Keepin' It Grove-y
An easy and efficient way to wake up and keep intruders out.
IntermediateShowcase (no instructions)22
Keepin' It Grove-y
Things used in this project
Hardware components
Grove - Ultrasonic Ranger
Seeed Grove - Ultrasonic Ranger
×1
Buzzer, Piezo
Buzzer, Piezo
×1
LED (generic)
LED (generic)
×1
Energia
Texas Instruments Energia
Story
Read more
Schematics
Picture of our Project
Elec pic aaow5e1jbd
Schematic Diagram
58462658 283872722549488 8733913655382376448 n o230f4po9h
Code
Keepin' it Grove-y Code
C/C++
Final Project
Julie Street, Mayurika Gupta, Ben Firullo,
Michael Russo, Tanak Patel
Alarm system that plays music on the Piezo buzzer
and does a light show when you wave your hand over
the distance sensor. Song repeats until you wave your hand again.
Application purpose: secondary alarm.
Imagine placing it near your phone, so when you go to hit snooze
in the morning, you trigger this secondary alarm and light show
to encourage you to actually wake up.
#include "Ultrasonic.h"
#include <stdio.h>
/* Macro Define */
#define BUZZER_PIN         39      /* pin of the Piezo Buzzer */
#define ULTRASONIC_PIN    24       /* pin of the Ultrasonic Ranger */
/* Global Variables */
int length = 61;         /* the number of notes */
char notes[] = "cdececedeffedfefgegegfgaagfagcdefgaadefgabbefgabCCbafbgCgedc "; //notes in the song
int beats[] = {3,1,3,1,2,2,4,3,1,1,1,1,1,8,3,1,3,1,2,2,4,3,1,1,1,1,1,8,3,1,1,1,1,1,8,3,1,1,1,1,1,8,3,1,1,1,1,1,6,1,1,2,2,2,2,2,2,2,2,8,4}; //length of each note
int tempo = 100; // speed of song. Lower number = faster
int toggle = 0;
int distance = 0; // distance reading from ultrasonic ranger
Ultrasonic ultrasonic(ULTRASONIC_PIN);    /* Ultrasonic Ranger object */
/*pin setup*/
  pinMode(BUZZER_PIN, OUTPUT);
  pinMode(25, OUTPUT);
  pinMode(26, OUTPUT);
  pinMode(27, OUTPUT);
  pinMode(28, OUTPUT);
  pinMode(29, OUTPUT);
  pinMode(5, OUTPUT);
//main loop
    distance = ultrasonic.MeasureInCentimeters(); /* read the value from the sensor */
  //check distance
  if(distance < 20 and distance > 3 )
      music();
/* play tone */
void playTone(int tone, int duration)
  for (long i = 0; i < duration * 1000L; i += tone * 2)
    digitalWrite(BUZZER_PIN, HIGH);
    delayMicroseconds(tone);
    digitalWrite(BUZZER_PIN, LOW);
char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' };
int tones[] = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 956 };
//play note
void playNote(char note, int duration)
  // play the tone corresponding to the note name
  for (int i = 0; i < 8; i++)
    //if names at current index equals given note, play tone
    if (names[i] == note)
      playTone(tones[i], duration);
/*notes of Do-Re-Mi*/
void music() {
  int pins[] = {25, 26, 27, 28, 29, 5, 25, 26, 27, 28, 29, 5, 25, 26, 27, 28, 29, 5, 25, 26, 27, 28, 29, 5, 25, 26, 27, 28, 29, 5, 25, 26, 27, 28, 29, 5, 25, 26, 27, 28, 29, 5, 25, 26, 27, 28, 29, 5, 25, 26, 27, 28, 29, 5, 25, 26, 27, 28, 29, 5, 25, 26, 27, 28, 29, 5, 25, 26, 27, 28, 29, 5};
  //Loop through each note
  for(int i = 0; i < length; i++)
    //space indicates a pause
    if(notes[i] == ' ')
      delay(beats[i] * tempo);
    else
      playNote(notes[i], beats[i] * tempo);
      digitalWrite(pins[i], HIGH);
    delay(tempo / 2);    /* delay between notes */
    digitalWrite(pins[i], LOW);
Credits
Mayurika Gupta
Mayurika Gupta
0 projects • 0 followers
Ben Firullo
Ben Firullo
Tanak Patel
Tanak Patel
Julie
Julie
Michael (Thomas) Russo
Comments
Add projectSign up / Login
