Vijay Raghav VaradaHanoz Patel
Published © CERN-OHL
Dual Axial Flux Generator & Wind Turbine
A highly efficient and compact generator that can be coupled with wind turbines or water wheels to produce upwards of 50V.
AdvancedShowcase (no instructions)3 days3,924
Things used in this project
Hardware components
40X20X5 mm N52 Grade Neodymium Magnet
×1
30 AWG Enamel insulated Copper Wire
×1
LM2596 2A Buck Step-down Power Converter Module
×1
M4 Threaded Rod, 250 mm
×1
1.2mm Mild Steel Sheet, 200x400mm
×1
25A 50V Bridge Rectifier
×1
M6x25 Fastners
×4
8mm Rod, 20cm long
×1
608ZZ bearings
×1
Fusion 360
Autodesk Fusion 360
3D Printer (generic)
Hand Drill, Cordless preferably
Story
Read more
Custom parts and enclosures
Coil Winding Jig Holder
The holder for the winding Jig
Rotor/Magnet Holder
The rotor of the turbine, print two
Generator Gear
Gear to be placed on the generator for coupling to wind turbine
Coil Winding Jig
The coil winding Jig Itself
Central Coil holder (Stator)
3DP could mounts/ stator for the generator
Generator Casing Part B
Mirror of part A, to complete the generator casing
Generator Casing Part A
Part of the generator Casing
Brace for the rotor
Brace that mounts on the rotor, preventing the strong magnets from collapsing on each other. Print two of these
Bearing holder/Generator casing cover
These cover the generator on the top and bottom, and house bearings that keep the central shaft inline
Lenz 2 wind gear turbine attachement
Gear to couple generator with Wind Turbine
Credits
Vijay Raghav Varada
Vijay Raghav Varada
1 project • 2 followers
Hanoz Patel
Hanoz Patel
0 projects • 2 followers
Comments
Add projectSign up / Login
