IoT_hobbyist
Published © GPL3+
Arduino - Pan Tilt Grove Camera on Web
Monitor your home remotely via web using Arduino Uno and pan-tilt Grove camera.
BeginnerFull instructions provided5,753
Things used in this project
Hardware components
Arduino UNO & Genuino UNO
×1
PHPoC WiFi Shield for Arduino
×1
Seeed Grove Expansion Board
×1
Grove - Serial Camera Kit
Seeed Grove - Serial Camera Kit
×1
SG90 Micro-servo motor
×2
Story
Read more
Code
Arduino Code
Arduino
#include "SPI.h"
#include "Phpoc.h"
#include <Servo.h>
#define PIC_PKT_LEN    256 //data length of each read, dont set this too big because ram is limited
#define CAM_ADDR       0
const byte cameraAddr = (CAM_ADDR << 5); // address
unsigned char pkt[PIC_PKT_LEN];
unsigned int pktCnt;
unsigned int lastPacketLength;
PhpocServer server(80);
PhpocClient client;
Servo servo_x;
Servo servo_y;
int current_angle_x;
int current_angle_y;
void setup(){
	Phpoc.begin(PF_LOG_SPI | PF_LOG_NET);
	server.beginWebSocketBinary("grove_camera", "uint8.phpoc");
	servo_x.attach(8);  // attaches the servo on pin 8 to the servo object
    servo_y.attach(9);  // attaches the servo on pin 9 to the servo object
    servo_x.write(90);
    servo_y.write(90);
	cameraInit();
	client = server.available();
void loop(){
	if(client && client.connected()){
		cameraGetPicture();
		for(unsigned int i = 0; i <= pktCnt; i++){
			getPacket(i);
			joystickLoop();
	} else {
void joystickLoop(){
	String data = "";
	while(1) {
		String data = client.readLine();
		if(data.length()){
			int pos = data.indexOf(':');
			long x = data.substring(0, pos).toInt();
			long y = data.substring(pos+1).toInt();
			// scale  from [-100; 100] to [0; 180]
			long angle_x = map(x, -100, 100, 0, 180);
			long angle_y = map(y, -100, 100, 0, 180);
			servo_x.write(angle_x);
			servo_y.write(angle_y);
		else
			break;
void clearRxBuf(){
    while (Serial.available()){
        Serial.read();
void sendCmd(char cmd[], int cmd_len){
    for (char i = 0; i < cmd_len; i++) Serial.print(cmd[i]);
void cameraInit(){
    char cmd[] = {0xaa,0x0d|cameraAddr,0x00,0x00,0x00,0x00} ;
    unsigned char resp[6];
    Serial.setTimeout(500);
    while (1){
        sendCmd(cmd,6);
        if(Serial.readBytes((char *)resp, 6) != 6)
            continue;
        if(resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x0d && resp[4] == 0 && resp[5] == 0) {
            if(Serial.readBytes((char *)resp, 6) != 6) continue;
            if(resp[0] == 0xaa && resp[1] == (0x0d | cameraAddr) && resp[2] == 0 && resp[3] == 0 && resp[4] == 0 && resp[5] == 0) break;
    cmd[1] = 0x0e | cameraAddr;
    cmd[2] = 0x0d;
    sendCmd(cmd, 6);
    char cmd2[] = { 0xaa, 0x01 | cameraAddr, 0x00, 0x07, 0x03, 0x05};
    Serial.setTimeout(100);
    while (1){
        clearRxBuf();
        sendCmd(cmd2, 6);
        if(resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x01 && resp[4] == 0 && resp[5] == 0) break;
    char cmd3[] = { 0xaa, 0x06 | cameraAddr, 0x08, PIC_PKT_LEN & 0xff, (PIC_PKT_LEN>>8) & 0xff ,0};
    while (1) {
        clearRxBuf();
        sendCmd(cmd3, 6);
        if(resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x06 && resp[4] == 0 && resp[5] == 0) break;
	//Serial.println("Camera initialization done.");
void cameraGetPicture(){
	char cmd[] = { 0xaa, 0x04 | cameraAddr, 0x01, 0x00, 0x00, 0x00 };
	unsigned long picTotalLen = 0; // picture length
    while (1){
        clearRxBuf();
        sendCmd(cmd, 6);
        if(resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x04 && resp[4] == 0 && resp[5] == 0){
            Serial.setTimeout(1000);
                continue;
            if(resp[0] == 0xaa && resp[1] == (0x0a | cameraAddr) && resp[2] == 0x01){
                picTotalLen = (resp[3]) | (resp[4] << 8) | (resp[5] << 16);
                break;
    pktCnt = (picTotalLen) / (PIC_PKT_LEN - 6);
	lastPacketLength = PIC_PKT_LEN;
    if((picTotalLen % (PIC_PKT_LEN-6)) != 0){
		pktCnt += 1;
		lastPacketLength = picTotalLen % (PIC_PKT_LEN - 6) + 6;
void getPacket(unsigned int i){
    char cmd[] = { 0xaa, 0x0e | cameraAddr, 0x00, 0x00, 0x00, 0x00 };
	if(i < pktCnt) {
		cmd[4] = i & 0xff;
		cmd[5] = (i >> 8) & 0xff;
		clearRxBuf();
		sendCmd(cmd, 6);
		int pkt_len;
		if(i < (pktCnt - 1))
			pkt_len = PIC_PKT_LEN ;
		else
			pkt_len = lastPacketLength;
		uint16_t cnt = Serial.readBytes((char *)pkt, pkt_len);
		while(client.availableForWrite() < (cnt - 6)) // check availability of websocket tx buffer.
		client.write((const uint8_t *)&pkt[4], cnt - 6);
	} else {
		cmd[4] = 0xf0;
		cmd[5] = 0xf0;
		sendCmd(cmd, 6);
Web User Interface
PHP
<!DOCTYPE html>
<html>
<head>
<title>Arduino - PHPoC Shield</title>
<meta name="viewport" content="width=device-width, initial-scale=0.7, maximum-scale=0.7">
<style>
body { text-align: center; font-size: 15pt; }
h1 { font-weight: bold; font-size: 20pt; }
h2 { font-weight: bold; font-size: 15pt; }
button { font-weight: bold; font-size: 15pt; }
</style>
<script>
/* Camera variable */
var image = new Uint8Array(0);
/* Joystick variable */
var canvas_width = 500, canvas_height = 500;
var radius_base = 150;
var radius_handle = 72;
var radius_shaft = 120;
var range = canvas_width/2 - 10;
var step = 18;
var joystick = {x:0, y:0, x_percent: 0, y_percent: 0};
var click_state = 0;
var ws;
function init()
	/* Camera setting */
	var camera = document.getElementById("camera");
	camera.width = "320";
	camera.height = "240";
	/* Joystick setting */
	var ratio = 320.0 / canvas_width; // 320 is image's width
	canvas_width = Math.round(canvas_width * ratio);
	canvas_height = Math.round(canvas_height * ratio);
	radius_base = Math.round(radius_base * ratio);
	radius_handle = Math.round(radius_handle * ratio);
	radius_shaft = Math.round(radius_shaft * ratio);
	range = Math.round(range * ratio);
	step = Math.round(step * ratio);
	var canvas = document.getElementById("joystick");
	canvas.width = canvas_width;
	canvas.height = canvas_height;
	canvas.addEventListener("touchstart", mouse_down);
	canvas.addEventListener("touchend", mouse_up);
	canvas.addEventListener("touchmove", mouse_move);
	canvas.addEventListener("mousedown", mouse_down);
	canvas.addEventListener("mouseup", mouse_up);
	canvas.addEventListener("mousemove", mouse_move);
	var ctx = canvas.getContext("2d");
	ctx.translate(canvas_width/2, canvas_height/2);
	ctx.shadowBlur = 20;
	ctx.shadowColor = "LightGray";
	ctx.lineCap="round";
	ctx.lineJoin="round";
	update_view();
function connect_onclick()
	if(ws == null)
		var ws_host_addr = "<?echo _SERVER("HTTP_HOST")?>";
		if((navigator.platform.indexOf("Win") != -1) && (ws_host_addr.charAt(0) == "["))
			// network resource identifier to UNC path name conversion
			ws_host_addr = ws_host_addr.replace(/[\[\]]/g, '');
			ws_host_addr = ws_host_addr.replace(/:/g, "-");
			ws_host_addr += ".ipv6-literal.net";
		ws = new WebSocket("ws://" + ws_host_addr + "/grove_camera", "uint8.phpoc");
		document.getElementById("ws_state").innerHTML = "CONNECTING";
		ws.onopen = ws_onopen;
		ws.onclose = ws_onclose;
		ws.onmessage = ws_onmessage;
		ws.binaryType = "arraybuffer";
	else
		ws.close();
function ws_onopen()
	document.getElementById("ws_state").innerHTML = "<font color='blue'>CONNECTED</font>";
	document.getElementById("bt_connect").innerHTML = "Disconnect";
	ws.send("0:0\r\n");
function ws_onclose()
	document.getElementById("ws_state").innerHTML = "<font color='gray'>CLOSED</font>";
	document.getElementById("bt_connect").innerHTML = "Connect";
	ws.onopen = null;
	ws.onclose = null;
	ws.onmessage = null;
	ws = null;
/* Camera functions */
function ws_onmessage(e_msg)
	e_msg = e_msg || window.event; // MessageEvent
	var u8view = new Uint8Array(e_msg.data);
	if(u8view[0] == 0xFF && u8view[1] == 0xD8) /* Start Of JPEG Image */
		image = u8view;
	else
		var data = new Uint8Array(image.length + u8view.length);
		data.set(image);
		data.set(u8view, image.length);
		image = data;
	if(u8view[u8view.length - 2] == 0xFF && u8view[u8view.length - 1] == 0xD9) /* End Of JPEG Image */
		document.getElementById("camera").src = "data:image/jpeg;base64,"+  arrayToBase64(image);
function arrayToBase64(byteArray)
	var hexString =  Array.from(byteArray, function(byte) {
			return ('0' + (byte & 0xFF).toString(16)).slice(-2);
		}).join('');
	return btoa(String.fromCharCode.apply(null, hexString.replace(/\r|\n/g, "").replace(/([\da-fA-F]{2}) ?/g, "0x$1 ").replace(/ +$/, "").split(" ")));
/* Joystick functions */
function send_data()
	console.log(joystick.x_percent + ":" + joystick.y_percent + "\r\n");
	if(ws != null)
		ws.send(joystick.x_percent + ":" + joystick.y_percent + "\r\n");
function update_view()
	var x = joystick.x, y = joystick.y;
	ctx.clearRect(-canvas_width/2, -canvas_height/2, canvas_width, canvas_height);
	ctx.lineWidth = 3;
	ctx.strokeStyle="gray";
	ctx.fillStyle = "LightGray";
	ctx.beginPath();
	ctx.arc(0, 0, range, 0, 2 * Math.PI);
	ctx.stroke();
	ctx.fill();
	ctx.strokeStyle="black";
	ctx.fillStyle = "hsl(0, 0%, 35%)";
	ctx.beginPath();
	ctx.arc(0, 0, radius_base, 0, 2 * Math.PI);
	ctx.stroke();
	ctx.fill();
	ctx.strokeStyle="red";
	var lineWidth = radius_shaft;
	var pre_x = pre_y = 0;
	var x_end = x/5;
	var y_end = y/5;
	var max_count  = (radius_shaft - 10)/step;
	var count = 1;
	while(lineWidth >= 10)
		var cur_x = Math.round(count * x_end / max_count);
		var cur_y = Math.round(count * y_end / max_count);
		ctx.lineWidth = lineWidth;
		ctx.beginPath();
		ctx.lineTo(pre_x, pre_y);
		ctx.lineTo(cur_x, cur_y);
		ctx.stroke();
		lineWidth -= step;
		pre_x = cur_x;
		pre_y = cur_y;
		count++;
	var x_start = Math.round(x / 3);
	var y_start = Math.round(y / 3);
	lineWidth += step;
	ctx.beginPath();
	ctx.lineTo(x_start, y_start);
	ctx.stroke();
	count = 1;
	pre_x = x_start;
	pre_y = y_start;
	while(lineWidth < radius_shaft)
		var cur_x = Math.round(x_start + count * (x - x_start) / max_count);
		var cur_y = Math.round(y_start + count * (y - y_start) / max_count);
		ctx.beginPath();
		ctx.stroke();
		lineWidth += step;
		pre_x = cur_x;
		pre_y = cur_y;
		count++;
	var grd = ctx.createRadialGradient(x, y, 0, x, y, radius_handle);
	for(var i = 85; i >= 50; i-=5)
		grd.addColorStop((85 - i)/35, "hsl(0, 100%, "+ i + "%)");
	ctx.fillStyle = grd;
	ctx.beginPath();
	ctx.arc(x, y, radius_handle, 0, 2 * Math.PI);
	ctx.fill();
function process_event(event)
	var pos_x, pos_y;
	if(event.offsetX)
		pos_x = event.offsetX - canvas_width/2;
		pos_y = event.offsetY - canvas_height/2;
	else if(event.layerX)
		pos_x = event.layerX - canvas_width/2;
		pos_y = event.layerY - canvas_height/2;
	else
		pos_x = (Math.round(event.touches[0].pageX - event.touches[0].target.offsetLeft)) - canvas_width/2;
		pos_y = (Math.round(event.touches[0].pageY - event.touches[0].target.offsetTop)) - canvas_height/2;
	var joystick_range = range - radius_handle;
	x_percent = Math.round(pos_x * 100 / joystick_range);
	y_percent = Math.round(-pos_y * 100 / joystick_range);
	return {x:pos_x, y:pos_y, x_percent:x_percent, y_percent:y_percent}
function mouse_down()
	if(ws == null)
		return;
	event.preventDefault();
	var pos = process_event(event);
	var delta_x = pos.x - joystick.x;
	var delta_y = pos.y - joystick.y;
	var dist = Math.sqrt(delta_x*delta_x + delta_y*delta_y);
	if(dist > radius_handle)
		return;
	click_state = 1;
	var radius = Math.sqrt(pos.x*pos.x + pos.y*pos.y);
	if(radius <(range - radius_handle))
		delta_x = pos.x_percent - joystick.x_percent;
		delta_y = pos.y_percent - joystick.y_percent;
		if(dist < 2)
			return;
		joystick = pos;
		send_data();
		update_view();
function mouse_up()
	click_state = 0;
function mouse_move()
	if(ws == null)
		return;
	if(!click_state)
		return;
		var delta_x = pos.x_percent - joystick.x_percent;
		var delta_y = pos.y_percent - joystick.y_percent;
		if(dist < 2)
			return;
		joystick = pos;
		send_data();
		update_view();
window.onload = init;
</script>
</head>
<body>
<h1>Arduino - Grove Camera - Web</h1>
<img id="camera"><br>
<canvas id="joystick"></canvas>
<h2>
<p>
WebSocket : <span id="ws_state">null</span><br>
</p>
<button id="bt_connect" type="button" onclick="connect_onclick();">Connect</button>
</h2>
</body>
</html>
Credits
IoT_hobbyist
IoT_hobbyist
4 projects • 17 followers
Comments
Add projectSign up / Login
