houda lahlouKenzi Sarra
Published © GPL3+
Polytech's Energy Monitoring System
Measure, monitor and predict energy consumption
IntermediateFull instructions providedOver 1 day16
Things used in this project
Hardware components
Grove - Electricity Sensor
Seeed Grove - Electricity Sensor
×1
The Things Uno
The Things Network The Things Uno
×1
LoRa LoRaWAN Gateway
Seeed LoRa LoRaWAN Gateway
×1
The Things Network
The Things Network
Anaconda
Arduino IDE
Arduino IDE
Story
Read more
Schematics
Wiring schema
Code
Puissance
Arduino
Read, process and send data to the gateway
#include <TheThingsNetwork.h>
#include <CayenneLPP.h>
// Set your AppEUI and AppKey
const char *appEui = "70B3D57ED002A483";
const char *appKey = "C6FE88C86D54E5EB145529E0B47301E5";
#define loraSerial Serial1
#define debugSerial Serial
// Replace REPLACE_ME with TTN_FP_EU868 or TTN_FP_US915
#define freqPlan TTN_FP_EU868
TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan);
CayenneLPP lpp(51);
// Variables globales pour stocker les anciennes valeurs
int valeur1 = 0;
int valeur2 = 0;
int valeur3 = 0;
//Variable global pour grer le dlai d'envoi des donnes
int compteur=0;
  loraSerial.begin(57600);
  debugSerial.begin(9600);
  // Wait a maximum of 10s for Serial Monitor
  while (!debugSerial && millis() < 10000)
  debugSerial.println("-- STATUS");
  ttn.showStatus();
  debugSerial.println("-- JOIN");
  ttn.join(appEui, appKey);
CayenneLPP lpp(51);
  int valeur11 = analogRead(A0);
  int valeur21 = analogRead(A1);
  int valeur31 = analogRead(A2);
  valeur1 = max(valeur11,valeur1);
  valeur2 = max(valeur21,valeur2);
  valeur3 = max(valeur31,valeur3);
  compteur += 1;
// 1s = 1000ms
if(compteur == 1000) {
  float courant1 = valeur1 *30.3* (5.0 / 1023.0) * sqrt(2);  //30.3 (pour100A on a 3.3 V )
  float courant2 = valeur2 * 30.3 * (5.0 / 1023.0) * sqrt(2) ; //racine de deux *valeur efficace du courant ( signal sinus) =Imax
  float courant3 = valeur3 * 30.3 *(5.0 / 1023.0) * sqrt(2) ;
  float puissance1 = 240* (courant1);
  float puissance2 = 240* (courant2);
  float puissance3 = 240* (courant3);
  float puissance4 = puissance1+puissance2+puissance3;
  lpp.addAnalogInput(4,puissance4);
//Send it off
 ttn.sendBytes(lpp.getBuffer(), lpp.getSize());
  compteur = 0;
  valeur1 = 0;
  valeur2 = 0;
  valeur3 = 0;
  delay(1);
Power Prediction
Python
Build a Machine Learning Model that prdict Power consumption
 "cells": [
   "cell_type": "markdown",
   "metadata": {},
   "source": [
    "Importation des librairies"
   "cell_type": "code",
   "execution_count": 52,
   "metadata": {},
   "outputs": [],
   "source": [
    "import pandas as pd\n",
    "import numpy as np\n",
    "import matplotlib.pyplot as plt\n",
    "from sklearn import linear_model\n",
    "import warnings\n",
    "warnings.filterwarnings('ignore')\n",
    "warnings.simplefilter('ignore')"
   "metadata": {},
   "source": [
    "Importation des donnes"
   "execution_count": 53,
   "metadata": {},
   "outputs": [],
   "source": [
    "data = pd.read_csv(\"../Puissance.csv\")"
   "metadata": {},
   "source": [
    "Analyse des donnes"
   "execution_count": 54,
   "metadata": {},
   "outputs": [
     "data": {
      "text/html": [
       "<div>\n",
       "<style scoped>\n",
       "    .dataframe tbody tr th:only-of-type {\n",
       "        vertical-align: middle;\n",
       "    }\n",
       "\n",
       "    .dataframe tbody tr th {\n",
       "        vertical-align: top;\n",
       "    }\n",
       "\n",
       "    .dataframe thead th {\n",
       "        text-align: right;\n",
       "    }\n",
       "</style>\n",
       "<table border=\"1\" class=\"dataframe\">\n",
       "  <thead>\n",
       "    <tr style=\"text-align: right;\">\n",
       "      <th></th>\n",
       "      <th>DateHeure</th>\n",
       "      <th>Puissance</th>\n",
       "    </tr>\n",
       "  </thead>\n",
       "  <tbody>\n",
       "    <tr>\n",
       "      <th>0</th>\n",
       "      <td>01/04/2020 13:01:29</td>\n",
       "      <td>1562.445517</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>1</th>\n",
       "      <td>01/04/2020 13:31:29</td>\n",
       "      <td>2181.738667</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>2</th>\n",
       "      <td>01/04/2020 14:01:29</td>\n",
       "      <td>2752.225827</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>3</th>\n",
       "      <td>01/04/2020 14:31:29</td>\n",
       "      <td>2003.979045</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>4</th>\n",
       "      <td>01/04/2020 15:01:29</td>\n",
       "      <td>2348.234105</td>\n",
       "    </tr>\n",
       "  </tbody>\n",
       "</table>\n",
       "</div>"
      "text/plain": [
       "             DateHeure    Puissance\n",
       "0  01/04/2020 13:01:29  1562.445517\n",
       "1  01/04/2020 13:31:29  2181.738667\n",
       "2  01/04/2020 14:01:29  2752.225827\n",
       "3  01/04/2020 14:31:29  2003.979045\n",
       "4  01/04/2020 15:01:29  2348.234105"
     "metadata": {},
     "output_type": "execute_result"
   "source": [
    "data.head()"
   "execution_count": 55,
   "metadata": {},
   "outputs": [
     "data": {
      "text/plain": [
       "(10000, 2)"
     "metadata": {},
   "source": [
    "data.shape"
   "execution_count": 56,
   "metadata": {},
   "outputs": [],
   "source": [
    "data['DateHeure'] = pd.to_datetime(data['DateHeure'], dayfirst = True)"
   "execution_count": 57,
   "metadata": {},
   "outputs": [
     "data": {
      "text/plain": [
       "DateHeure    datetime64[ns]\n",
       "Puissance           float64\n",
       "dtype: object"
     "metadata": {},
   "source": [
    "data.dtypes"
   "execution_count": 58,
   "metadata": {},
   "outputs": [
     "data": {
      "text/html": [
       "<div>\n",
       "<style scoped>\n",
       "    }\n",
       "\n",
       "    }\n",
       "\n",
       "    }\n",
       "</style>\n",
       "  <thead>\n",
       "      <th></th>\n",
       "    </tr>\n",
       "  </thead>\n",
       "  <tbody>\n",
       "    <tr>\n",
       "      <th>count</th>\n",
       "      <td>10000</td>\n",
       "      <td>10000.000000</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>unique</th>\n",
       "      <td>NaN</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>top</th>\n",
       "      <td>2020-06-07 05:31:29</td>\n",
       "      <td>NaN</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>freq</th>\n",
       "      <td>1</td>\n",
       "      <td>NaN</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>first</th>\n",
       "      <td>2020-04-01 13:01:29</td>\n",
       "      <td>NaN</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>last</th>\n",
       "      <td>2020-10-26 20:31:29</td>\n",
       "      <td>NaN</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>mean</th>\n",
       "      <td>NaN</td>\n",
       "      <td>592.929413</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>std</th>\n",
       "      <td>NaN</td>\n",
       "      <td>884.358110</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>min</th>\n",
       "      <td>NaN</td>\n",
       "      <td>100.022437</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>25%</th>\n",
       "      <td>NaN</td>\n",
       "      <td>131.662871</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>50%</th>\n",
       "      <td>NaN</td>\n",
       "      <td>163.118110</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>75%</th>\n",
       "      <td>NaN</td>\n",
       "      <td>194.904384</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>max</th>\n",
       "      <td>NaN</td>\n",
       "      <td>2998.318641</td>\n",
       "    </tr>\n",
       "  </tbody>\n",
       "</table>\n",
       "</div>"
      "text/plain": [
       "count                 10000  10000.000000\n",
       "unique                10000           NaN\n",
       "top     2020-06-07 05:31:29           NaN\n",
       "freq                      1           NaN\n",
       "first   2020-04-01 13:01:29           NaN\n",
       "last    2020-10-26 20:31:29           NaN\n",
       "mean                    NaN    592.929413\n",
       "std                     NaN    884.358110\n",
       "min                     NaN    100.022437\n",
       "25%                     NaN    131.662871\n",
       "50%                     NaN    163.118110\n",
       "75%                     NaN    194.904384\n",
       "max                     NaN   2998.318641"
     "metadata": {},
   "source": [
    "data.describe(include='all')"
   "metadata": {},
   "source": [
    "Enrichissement des donnes"
   "execution_count": 59,
   "metadata": {},
   "outputs": [],
   "source": [
    "data['Jour'] = data['DateHeure'].dt.day\n",
    "data['Heure'] = data['DateHeure'].dt.hour\n",
    "data['Mois'] = data['DateHeure'].dt.month"
   "execution_count": 60,
   "metadata": {},
   "outputs": [
     "data": {
      "text/html": [
       "<div>\n",
       "<style scoped>\n",
       "    }\n",
       "\n",
       "    }\n",
       "\n",
       "    }\n",
       "</style>\n",
       "  <thead>\n",
       "      <th></th>\n",
       "      <th>Jour</th>\n",
       "      <th>Heure</th>\n",
       "      <th>Mois</th>\n",
       "    </tr>\n",
       "  </thead>\n",
       "  <tbody>\n",
       "    <tr>\n",
       "      <th>0</th>\n",
       "      <td>1</td>\n",
       "      <td>13</td>\n",
       "      <td>4</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>1</th>\n",
       "      <td>2020-04-01 13:31:29</td>\n",
       "      <td>1</td>\n",
       "      <td>13</td>\n",
       "      <td>4</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>2</th>\n",
       "      <td>2020-04-01 14:01:29</td>\n",
       "      <td>1</td>\n",
       "      <td>14</td>\n",
       "      <td>4</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>3</th>\n",
       "      <td>2020-04-01 14:31:29</td>\n",
       "      <td>1</td>\n",
       "      <td>14</td>\n",
       "      <td>4</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>4</th>\n",
       "      <td>2020-04-01 15:01:29</td>\n",
       "      <td>1</td>\n",
       "      <td>15</td>\n",
       "      <td>4</td>\n",
       "    </tr>\n",
       "  </tbody>\n",
       "</table>\n",
       "</div>"
      "text/plain": [
       "            DateHeure    Puissance  Jour  Heure  Mois\n",
       "0 2020-04-01 13:01:29  1562.445517     1     13     4\n",
       "1 2020-04-01 13:31:29  2181.738667     1     13     4\n",
       "2 2020-04-01 14:01:29  2752.225827     1     14     4\n",
       "3 2020-04-01 14:31:29  2003.979045     1     14     4\n",
       "4 2020-04-01 15:01:29  2348.234105     1     15     4"
     "metadata": {},
   "source": [
    "data.head()"
   "execution_count": 61,
   "metadata": {},
   "outputs": [
     "data": {
      "text/plain": [
       "<matplotlib.axes._subplots.AxesSubplot at 0x1e41b72b9b0>"
     "metadata": {},
     "data": {
      "image/png": "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\n",
      "text/plain": [
       "<Figure size 432x288 with 1 Axes>"
     "metadata": {
      "needs_background": "light"
     "output_type": "display_data"
   "source": [
    "data1 = data.head(100)\n",
    "data1.plot.scatter('Heure','Puissance')"
   "execution_count": 62,
   "metadata": {},
   "outputs": [
     "data": {
      "text/plain": [
       "<matplotlib.axes._subplots.AxesSubplot at 0x1e41b5afa58>"
     "metadata": {},
     "data": {
      "image/png": "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\n",
      "text/plain": [
     "metadata": {
   "source": [
    "data.plot('Mois','Puissance')"
   "execution_count": 63,
   "metadata": {},
   "outputs": [],
   "source": [
    "data['HeureEtude'] = np.zeros(data.shape[0])\n",
    "data['MoisEtude'] = np.zeros(data.shape[0])"
   "execution_count": 64,
   "metadata": {},
   "outputs": [],
   "source": [
    "for i in range(1,7):\n",
    "    data['MoisEtude'][data['Mois'] == i]=1\n",
    "for i in range(9,13):\n",
    "for i in range (8,20):\n",
    "    data['HeureEtude'][data['Heure'] == i]=1"
   "execution_count": 65,
   "metadata": {},
   "outputs": [
     "data": {
      "text/html": [
       "<div>\n",
       "<style scoped>\n",
       "    }\n",
       "\n",
       "    }\n",
       "\n",
       "    }\n",
       "</style>\n",
       "  <thead>\n",
       "      <th></th>\n",
       "      <th>Jour</th>\n",
       "      <th>Mois</th>\n",
       "      <th>HeureEtude</th>\n",
       "      <th>MoisEtude</th>\n",
       "    </tr>\n",
       "  </thead>\n",
       "  <tbody>\n",
       "    <tr>\n",
       "      <th>0</th>\n",
       "      <td>1</td>\n",
       "      <td>13</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>1</th>\n",
       "      <td>1</td>\n",
       "      <td>13</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>2</th>\n",
       "      <td>1</td>\n",
       "      <td>14</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>3</th>\n",
       "      <td>1</td>\n",
       "      <td>14</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>4</th>\n",
       "      <td>1</td>\n",
       "      <td>15</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>5</th>\n",
       "      <td>2020-04-01 15:31:29</td>\n",
       "      <td>1502.650369</td>\n",
       "      <td>1</td>\n",
       "      <td>15</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>6</th>\n",
       "      <td>2020-04-01 16:01:29</td>\n",
       "      <td>1781.384275</td>\n",
       "      <td>1</td>\n",
       "      <td>16</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>7</th>\n",
       "      <td>2020-04-01 16:31:29</td>\n",
       "      <td>2985.651120</td>\n",
       "      <td>1</td>\n",
       "      <td>16</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>8</th>\n",
       "      <td>2020-04-01 17:01:29</td>\n",
       "      <td>2625.745700</td>\n",
       "      <td>1</td>\n",
       "      <td>17</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>9</th>\n",
       "      <td>2020-04-01 17:31:29</td>\n",
       "      <td>2049.410457</td>\n",
       "      <td>1</td>\n",
       "      <td>17</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>10</th>\n",
       "      <td>2020-04-01 18:01:29</td>\n",
       "      <td>2026.813647</td>\n",
       "      <td>1</td>\n",
       "      <td>18</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>11</th>\n",
       "      <td>2020-04-01 18:31:29</td>\n",
       "      <td>2360.017657</td>\n",
       "      <td>1</td>\n",
       "      <td>18</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>12</th>\n",
       "      <td>2020-04-01 19:01:29</td>\n",
       "      <td>104.163034</td>\n",
       "      <td>1</td>\n",
       "      <td>19</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>13</th>\n",
       "      <td>2020-04-01 19:31:29</td>\n",
       "      <td>145.449244</td>\n",
       "      <td>1</td>\n",
       "      <td>19</td>\n",
       "      <td>4</td>\n",
       "      <td>1.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>14</th>\n",
       "      <td>2020-04-01 20:01:29</td>\n",
       "      <td>183.481722</td>\n",
       "      <td>1</td>\n",
       "      <td>20</td>\n",
       "      <td>4</td>\n",
       "      <td>0.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>15</th>\n",
       "      <td>2020-04-01 20:31:29</td>\n",
       "      <td>133.598603</td>\n",
       "      <td>1</td>\n",
       "      <td>20</td>\n",
       "      <td>4</td>\n",
       "      <td>0.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>16</th>\n",
       "      <td>2020-04-01 21:01:29</td>\n",
       "      <td>156.548940</td>\n",
       "      <td>1</td>\n",
       "      <td>21</td>\n",
       "      <td>4</td>\n",
       "      <td>0.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>17</th>\n",
       "      <td>2020-04-01 21:31:29</td>\n",
       "      <td>100.176691</td>\n",
       "      <td>1</td>\n",
       "      <td>21</td>\n",
       "      <td>4</td>\n",
       "      <td>0.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>18</th>\n",
       "      <td>2020-04-01 22:01:29</td>\n",
       "      <td>118.758952</td>\n",
       "      <td>1</td>\n",
       "      <td>22</td>\n",
       "      <td>4</td>\n",
       "      <td>0.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "    <tr>\n",
       "      <th>19</th>\n",
       "      <td>2020-04-01 22:31:29</td>\n",
       "      <td>199.043408</td>\n",
       "      <td>1</td>\n",
       "      <td>22</td>\n",
       "      <td>4</td>\n",
       "      <td>0.0</td>\n",
       "      <td>1.0</td>\n",
       "    </tr>\n",
       "  </tbody>\n",
       "</table>\n",
       "</div>"
      "text/plain": [
       "             DateHeure    Puissance  Jour  Heure  Mois  HeureEtude  MoisEtude\n",
       "0  2020-04-01 13:01:29  1562.445517     1     13     4         1.0        1.0\n",
       "1  2020-04-01 13:31:29  2181.738667     1     13     4         1.0        1.0\n",
       "2  2020-04-01 14:01:29  2752.225827     1     14     4         1.0        1.0\n",
       "3  2020-04-01 14:31:29  2003.979045     1     14     4         1.0        1.0\n",
       "4  2020-04-01 15:01:29  2348.234105     1     15     4         1.0        1.0\n",
       "5  2020-04-01 15:31:29  1502.650369     1     15     4         1.0        1.0\n",
       "6  2020-04-01 16:01:29  1781.384275     1     16     4         1.0        1.0\n",
       "7  2020-04-01 16:31:29  2985.651120     1     16     4         1.0        1.0\n",
       "8  2020-04-01 17:01:29  2625.745700     1     17     4         1.0        1.0\n",
       "9  2020-04-01 17:31:29  2049.410457     1     17     4         1.0        1.0\n",
       "10 2020-04-01 18:01:29  2026.813647     1     18     4         1.0        1.0\n",
       "11 2020-04-01 18:31:29  2360.017657     1     18     4         1.0        1.0\n",
       "12 2020-04-01 19:01:29   104.163034     1     19     4         1.0        1.0\n",
       "13 2020-04-01 19:31:29   145.449244     1     19     4         1.0        1.0\n",
       "14 2020-04-01 20:01:29   183.481722     1     20     4         0.0        1.0\n",
       "15 2020-04-01 20:31:29   133.598603     1     20     4         0.0        1.0\n",
       "16 2020-04-01 21:01:29   156.548940     1     21     4         0.0        1.0\n",
       "17 2020-04-01 21:31:29   100.176691     1     21     4         0.0        1.0\n",
       "18 2020-04-01 22:01:29   118.758952     1     22     4         0.0        1.0\n",
       "19 2020-04-01 22:31:29   199.043408     1     22     4         0.0        1.0"
     "metadata": {},
   "source": [
    "data.head(20)"
   "execution_count": 66,
   "metadata": {},
   "outputs": [],
   "source": [
    "train = data.iloc[0:7000,:]\n",
    "test = data.iloc[7000:,:]"
   "execution_count": 68,
   "metadata": {},
   "outputs": [],
   "source": [
    "X_train = train[['Jour','Heure','Mois','HeureEtude','MoisEtude']]\n",
    "Y_train = train['Puissance']"
   "execution_count": 69,
   "metadata": {},
   "outputs": [],
   "source": [
    "X_test = test[['Jour','Heure','Mois','HeureEtude','MoisEtude']]\n",
    "Y_test = test['Puissance']"
   "metadata": {},
   "source": [
    "Entrainement du modle"
   "execution_count": 70,
   "metadata": {},
   "outputs": [
     "data": {
      "text/plain": [
       "LinearRegression(copy_X=True, fit_intercept=True, n_jobs=None, normalize=False)"
     "metadata": {},
   "source": [
    "Model = linear_model.LinearRegression()\n",
    "\n",
    "# Train the model using the training sets\n",
    "Model.fit(X_train, Y_train)"
   "metadata": {},
   "source": [
    "Prediction"
   "execution_count": 73,
   "metadata": {},
   "outputs": [
     "data": {
      "text/plain": [
       "array([ 541.77091184,  541.77091184,  541.22124232, ..., 1198.88216381,\n",
       "        416.80765393,  416.80765393])"
     "metadata": {},
   "source": [
    "Model.predict(X_test)"
   "metadata": {},
   "source": [
    "Coefficient R"
   "execution_count": 74,
   "metadata": {},
   "outputs": [
     "data": {
      "text/plain": [
       "0.34852852978549054"
     "metadata": {},
   "source": [
    "Model.score(X_test, Y_test)"
 "metadata": {
  "celltoolbar": "Aucun(e)",
  "kernelspec": {
   "display_name": "Python 3",
   "language": "python",
   "name": "python3"
  "language_info": {
   "codemirror_mode": {
    "name": "ipython",
    "version": 3
   "file_extension": ".py",
   "mimetype": "text/x-python",
   "name": "python",
   "nbconvert_exporter": "python",
   "pygments_lexer": "ipython3",
   "version": "3.7.3"
 "nbformat": 4,
 "nbformat_minor": 2
Credits
houda lahlou
houda lahlou
1 project • 0 followers
Kenzi Sarra
Kenzi Sarra
0 projects • 0 followers
Comments
Add projectSign up / Login
