Green Roof Monitoring
This is a simple system which keeps watching over your vegetalized roof.
IntermediateFull instructions provided5 days35
Things used in this project
Hardware components
DHT22 Temperature Sensor
×1
ST STM32L4, STM32F7 NUCLEO-L432KC - Carte de développement
×1
Cellule solaire
×1
Batterie Li-Ion 3,7V 1050 mAh
×1
Module Sigfox Wisol
×1
Breadboard (generic)
×1
DS18B20 Programmable Resolution 1-Wire Digital Thermometer
Maxim Integrated DS18B20 Programmable Resolution 1-Wire Digital Thermometer
×1
Seeed Power adapter Module (LiPo Rider Pro)
×1
Female Header 8 Position 1 Row (0.1")
×5
Male-Header 36 Position 1 Row- Long (0.1")
×1
Vishay Triode BS250
×2
Adafruit Color Sensor ADA1334
×1
Step-Up/Step-Down Voltage Regulator
×1
Adafruit Light Sensor ADA1384
×1
Through Hole Resistor, 1.5 kohm
×4
Soil moisture sensor SEN0193
×1
Through Hole Resistor, 68 kohm
×1
Capacitor 47 µF
Capacitor 47 µF
×2
Through Hole Resistor, 1.8 kohm
×1
Sigfox
Sigfox
Ubidots
Ubidots
Mbed Studio
Arm Mbed Mbed Studio
KiCad
KiCad
Soldering iron (generic)
Premium Female/Male Extension Jumper Wires, 40 x 6" (150mm)
Solder Wire, Lead Free
Wire Stripper & Cutter, 26-14 AWG Solid & Stranded Wires
Story
Read more
Schematics
Supply schematic
The schematic of the power supply board
Supply PCB
The PCB of the power supply board.
NUCLEO card schematic
The schematic of the principal card that contains the NUCLEO card, the sensors and the Sigfox module
NUCLEO card PCB
The PCB of the principal card
Mapping
This is how we have connected our cables and wires.
Photo of System
This is a photo of our system.
Code
main.cpp
C/C++
The main program of project.
#include"mbed.h"
#include"DS1820.h"
#include"DHT.h"
#include "TCS34725.h"
#include "Sigfox.h"
#include "WakeUp.h"
#include <math.h>
#define LOG_RANGE           5.0f
float Temp_Sol;
float Temp_Air;
float Humi_Air;
float Humi_Sol;
float Lumiere;
uint16_t r;
uint16_t g;
uint16_t b;
uint16_t c;
DHT dht22(D6,DHT22);//pin,type
DS1820  ds1820(A0);//pin
TCS34725 tcs34725(D12, A6); //I2C sda and scl
AnalogIn humigrove(A1);
AnalogIn lumiere(A2);
AnalogIn bat(A4);
DigitalOut ledTest(LED1);
DigitalOut mos(D9);
u8 readBat() {
    float tmp;
    tmp = 7.0f*(float)bat - 3.3f;
    if(tmp > 1)
        tmp = 1;
    else if(tmp < 0)
        tmp = 0;
    return (u8)(tmp * 255);
void ReadTempHumiAir(){
  int err=1;
  while(err!=0){
    err=dht22.readData();
    ledTest = 1;
    wait(1);
  if(err==0){
     Temp_Air= dht22.ReadTemperature(CELCIUS);
     Humi_Air=dht22.ReadHumidity();
     ledTest = 0;
void ReadTempSol(){
  if (ds1820.begin()) {
        ds1820.startConversion();   // start temperature conversion from analog to digital
        wait(1);                  // let DS1820 complete the temperature conversion
        Temp_Sol = ds1820.read();
        Temp_Sol = Temp_Sol - (-0.06923*Temp_Sol + 7.621);
void ReadRGBC(){
    if(tcs34725.init(TCS34725_INTEGRATIONTIME_101MS, TCS34725_GAIN_60X)){
        ledTest = 1;
        wait(1);
        ledTest = 0;
         tcs34725.getColor(r,g,b,c);
         r/=256;
         g/=256;
         b/=256;
         c/=256;
void ReadHumiSol(){
    float grove_moist=humigrove.read();
    Humi_Sol= -252.2*(float)grove_moist + 196.7;
    if(Humi_Sol < 0)    Humi_Sol = 0;
    if(Humi_Sol > 100)    Humi_Sol = 100;
void ReadLumi(){
    float raw=lumiere.read();
    float loglux=2*raw*LOG_RANGE;
    Lumiere=(float)(pow(10,loglux)*65535.0f)/100000.0f;
    Lumiere = 1.64 * (float)Lumiere + 119.0f;
int main(){
    Sigfox sigfox(D1,D0);
    WakeUp::calibrate();
    ReadRGBC();
    wait(5);
    while(1){
        WakeUp::set(1200);
        mos = 0;
        sigfox.wake();
        wait(2);
        ReadTempHumiAir();
        ReadTempSol();
        ReadRGBC();
        ReadHumiSol();
        wait(1);
        ReadLumi();
        wait(1);
        //printf("R:%d, G:%d, B:%d\n\r", r, g, b);
        sigfox.send((s16)(Temp_Air*10),(u16)(Humi_Air*10),(s16)(Temp_Sol*10),(u8)Humi_Sol,
            (u8)Lumiere,(u8)r,(u8)g,(u8)b, readBat());
        wait(5);
        mos = 1;
        sigfox.sleep();
        deepsleep();
sigfox.cpp
C/C++
The sigfox class
#include "Sigfox.h"
Sigfox::Sigfox(PinName tx, PinName rx): Serial(tx, rx) {
  * @brief  Tester si le module sigfox est pret
  * @param
  * @retval 1 si OK, 0 sinon
bool Sigfox::ready() {
    printf("AT");
    char c = getc();
    if(c == 'O')
        return 1;
    else
        return 0;
  * @brief  Envoyer les parametres recuperees par les capteurs
  * @param  Les valeurs detectees par les capteurs
  * @retval
void Sigfox::send(s16 temp_air, u16 hum_air, s16 temp_sol, u8 hum_sol, u16 lum, u8 val_r, u8 val_g, u8 val_b, u8 bat) {
    uint16_t temp1, temp2;
    uint32_t tmp;
    temp1 = temp_air + 200;
    temp2 = temp_sol + 200;
    tmp = temp1 | (temp2<<10) | (hum_air<<20);
    printf("AT$SF=%08x%02x%04x%02x%02x%02x%02x\r", tmp, hum_sol, lum, val_r, val_g, val_b, bat);
void Sigfox::sleep() {
    printf("AT$P=1\r");
void Sigfox::wake() {
    printf("AT$P=0\r");
sigfox.h
C/C++
The sigfox class
#ifndef SIGFOX_H
#define SIGFOX_H
#include "mbed.h"
typedef uint8_t     u8;
typedef uint16_t    u16;
typedef int16_t     s16;
class Sigfox: public Serial{
    public:
        Sigfox(PinName tx, PinName rx);
        * @param
        bool ready();
        * @retval
        void send(s16 temp_air, u16 hum_air, s16 temp_sol, u8 hum_sol, u16 lum, u8 val_r, u8 val_g, u8 val_b,u8 bat);
        // Sleep mode
        void sleep();
        // Wake up
        void wake();
#endif
Credits
包慧灵
包慧灵
0 projects • 0 followers
刘颖姗
刘颖姗
Diego Moreno Villanueva
Yuxiao ZHANG
Yuxiao ZHANG
Comments
Add projectSign up / Login
