nishanchettriDikshita Singh
Published © LGPL
Smart Gloves
Monitor your sleep and meditation using smart gloves and IOT application.
IntermediateFull instructions provided71
Smart Gloves
Things used in this project
Hardware components
ESP8266 ESP-12E
Espressif ESP8266 ESP-12E
×1
Resistor 10k ohm
Resistor 10k ohm
×1
aluminium foil
×1
Capacitor 100 nF
Capacitor 100 nF
×1
Pushbutton switch 12mm
SparkFun Pushbutton switch 12mm
×1
Phone Audio Connector, Jack
×1
Phone Audio Connector, 3.5mm
×1
Male Header 40 Position 1 Row (0.1")
×1
Grove - 2-Channel SPDT Relay
Seeed Grove - 2-Channel SPDT Relay
×1
Arduino IDE
Arduino IDE
Adafruit IO
Soldering iron (generic)
Solder Wire, Lead Free
Wire Cutter / Stripper, 5.25 " Overall Length
Story
Read more
Schematics
Glove circuit with sensor electrode
IOT node for turning on fan when trigger is caused
IOT node for turning on RGB mood LED bulb when trigger is caused
Code
For the glove and IOT dashboard monitoring
Arduino
Thanks to Adafrut mqtt example.
Author: nishan chettri
This sketch includes the use of NTC 10D-9 thermistor, it is commented out.If you want to monitoe temperature too you can add the temperature sensor and uncomment.
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <math.h>        //include math.h
/******************Thermistor Calibration*************************/
//float thermistorError=20 ;
//There is 6 degree deviation from actual value
/******************* WiFi Access Point ***************************/
#define WLAN_SSID       "nissan"
#define WLAN_PASS       "password"
/******************* Adafruit.io Setup ***************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883                   // use 8883 for SSL
#define AIO_USERNAME    "put your adafruit IO username herer"
#define AIO_KEY         "put your Api key here"
//********* Global State (you don't need to change this!) **********
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// or... use WiFiFlientSecure for SSL
//WiFiClientSecure client;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
/************************ Feeds ********************************/
/************************* Topics ******************************/
//  Setup a feed called 'temp_topic' for publishing.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
Adafruit_MQTT_Publish gsr = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/gsr10_05_2020");
//Adafruit_MQTT_Publish temp = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/temp");
//Publishing to the feed "band" in my dashboard
void MQTT_connect();
//declaration of mqtt connect funciton
//measure(beta,normal tempreature in K, normal resistance, analog value , Series resistance)
double measure(double beta,double To,double R,double aVal,double Rs);
  delay(10);
  Serial.println(F("Adafruit MQTT demo"));
// Connect to WiFi access point.
  Serial.println(); Serial.println();
  Serial.print("Connecting to ");
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println();
Serial.println("WiFi connected");
  Serial.println("IP address: "); Serial.println(WiFi.localIP());
//uint32_t x = 0;
/************************ Loop  *****************************/
  delay(2000);
  MQTT_connect();
//    double val=analogRead(34);   //analog read
    double gsrValue=analogRead(A0);
  /*measure(beta,normal tempreature in K, normal resistance, analog value , Series resistance)*/
//    double temperature = measure(3000,25,10,val,120);
/************************ Publish  **************************/
  // Publishing the temperature and GSR raw data
//  if (! temp.publish(temperature)) {
//    Serial.println(F("temp Failed"));
//  } else {
//    Serial.println(F("OK!"));
    if (! gsr.publish(gsrValue)) {
    Serial.println(F("gsr Failed"));
  } else {
    Serial.println(gsrValue);
/************************ Ping  *********************************/
  // ping the server to keep the mqtt connection alive
  // NOT required if you are publishing once every KEEPALIVE seconds
    if(! mqtt.ping()) {
    mqtt.disconnect();
  delay(2000);
/************************** MQTT Conn  **************************/
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect()
  int8_t ret;
// Stop if already connected.
  if (mqtt.connected()) {
    return;
Serial.print("Connecting to MQTT... ");
uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
    Serial.println(mqtt.connectErrorString(ret));
    Serial.println("Retrying MQTT connection in 5 seconds...");
    mqtt.disconnect();
    delay(5000);  // wait 5 seconds
    retries--;
    if (retries == 0) {
      // basically die and wait for WDT to reset me
      while (1);
  Serial.println("MQTT Connected!");
 * Function to calculate temperature according to thermistor used here NTC 10D-9 is used
 * This function can be used with any thermistor
//double measure(double beta,double To,double R,double aVal,double Rs)
//{ //steinhart hart eqution for temperature calculation
//  double To_C=To+273.15;
//  double Eout=(aVal/4095)*3.3;
//  double Rt=((3.3*Rs)/Eout)-120 ;
//  double alpha=log(Rt/R)/beta ;
//  double inv_To= 1/To_C ;
//  double Tk= 1/(alpha+inv_To) ;
//  double Tc=Tk-273.15-thermistorError ; //convert from kelvin to celsius
//  return Tc;
Code for the node controlling the fan
Arduino
Please make necessary tweaks according tothe board used. This is for ESP12E
If you are using ESP32:
replace #include <ESP8266WiFi.h> by #include <WiFi.h>
/************************* WiFi Access Point *********************************/
#define WLAN_SSID       "wifi ssid"
/************************* Adafruit.io Setup *********************************/
#define AIO_USERNAME    "put your username here"
#define AIO_KEY         "put your api key here"
/************ Global State (you don't need to change this!) ******************/
WiFiClient client;
/****************************** Feeds ***************************************/
Adafruit_MQTT_Subscribe onoffbutton = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/fan");
/*************************** Sketch Code ************************************/
#define fanPin D7
  delay(10);
  pinMode(fanPin,OUTPUT);
    delay(500);
    Serial.print(".");
  Serial.println();
  // Setup MQTT subscription for onoff feed.
  mqtt.subscribe(&onoffbutton);
  digitalWrite(fanPin,LOW);
uint32_t x=0;
  // Ensure the connection to the MQTT server is alive (this will make the first
  // connection and automatically reconnect when disconnected).  See the MQTT_connect
  // function definition further below.
  MQTT_connect();
  // this is our 'wait for incoming subscription packets' busy subloop
  // try to spend your time here
  Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(5000))) {
    if (subscription == &onoffbutton) {
      Serial.print("Got: ");
      Serial.print((char*)onoffbutton.lastread);
    if(strcmp((char*)onoffbutton.lastread,"OFF")==0)
        digitalWrite(fanPin,HIGH);
      else
  // Now we can publish stuff!
 if(! mqtt.ping()) {
   mqtt.disconnect();
void MQTT_connect() {
  int8_t ret;
    return;
       mqtt.disconnect();
       retries--;
       if (retries == 0) {
         while (1);
Credits
nishanchettri
nishanchettri
6 projects • 3 followers
Maker with an infinite curiosity to learn.
Dikshita Singh
Dikshita Singh
0 projects • 1 follower
Comments
Add projectSign up / Login
