Antonio ScalaEvan DiewaldNathan Pirhalla
Published © GPL3+
LongHive
An end-to-end beehive monitoring solution enabled by the Helium Network and deep learning.
IntermediateFull instructions provided10 hours4,016
Things used in this project
Hardware components
Helium Developer Kit
×1
Raspberry Pi 3 Model B
×1
ReSpeaker 2-Mics Pi HAT
Seeed ReSpeaker 2-Mics Pi HAT
×1
50kg Load Cells with HX711 Amplifier
×1
SparkFun Air Quality Breakout - CCS811
×1
DS18B20 Temperature Sensor 1m
HARDWARIO DS18B20 Temperature Sensor 1m
×1
TensorFlow
TensorFlow
Grafana
Helium Console
Pipedream
3D Printer (generic)
Story
Read more
Custom parts and enclosures
Load Cell Foot Mount (Print 4)
Load cells should snap into place if the filament has a bit of flex to it - no adhesive needed. Credit to user b2vn on Thingiverse: https://www.thingiverse.com/thing:1100304
ST-LRWAN1 Housing
This latched housing allows easy access to the LoRa Board without detaching the entire assembly. Print in place with only supports where the part attaches to the build plate.
Raspberry Pi Housing
Holds the RPi 3B and slides into the Raspberry Pi Mount.
Raspberry Pi Mount
Attach to the underside of the enclosure lid.
LongHive SW Assembly
Prepared in SW 2019.
Schematics
LongHive Enclosure Drawing
The base was designed to be assembled with 2x4 planks and 1/4" sheets of plywood.
LongHive Breadboard
An Arduino UNO is shown in the schematic, but please replace the UNO with the ST-B-L072Z-LRWAN1 from the Helium Developer Kit, which has the same form factor.
LongHive Schematic
Code
LongHive
A smart beehive monitoring system using edge computing and the Helium protocol.
Credits
Antonio Scala
Antonio Scala
1 project • 2 followers
Evan Diewald
Evan Diewald
3 projects • 4 followers
Mechanical engineering grad student at Carnegie Mellon
Nathan Pirhalla
Nathan Pirhalla
0 projects • 1 follower
Comments
Add projectSign up / Login
