Amol Disale
Published © GPL3+
Temperature Humidity Data Logger
This project helps to monitor temperature and humidity values of a particular location along with device battery level.
IntermediateFull instructions provided6,233
Things used in this project
Hardware components
Grove Starter Kit for LinkIt ONE
Seeed Grove Starter Kit for LinkIt ONE
×1
Ubidots
Ubidots
Arduino IDE
Arduino IDE
Story
Read more
Schematics
Project connection diagram
Code
LinkIt ONE CODE
Arduino
DHT Library can be downloaded from:
https://github.com/Seeed-Studio/Grove_Starter_Kit_For_LinkIt/tree/master/libraries/Humidity_Temperature_Sensor
#include <LBattery.h>
#include <LGPRS.h>
#include <LGPRSClient.h>
#include "DHT.h"
#define URL    "things.ubidots.com"
#define TOKEN ""  // replace with your Ubidots token generated in your profile tab
#define VARID1 ""    //Temperature variable id
#define VARID2 ""    //Humidity variable id
#define VARID3 ""    //Battery Level variable id
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
#define DHTPIN 2     // Digital pin 2 where DHT 22 is connected to
#define DHTTYPE DHT22   // DHT 22  (AM2302)
DHT dht(DHTPIN, DHTTYPE);
char buff[256];  //Info about battery level and charging
//Temperature and Humidity sensor readings from DHT 22
float t = 0.0;
float h = 0.0;
//Location where this logger is placed!!
String loclat="19.21833";
String loclng="72.978088";
String Location;
//Initializing gprs
LGPRSClient client;  //GPRS Client
  Serial.begin(9600);
  Serial.println("Temperature Humidity Logger by Er.Amol");
  dht.begin();
// Creating a string containing latitude and longitude information of the Logger's location
  Location="{\"lat\":";
  Location=Location+loclat;
  Location += " ,\"lng\":";
  Location=Location+loclng+ "}";
  Serial.println("Attach to GPRS network by APN setting");
  //Note add Access point name, username and password according to your sim card manufacturer/service provide
   while (!LGPRS.attachGPRS("APN","Username","Password"))
    delay(500);
  LGPRSClient globalclient ;
  client = globalclient;
  delay(2000);
  Serial.println("Smart Trash Can Project by Er.Amol");
  if(dht.readHT(&t, &h)) //Reading Temperature and humidity from DHT 22
  delay(2000);
  dht.readHT(&t, &h);
  Serial.println("------------------------------");
  Serial.print("Temperature: ");
  Serial.println(t);
  Serial.print("Humidity: ");
  Serial.println(h);
  sprintf(buff,"Battery level = %d", LBattery.level() );
  Serial.println(buff);
 String payload = "[{\"variable\":\"" VARID1 "\",\"value\":"+ String(t)+",\"context\":"+Location+"},{\"variable\":\"" VARID2 "\",\"value\":" + String(h) + "},{\"variable\":\"" VARID3 "\",\"value\":" + String(LBattery.level()) + "}]";
 String le = String(payload.length());
  // if you get a connection, report back via serial:
  Serial.print("Connect to ");
  Serial.println(URL);
  if (client.connect(URL, 80))
    // Build HTTP POST request
    Serial.println("connected");
    client.print(F("POST /api/v1.6/collections/values/?token="));
    client.print(TOKEN);
    client.println(F(" HTTP/1.1"));
    client.println(F("Content-Type: application/json"));
    client.print(F("Content-Length: "));
    client.println(le);
    client.print(F("Host: "));
    client.println(URL);
    client.println();
    client.println(payload);
  else
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  delay(100);
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available())
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.available() && !client.connected())
    Serial.println();
    Serial.println("disconnecting.");
    client.stop();
  //Delay of about 1 minute or 60 seconds
   for (int minutes = 0; minutes < 7; minutes++)
     delay(10000);  //10 seconds delay or 10 thousand milli-seconds
Credits
Amol Disale
Amol Disale
9 projects • 91 followers
I am passionate about the idea of open-source hardware and software. I am ready to help in prototyping IoT, Smart Home, and other products.
Comments
Add projectSign up / Login
