Arbaz KhanShubham DevkarHarsh Patel
Published © GPL3+
Flight Computer developed by STAR for High Powered Rockets
Go high and land safely.
ExpertShowcase (no instructions)3 days135
Things used in this project
Hardware components
Arduino Nano R3
Arduino Nano R3
×1
Grove - Barometer Sensor (BMP280)
Seeed Grove - Barometer Sensor (BMP280)
×1
Power MOSFET N-Channel
×1
Li-Ion Battery 1000mAh
×1
9V battery (generic)
×1
Micro SD card module
×1
Terminal Block Interface, Terminal Block
×3
Custom PCB
Custom PCB
×1
Female Header 8 Position 1 Row (0.1")
×4
Slide Switch
Slide Switch
×1
Arduino IDE
Arduino IDE
Autodesk -Eagle
Soldering iron (generic)
Solder Wire, Lead Free
Solder Flux, Soldering
Desoldering Pump, Deluxe SOLDAPULLT®
Wire Stripper & Cutter, 18-10 AWG / 0.75-4mm² Capacity Wires
Cable Cutter, 143mm
Cable Cutter, 143mm
Drill / Driver, 20V
Drill / Driver, 20V
Story
Read more
Schematics
Schematic
Board file
Credits
Arbaz Khan
Arbaz Khan
7 projects • 0 followers
CTO of STAR (Space Technology and Aeronautical Rocketry) Experienced CTO with a demonstrated history of working in Rocket technology.
Shubham Devkar
Shubham Devkar
10 projects • 8 followers
Experienced Electronics engineer, excellent at PCB Designing, control circuit development.circuit designing, hands-on experience with MCUs
Harsh Patel
Harsh Patel
2 projects • 1 follower
Worked on High powered rockets, CanSat/CubeSat and Robotics. Student of electronics and communication.
Comments
Add projectSign up / Login
