return;
    delay(100);
Credits
Rishabh Banga
Rishabh Banga
11 projects • 115 followers
Intel Software Innovator | Microsoft Certified Professional | IoT Evangelist
Contact
Priyanka Jain
Priyanka Jain
2 projects • 6 followers
Contact
Comments
Add projectSign up / Login
