Leo-zhong
Published © GPL3+
Balance maze with Arduino Uno
This is a balanced maze with sensors, and you can only win if you stay calm and balanced.
BeginnerFull instructions provided2 hours20
Things used in this project
Hardware components
Grove - Touch Sensor SKU 101020037
Seeed Grove - Touch Sensor SKU 101020037
×1
Grove - Vibration Sensor (SW-420)
Seeed Grove - Vibration Sensor (SW-420)
×1
4-Digit-Display
×1
Arduino Uno
×1
Base Shield V2
Seeed Base Shield V2
×1
LED Pack
×1
Story
Read more
Schematics
Sensors' connection
it's easy to connect according to your way.
Code
Key code
C/C++
The main code can be optimized
    pinMode(TouchPin, INPUT);
    pinMode(TouchPin1, INPUT);
    pinMode(ledPin,OUTPUT);
    pinMode(buttonPin, INPUT);
    tm1637.set();
    tm1637.init();
    Timer1.initialize(500000);//timing for 500ms
    Timer1.attachInterrupt(TimingISR);//declare the interrupt serve routine:TimingISR
void loop(){
    int sensorValue = digitalRead(TouchPin);
    int sensorValue1 = digitalRead(TouchPin1);
    int buttonState = digitalRead(buttonPin);
    if(sensorValue==HIGH && sensorValue1==HIGH)
        digitalWrite(ledPin,LOW);
        if(buttonState == HIGH)
          if(Update == ON)
            TimeUpdate();
            tm1637.display(TimeDisp);
         else
            exit(0);
    else
        digitalWrite(ledPin,HIGH);
void TimeUpdate(void)
  if(ClockPoint)
    tm1637.point(POINT_ON);
  else
   tm1637.point(POINT_OFF);
   TimeDisp[0] = minute / 10;
   TimeDisp[1] = minute % 10;
   TimeDisp[2] = second / 10;
   TimeDisp[3] = second % 10;
   Update = OFF;
void TimingISR()
  halfsecond ++;
  Update = ON;
  if(halfsecond == 2)
    second --;
    if(second == 0 && minute !=0)
      minute --;
      if(minute == 0)
      second = 59;
    halfsecond = 0;
    Serial.println(second);
    ClockPoint = (~ClockPoint) & 0x01;
Credits
Leo-zhong
Leo-zhong
1 project • 1 follower
Comments
Add projectSign up / Login
