Peter Ma
Published © GPL3+
Proximity Candy Bot
Our robotic arm will automatically welcome our guests with candies
IntermediateFull instructions provided16 hours265
Things used in this project
Hardware components
Proximity Sensor- Pyroelectric Infrared Sensor Module
KEMET Electronics Corporation Proximity Sensor- Pyroelectric Infrared Sensor Module
×1
Raspberry Pi 3 Model B
×1
Seeed Grove Shield for Pi
×1
Dobot Magician
×1
3D Printer (generic)
Story
Read more
Schematics
Candy bot robotic arm schema
Code
candybot.py
Python
candybot file
import time
import os
import grovepi
from grovepi import *
from datetime import datetime
import firebase_admin
from firebase_admin import credentials
from firebase_admin import db
cred = credentials.Certificate("/path/to/your_account-service_key")
# Initialize the app with a service account, granting admin privileges
firebase_admin.initialize_app(cred, {
    'databaseURL': 'https://your_candy_bot.firebaseio.com/'
ref = db.reference('/candy')
#Sensor connected to A0 Port
sensor = 14		# Pin 14 is A0 Port.
led = 4
grovepi.pinMode(sensor,"INPUT")
pinMode(led,"OUTPUT")
count = 0
last_value = 0
while True:
    try:
        sensor_value = grovepi.analogRead(sensor)
        print ("sensor_value = %d" %sensor_value)
        if sensor_value > 200:
        	count += 1
        if sensor_value <= 200 and last_value > 200:
        	count = 0 #reset the count
        if count > 2:
            count = 0
            digitalWrite(led,1)		# Send HIGH to switch on LED
            print('called robotic arm')
            os.system('python3 Script.py --Json candybot.json')
            digitalWrite(led,0)		# Send LOW to switch off LED
            ref.set({'count': 1, 'time': datetime.now().strftime("%d-%b-%Y (%H:%M:%S.%f)")})
        last_value = sensor_value
        time.sleep(.5)
    except IOError:
        print ("Error")
Dobot Magician Scirpt
Python
script to control the DobotMagician
import threading
import DobotDllType as dType
import time
import argparse
import json
from pprint import pprint
from collections import OrderedDict
class ScriptRobot():
    global CON_STR
    CON_STR = {
    dType.DobotConnect.DobotConnect_NoError:  "DobotConnect_NoError",
    dType.DobotConnect.DobotConnect_NotFound: "DobotConnect_NotFound",
    dType.DobotConnect.DobotConnect_Occupied: "DobotConnect_Occupied"}
    def __init__(self,Json):
        self.Json=Json
        self.api=dType.load()
        self.state=""
    def Connect(self):
        #Connect Dobot
        self.state = dType.ConnectDobot(self.api, "", 115200)[0]
        dType.GetDeviceSN(self.api)
        dType.GetDeviceName(self.api)
        dType.GetDeviceVersion(self.api)
        dType.GetDeviceWithL(self.api)
        dType.GetPoseL(self.api)
        dType.GetKinematics(self.api)
        #dType.GetHOMEParams(self.api)
        print("Connect status:",CON_STR[self.state])
        if (self.state == dType.DobotConnect.DobotConnect_NoError):
            dType.SetQueuedCmdClear(self.api)
            return True
        else :
            dType.DisconnectDobot(self.api)
            return False
    def _MOVJ(self,data):
           dType.SetPTPCmd(self.api,dType.PTPMode.PTPMOVJXYZMode,float(data['X']),float(data['Y']),float(data['Z']),float(data['R']), isQueued = 1)
    def _MOVL(self,data):
           dType.SetPTPCmd(self.api,dType.PTPMode.PTPMOVLXYZMode,float(data['X']),float(data['Y']),float(data['Z']),float(data['R']), isQueued = 1)
    def _ARC(self,value,data):
           dType.SetARCCmd(self.api,[float(data['X']),float(data['Y']),float(data['Z']),0],[float(data['_X']),float(data['_Y']),float(data['_Z']),0], isQueued = 1)
    def moveTypes(self,value,data):
        if value=="MOVJ" :
			return self._MOVJ(data)
        elif value=="MOVL" :
            return self._MOVL(data)
        elif value=="ARC" :
            return self._ARC(value,data)
    def ParserMove(self):
        json_data = open(self.Json)
        data = json.load(json_data, object_pairs_hook=OrderedDict)
       #def SetPTPCoordinateParams(api, xyzVelocity, xyzAcceleration, rVelocity,  rAcceleration,  isQueued=0):
        for move in data:
            #print "TEST_:"+data[move]['MotionStyle'],data[move]
            if data[move]['MotionStyle']=="MOVJ" :
                lastIndex=dType.SetPTPCmd(self.api,dType.PTPMode.PTPMOVJXYZMode,float(data[move]['X']),float(data[move]['Y']),float(data[move]['Z']),float(data[move]['R']), isQueued = 1)[0]
                dType.SetEndEffectorGripper(self.api, data[move]["Enabled"], data[move]['Gripper'], isQueued= 1)
                print(data[move]["Gripper"])
            if data[move]['PauseTime']!=0:
                lastIndex=dType.SetWAITCmd(self.api,float(data[move]['PauseTime']), isQueued = 1)[0]
            if data[move]['MotionStyle']=="MOVL" :
                lastIndex=dType.SetPTPCmd(self.api,dType.PTPMode.PTPMOVLXYZMode,float(data[move]['X']),float(data[move]['Y']),float(data[move]['Z']),float(data[move]['R']), isQueued = 1)[0]
            if data[move]['MotionStyle']=="MOVJANGLE" :
                lastIndex=dType.SetARCCmd(self.api,[float(data[move]['X']),float(data[move]['Y']),float(data[move]['Z']),0],[float(data[move]['_X']),float(data[move]['_Y']),float(data[move]['_Z']),0], isQueued = 1)[0]
        dType.SetQueuedCmdStartExec(self.api)
        while lastIndex > dType.GetQueuedCmdCurrentIndex(self.api)[0]:
#           dType.GetPose(self.api) Obtener la Posicion actual del robot
            dType.dSleep(100)
        dType.SetQueuedCmdStopExec(self.api)
if __name__ == "__main__":
    parser = argparse.ArgumentParser(description='Script Robot')
    parser.add_argument('--Json', required=True, help='File name export json')
    args = parser.parse_args()
    R = ScriptRobot(args.Json)
    R.Connect()
    R.ParserMove()
Firebase test code
Python
Fire base test code
Kemet Candy Bot repo
Credits
Peter Ma
Peter Ma
36 projects • 245 followers
Prototype Hacker, Hackathon Goer, World Traveler, Ecological balancer, integrationist, technologist, futurist.
Thanks to GeoNomad.
Comments
Add projectSign up / Login
