Amol DisaleBrijesh Singh
Published © GPL3+
Stopwatch Using Arduino
Use an Arduino Nano to make a simple stopwatch!
EasyWork in progress10 hours6
Things used in this project
Hardware components
Arduino Nano R3
Arduino Nano R3
×1
Grove - 16 x 2 LCD (Black on Yellow)
Seeed Grove - 16 x 2 LCD (Black on Yellow)
×1
Pushbutton switch 12mm
SparkFun Pushbutton switch 12mm
×2
Screw Terminal 2-Pin
×1
General Purpose Breadboard PCB
×1
Arduino IDE
Arduino IDE
Soldering iron (generic)
Story
Read more
Schematics
Arduino StopWatch Circuit Connection
The connection is shown in Proteus Software!
Arduino stopwatch circuit zb20v1s3py
Code
Arduino StopWatch Code
Arduino
Stopwatch function implemented using Arduino Nano
// include the library code:
#include <LiquidCrystal.h>
#include <Bounce2.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 6, rw = 5, en = 4, d4 = 8, d5 = 9, d6 = 10, d7 = 11;
//LiquidCrystal(rs, rw, enable, d4, d5, d6, d7)
LiquidCrystal lcd(rs, rw, en, d4, d5, d6, d7);
const byte ledPin = 13;
const byte startButton = 2;
// Instantiate a Bounce object
Bounce startDebouncer1 = Bounce();
const byte resetButton = 3;
// Instantiate another Bounce object
Bounce resetDebouncer2 = Bounce();
  pinMode(startButton, INPUT_PULLUP);
  // After setting up the button, setup the Bounce instance :
  startDebouncer1.attach(startButton);
  startDebouncer1.interval(5); // interval in ms
  pinMode(resetButton, INPUT_PULLUP);
  resetDebouncer2.attach(resetButton);
  resetDebouncer2.interval(5); // interval in ms
  pinMode(ledPin, OUTPUT);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  lcd.setCursor(0, 0);
  // Print a message to the LCD.
  lcd.print("*** StopWatch **");
  lcd.setCursor(0, 1);
  lcd.print("***  Project ***");
  delay(500);
  // clear screen for the next loop:
  lcd.clear();
  lcd.print("Press B-Strt/Stp");
  lcd.print("Press R-Reset");
  Serial.begin(9600);
  Serial.println("StopWatch using Arduino Nano");
  Serial.println("Press Following Switches:- ");
  Serial.println("Black Switch for Start/Stop");
  Serial.println("Red Switch for Reset");
bool startState = LOW;
bool resetState = LOW;
unsigned long startMillis;
unsigned long currentMillis;
unsigned long elapsedMillis;
  // Update the Bounce instances :
  startDebouncer1.update();
   if ( startDebouncer1.fell() ) {     // Call code if button transitions from HIGH to LOW
     startState = !startState;         // Toggle start button state
     startMillis = millis();
  if (startState)
    currentMillis = millis();
    elapsedMillis = (currentMillis - startMillis);
    lcd.print("SW (hh:mm:ss:ms)");
    lcd.print("                ");
    Serial.print("elapsedMillis: ");
    Serial.print(elapsedMillis);
    Serial.println("");
    unsigned long durMS = (elapsedMillis%1000);       //Milliseconds
    unsigned long durSS = (elapsedMillis/1000)%60;    //Seconds
    unsigned long durMM = (elapsedMillis/(60000))%60; //Minutes
    unsigned long durHH = (elapsedMillis/(3600000));  //Hours
    durHH = durHH % 24;
    Serial.print("Time: ");
    Serial.print(durHH);
    Serial.print(" : ");
    Serial.print(durMM);
    Serial.print(durSS);
    Serial.print(durMS);
    Serial.println("");
    String durMilliSec = timeMillis(durHH, durMM, durSS,durMS);
    lcd.print(durMilliSec);
    Serial.println("******************************");
    Serial.println("");
    delay(150);
  resetDebouncer2.update();
  if (resetDebouncer2.fell())
    resetState = HIGH;
  if (resetState)
    lcd.clear();
    Serial.println("");
    delay(100);
    resetState = LOW;
String timeMillis(unsigned long Hourtime,unsigned long Mintime,unsigned long Sectime,unsigned long MStime)
  String dataTemp = "";
  if (Hourtime < 10)
    dataTemp = dataTemp + "0" + String(Hourtime)+ "h:";
  else{
    dataTemp = dataTemp + String(Hourtime)+ "h:";
  if (Mintime < 10)
    dataTemp = dataTemp + "0" + String(Mintime)+ "m:";
  else{
    dataTemp = dataTemp + String(Mintime)+ "m:";
  if (Sectime < 10)
    dataTemp = dataTemp + "0" + String(Sectime)+ "s:";
  else{
    dataTemp = dataTemp + String(Sectime)+ "s:";
  dataTemp = dataTemp + String(MStime);
  Serial.print("String Time: ");
  Serial.println(dataTemp);
  return dataTemp;
Credits
Amol Disale
Amol Disale
8 projects • 79 followers
I am passionate about the idea of open-source hardware and software. I am ready to help in prototyping IoT, Smart Home, and other products.
Brijesh Singh
Brijesh Singh
5 projects • 19 followers
Maker and Electronics Engineer likes to Make and share DIY, open source Hardware projects.
Comments
Add projectSign up / Login
