Muhammad Sheraz
Published © LGPL
Artificial Intelligence (AI) Based Line Following Robot
Artificial Intelligence (AI) based line Following robot is a robot that a sense of detecting the correct path for its route.
IntermediateFull instructions provided10 hours250
Things used in this project
Hardware components
Arduino Nano
×1
Seeed Wireless Bluetooth RF Transceiver Master Slave
×1
Amazon Web Services IR Infrared Sensor Module Reflective Photoelectric Light
×1
Sony Continuous Rotation Servo
×1
Android 4.8 Volt Battery
×1
Arduino IDE
Arduino IDE
Story
Read more
Schematics
Circuit Diagram
Code
RoBot_Maze_Solve_2
C/C++
7 sensors Smart Robot - Maze Solver and Line Follower with programable PID controller via BT
==> Basic movement based on Nano Mouse Robot, developed by Michael Backus (http://www.akrobotnerd.com/ )
==> Line follow based on http://samvrit.tk/tutorials/pid-control-arduino-line-follower-robot/?ckattempt=1
==> CREDIT to Patrick McCabe for the path Solving Code, visit patrickmccabemakes.com!!
Marcelo Jose Rovai - 23 April, 2016 - Visit: http://mjrobot.org
#include <Servo.h>
#include "robotDefines.h"
String command;
String device;
// BT Module
#include <SoftwareSerial.h>
SoftwareSerial BT1(10, 11); // El pin 10 es Rx y el pin 11 es Tx
  Serial.begin(9600);
  BT1.begin(9600);
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP);
  // line follow sensors
  pinMode(lineFollowSensor0, INPUT);
  pinMode(lineFollowSensor1, INPUT);
  pinMode(lineFollowSensor2, INPUT);
  pinMode(lineFollowSensor3, INPUT);
  pinMode(lineFollowSensor4, INPUT);
  // servos
  leftServo.attach(5);
  rightServo.attach(3);
  BT1.print("check the PID constants to be sent to Robot");
  Serial.print("check the PID constants to be sent to Robot");
  BT1.println('\n');
  while (digitalRead(buttonPin) && !mode)
    checkBTcmd();  // verify if a comand is received from BT remote control
    manualCmd ();
    command = "";
  checkPIDvalues();
  mode = STOPPED;
  status = 0; // 1st pass
  ledBlink(1);
  BT1.println("Start First Pass");
  Serial.println("Start First Pass");
  readLFSsensors();
  mazeSolve(); // First pass to solve the maze
  ledBlink(2);
  BT1.println("End First Pass");
  Serial.println("End First Pass");
    manualCmd ();
    command = "";
  BT1.println("Starting 2nd Pass");
  Serial.println("Starting 2nd Pass");
  pathIndex = 0;
  status = 0;
  mazeOptimization(); //run the maze as fast as possible
  ledBlink(3);
  BT1.println("End 2nd Pass");
  Serial.println("End 2nd Pass");
    manualCmd ();
    command = "";
  mode = STOPPED;
  pathIndex = 0;
  pathLength = 0;
Functions
C/C++
void mazeSolve(void)
    while (!status)
        readLFSsensors();
        switch (mode)
          case NO_LINE:
            motorStop();
            goAndTurn (LEFT, 180);
            recIntersection('B');
            break;
          case CONT_LINE:
            runExtraInch();
            readLFSsensors();
            if (mode != CONT_LINE) {goAndTurn (LEFT, 90); recIntersection('L');} // or it is a "T" or "Cross"). In both cases, goes to LEFT
            else mazeEnd();
            break;
         case RIGHT_TURN:
            runExtraInch();
            readLFSsensors();
            if (mode == NO_LINE) {goAndTurn (RIGHT, 90); recIntersection('R');}
            else recIntersection('S');
            break;
         case LEFT_TURN:
            break;
         case FOLLOWING_LINE:
            followingLine();
            break;
void recIntersection(char direction)
  path[pathLength] = direction; // Store the intersection in the path variable.
  pathLength ++;
  simplifyPath(); // Simplify the learned path.
void mazeEnd(void)
  motorStop();
  BT1.print("The End  ==> Path: ");
  for(int i=0;i<pathLength;i++)
    BT1.print(path[i]);
    //Serial.print(path[i]);
  BT1.println("");
  Serial.print("  pathLenght ==> ");
  Serial.println(pathLength);
  status = 1;
  mode = STOPPED;
void followingLine(void)
   //readLFSsensors();
   calculatePID();
   motorPIDcontrol();
// Path simplification.  The strategy is that whenever we encounter a
// sequence xBx, we can simplify it by cutting out the dead end.  For
// example, LBL -> S, because a single S bypasses the dead end
// represented by LBL.
void simplifyPath()
  // only simplify the path if the second-to-last turn was a 'B'
  if(pathLength < 3 || path[pathLength-2] != 'B')
    return;
  int totalAngle = 0;
  int i;
  for(i=1;i<=3;i++)
    switch(path[pathLength-i])
      case 'R':
        totalAngle += 90;
	break;
      case 'L':
	totalAngle += 270;
	break;
      case 'B':
	totalAngle += 180;
	break;
  // Get the angle as a number between 0 and 360 degrees.
  totalAngle = totalAngle % 360;
  // Replace all of those turns with a single one.
  switch(totalAngle)
    case 0:
	path[pathLength - 3] = 'S';
	break;
    case 90:
	path[pathLength - 3] = 'R';
	break;
    case 180:
	path[pathLength - 3] = 'B';
	break;
    case 270:
	path[pathLength - 3] = 'L';
	break;
  // The path is now two steps shorter.
  pathLength -= 2;
void mazeOptimization (void)
  while (!status)
    readLFSsensors();
    switch (mode)
        followingLine();
        break;
      case CONT_LINE:
        if (pathIndex >= pathLength) mazeEnd ();
        else {mazeTurn (path[pathIndex]); pathIndex++;}
        break;
      case LEFT_TURN:
        break;
      case RIGHT_TURN:
        break;
void mazeTurn (char dir)
  switch(dir)
    case 'L': // Turn Left
       break;
    case 'R': // Turn Right
       break;
    case 'B': // Turn Back
       goAndTurn (RIGHT, 800);
       break;
    case 'S': // Go Straight
       runExtraInch();
       break;
GeneralFunctions.
C/C++
void ledBlink(int times)
   for (int i = 0; i<times; i++)
      digitalWrite (ledPin, HIGH);
      delay (500);
      digitalWrite (ledPin, LOW);
      delay (500);
 void checkBTcmd()
   while (BT1.available())   //Check if there is an available byte to read
     delay(10); //Delay added to make thing stable
     char c = BT1.read(); //Conduct a serial read
     device += c; //build the string.
   if (device.length() > 0)
     Serial.print("Command received from BT ==> ");
     Serial.println(device);
     command = device;
     device ="";  //Reset the variable
     BT1.flush();
void manualCmd()
  switch (command[0])
    case 'g':
      mode = FOLLOWING_LINE;
      break;
    case 's':
      motorStop(); //turn off both motors
      break;
    case 'f':
      motorForward();
      break;
    case 'r':
      motorTurn(RIGHT, 30);
      motorStop();
      break;
   case 'l':
      motorTurn(LEFT, 30);
      motorStop();
      break;
    case 'b':
      motorBackward();
      break;
    case 'p':
      Kp = command[2];
      break;
    case 'i':
      Ki = command[2];
      break;
    case 'd':
      Kd = command[2];
      break;
void sendBTdata (int data) // send data to BT
    BT1.print("Data from Arduino");
    BT1.print(data);
    BT1.print(" xx");
    BT1.println('\n');
void calculatePID()
  P = error;
  I = I + error;
  D = error-previousError;
  PIDvalue = (Kp*P) + (Ki*I) + (Kd*D);
  previousError = error;
void checkPIDvalues()
  BT1.print("PID: ");
  BT1.print(Kp);
  BT1.print(" - ");
  BT1.print(Ki);
  BT1.print(" - ");
  BT1.println(Kd);
  Serial.print("PID: ");
  Serial.print(Kp);
  Serial.print(" - ");
  Serial.print(Ki);
  Serial.println(Kd);
void testLineFollowSensors()
     int LFS0 = digitalRead(lineFollowSensor0);
     int LFS1 = digitalRead(lineFollowSensor1);
     int LFS2 = digitalRead(lineFollowSensor2);
     int LFS3 = digitalRead(lineFollowSensor3);
     int LFS4 = digitalRead(lineFollowSensor4);
     Serial.print ("LFS: L  0 1 2 3 4  R ==> ");
     Serial.print (LFS0);
     Serial.print (" ");
     Serial.print (LFS1);
     Serial.print (" ");
     Serial.print (LFS2);
     Serial.print (" ");
     Serial.print (LFS3);
     Serial.print (" ");
     Serial.print (LFS4);
     Serial.print ("  ==> ");
     Serial.print (" P: ");
     Serial.print (P);
     Serial.print (" I: ");
     Serial.print (I);
     Serial.print (" D: ");
     Serial.print (D);
     Serial.print (" PID: ");
     Serial.println (PIDvalue);
sensorFuntions
C/C++
/* read line sensors values
Sensor Array 	Error Value
0 0 0 0 1	 4
0 0 0 1 1	 3
0 0 0 1 0	 2
0 0 1 1 0	 1
0 0 1 0 0	 0
0 1 1 0 0	-1
0 1 0 0 0	-2
1 1 0 0 0	-3
1 0 0 0 0	-4
1 1 1 1 1        0 Robot found continuous line - test if an intersection or end of maze
0 0 0 0 0        0 Robot found no line: turn 180o
void readLFSsensors()
  LFSensor[0] = digitalRead(lineFollowSensor0);
  LFSensor[1] = digitalRead(lineFollowSensor1);
  LFSensor[2] = digitalRead(lineFollowSensor2);
  LFSensor[3] = digitalRead(lineFollowSensor3);
  LFSensor[4] = digitalRead(lineFollowSensor4);
  farRightSensor = analogRead(farRightSensorPin);
  farLeftSensor = analogRead(farLeftSensorPin);
  if     ((LFSensor[0]== 1 )&&(LFSensor[1]== 1 )&&(LFSensor[2]== 1 )&&(LFSensor[3]== 1 )&&(LFSensor[4]== 1 ))  {mode = CONT_LINE; error = 0;}
  else if((LFSensor[0]== 0 )&&                                                   (farRightSensor < THRESHOLD)) {mode = RIGHT_TURN; error = 0;}
  else if ((farLeftSensor <  THRESHOLD)                                                  &&(LFSensor[4]== 0 )) {mode = LEFT_TURN; error = 0;}
  else if((LFSensor[0]== 0 )&&(LFSensor[1]== 0 )&&(LFSensor[2]== 0 )&&(LFSensor[3]== 0 )&&(LFSensor[4]== 0 ))  {mode = NO_LINE; error = 0;}
  else if((LFSensor[0]== 0 )&&(LFSensor[1]== 0 )&&(LFSensor[2]== 0 )&&(LFSensor[3]== 0 )&&(LFSensor[4]== 1 ))  {mode = FOLLOWING_LINE; error = 4;}
  else if((LFSensor[0]== 0 )&&(LFSensor[1]== 0 )&&(LFSensor[2]== 0 )&&(LFSensor[3]== 1 )&&(LFSensor[4]== 1 ))  {mode = FOLLOWING_LINE; error = 3;}
  else if((LFSensor[0]== 0 )&&(LFSensor[1]== 0 )&&(LFSensor[2]== 0 )&&(LFSensor[3]== 1 )&&(LFSensor[4]== 0 ))  {mode = FOLLOWING_LINE; error = 2;}
  else if((LFSensor[0]== 0 )&&(LFSensor[1]== 0 )&&(LFSensor[2]== 1 )&&(LFSensor[3]== 1 )&&(LFSensor[4]== 0 ))  {mode = FOLLOWING_LINE; error = 1;}
  else if((LFSensor[0]== 0 )&&(LFSensor[1]== 0 )&&(LFSensor[2]== 1 )&&(LFSensor[3]== 0 )&&(LFSensor[4]== 0 ))  {mode = FOLLOWING_LINE; error = 0;}
  else if((LFSensor[0]== 0 )&&(LFSensor[1]== 1 )&&(LFSensor[2]== 1 )&&(LFSensor[3]== 0 )&&(LFSensor[4]== 0 ))  {mode = FOLLOWING_LINE; error =- 1;}
  else if((LFSensor[0]== 0 )&&(LFSensor[1]== 1 )&&(LFSensor[2]== 0 )&&(LFSensor[3]== 0 )&&(LFSensor[4]== 0 ))  {mode = FOLLOWING_LINE; error = -2;}
  else if((LFSensor[0]== 1 )&&(LFSensor[1]== 1 )&&(LFSensor[2]== 0 )&&(LFSensor[3]== 0 )&&(LFSensor[4]== 0 ))  {mode = FOLLOWING_LINE; error = -3;}
  else if((LFSensor[0]== 1 )&&(LFSensor[1]== 0 )&&(LFSensor[2]== 0 )&&(LFSensor[3]== 0 )&&(LFSensor[4]== 0 ))  {mode = FOLLOWING_LINE; error = -4;}
  Serial.print (farLeftSensor);
  Serial.print (" <== LEFT  RIGH==> ");
  Serial.print (farRightSensor);
  Serial.print ("  mode: ");
  Serial.print (mode);
  Serial.print ("  error:");
  Serial.println (error);
void readLateralSensors(void)
RobotDefines.h
C/C++
int mode = 0;
# define STOPPED 0
# define FOLLOWING_LINE 1
# define NO_LINE 2
# define CONT_LINE 3
# define POS_LINE 4
# define RIGHT_TURN 5
# define LEFT_TURN 6
const int power = 250;
const int iniMotorPower = 250;
const int adj = 0;
float adjTurn = 8;
int extraInch = 200;
int adjGoAndTurn = 800;
const int ledPin = 13;
const int buttonPin = 9;
// LFSensor more to the Left is "0"
const int lineFollowSensor0 = 12;
const int lineFollowSensor1 = 18;
const int lineFollowSensor2 = 17;
const int lineFollowSensor3 = 16;
const int lineFollowSensor4 = 19;
const int farRightSensorPin = 0; //Analog Pin A0
const int farLeftSensorPin = 1; //Analog Pin A0
const int THRESHOLD = 150;
int farRightSensor = 0;
int farLeftSensor = 0;
int LFSensor[5]={0, 0, 0, 0, 0};
// PID controller
float Kp=50;
float Ki=0;
float Kd=0;
float error=0, P=0, I=0, D=0, PIDvalue=0;
float previousError=0, previousI=0;
#define RIGHT 1
#define LEFT -1
Servo leftServo;
Servo rightServo;
//Specific Maze Phase 2 (optimization) definitions and variables
unsigned char dir;
// The path variable will store the path that the robot has taken:
//  'L' for left
//  'R' for right
//  'S' for straight (going straight through an intersection)
//  'B' for back (U-turn)
char path[100] = "";
unsigned char pathLength = 0; // the length of the path
int pathIndex = 0;
unsigned int status = 0; // solving = 0; reach end = 1
MotorFuntions
C/C++
void motorStop()
  leftServo.writeMicroseconds(1500);
  rightServo.writeMicroseconds(1500);
  delay(200);
void motorForward()
  leftServo.writeMicroseconds(1500 - (power+adj));
  rightServo.writeMicroseconds(1500 + power);
void motorBackward()
  leftServo.writeMicroseconds(1500 + power);
  rightServo.writeMicroseconds(1500 - power);
void motorFwTime (unsigned int time)
  motorForward();
  delay (time);
  motorStop();
void motorBwTime (unsigned int time)
  motorBackward();
  delay (time);
  motorStop();
void motorTurn(int direction, int degrees)
  leftServo.writeMicroseconds(1500 - (iniMotorPower+adj)*direction);
  rightServo.writeMicroseconds(1500 - iniMotorPower*direction);
  delay (round(adjTurn*degrees+20));
  motorStop();
void motorPIDcontrol()
  int leftMotorSpeed = 1500 - (iniMotorPower+adj) - PIDvalue;
  int rightMotorSpeed = 1500 + iniMotorPower - PIDvalue;
  // The motor speed should not exceed the max PWM value
   constrain(leftMotorSpeed, 1000, 2000);
   constrain(rightMotorSpeed, 1000, 2000);
  leftServo.writeMicroseconds(leftMotorSpeed);
  rightServo.writeMicroseconds(rightMotorSpeed);
  //Serial.print (PIDvalue);
  //Serial.print (" ==> Left, Right:  ");
  //Serial.print (leftMotorSpeed);
  //Serial.print ("   ");
  //Serial.println (rightMotorSpeed);
void runExtraInch(void)
  motorPIDcontrol();
  delay(extraInch);
  motorStop();
void goAndTurn(int direction, int degrees)
  motorPIDcontrol();
  delay(adjGoAndTurn);
  motorTurn(direction, degrees);
Credits
Muhammad Sheraz
Muhammad Sheraz
11 projects • 45 followers
Student of Bsc electrical engineering at 7th semester In NFCIET Multan Pakistan. CONTACT: sheraz9345@gmail.com
Thanks to Maze.
Comments
Add projectSign up / Login
