Shahariar
Published © CC BY
Washing Machine Timer
Replacement for broken mechanical timer of a washing machine with electronic timer.
IntermediateFull instructions provided5 hours3,252
Things used in this project
Hardware components
Arduino Pro Mini 328 - 5V/16MHz
SparkFun Arduino Pro Mini 328 - 5V/16MHz
×1
1306 OLED Display
×1
Gravity:Digital Push Button (Yellow)
DFRobot Gravity:Digital Push Button (Yellow)
×2
Grove - 2-Channel SPDT Relay
Seeed Grove - 2-Channel SPDT Relay
×1
5V 2.5A Switching Power Supply
Digilent 5V 2.5A Switching Power Supply
×1
SparkFun USB UART Serial Breakout - CY7C65213
×1
HC-05 Bluetooth Module
×1
Arduino IDE
Arduino IDE
Soldering iron (generic)
Hot glue gun (generic)
Tape, Double Sided
Tape, Double Sided
Tape, Green
Tape, Green
Story
Read more
Schematics
Washing machine internal schematic
electronic timer schematic
Code
Untitled file
C/C++
#include "U8glib.h"
//SSD1306 oled waveshare(clk,din,cs,d/c,res);
U8GLIB_SSD1306_128X64 u8g(A4,A5,12,11,10);
volatile int rbc = 0;
volatile int bbc = 0;
 int sec =0;
 int mi = 0;
 int motor_rotation = 0;
  u8g.setRot180();
  analogReference(INTERNAL);
  pinMode(2,INPUT_PULLUP);
  pinMode(3,INPUT_PULLUP);
  attachInterrupt(0, ISR_SW_RED,FALLING);
  attachInterrupt(1, ISR_SW_BLACK,FALLING);
  pinMode(5,OUTPUT);
  digitalWrite(5,LOW);
  pinMode(4,OUTPUT);
  digitalWrite(4,LOW);
void loop(void)
 while(!rbc)
   // show timer set menu
    u8g.firstPage();
    do {
      draw_menu();
       } while( u8g.nextPage() );
   // show user proper operation message
     if (rbc>0 && bbc==0)
         u8g.firstPage();
        do {
            draw_message();
    delay(2000);
    rbc=0; //u8g.clear();
 // start timer
 if(rbc>0)
       sec =59;
       mi = bbc-1;
    while(mi>=0)
     // show countdown timer message
        unsigned long temp = millis()+1000;
        while(temp>=millis())
         u8g.firstPage();
         do {
             draw_timer();
         sec=sec-1;
         if(sec%5==0)
         control_motor(); // call every 5 sec
         if (sec <= 0)
             sec = 59;
             mi = mi - 1;
    rbc = 0; bbc = 0;
    mi = 0 ; sec = 0;
    digitalWrite(5,LOW);digitalWrite(6,LOW);
}// end of loop
void draw_menu(void)
 u8g.setFont(u8g_font_timB24);
 if (bbc<10)
 u8g.drawStr( 22,30,"0");
 u8g.setPrintPos(38,30);u8g.print(bbc);
 else
   u8g.setPrintPos(22,30);u8g.print(bbc);
 u8g.drawStr( 54,30,":00");
 u8g.setFont(u8g_font_8x13);
 u8g.drawStr( 0,62," 'WASHING TIMER'");
 u8g.setFont(u8g_font_5x8);
 u8g.drawStr( 0,47,"Red:START  Black:SET TIME");
void draw_message(void)
   u8g.drawStr( 0,10," SET WASH TIMER");
   u8g.drawStr( 0,23,"FIRST BY PUSHING");
   u8g.drawStr( 0,36,"THE BLACK BUTTON");
 //  u8g.setFont(u8g_font_8x13);
void draw_timer(void)
      if (mi<10)
       u8g.setPrintPos(38,30);u8g.print(mi);
       else
      u8g.setPrintPos(22,30);u8g.print(mi);
      u8g.drawStr( 54,30,":");
            if (sec<10)
       u8g.drawStr( 70,30,"0");
       u8g.setPrintPos(86,30);u8g.print(sec);
       else
       u8g.setPrintPos(70,30);u8g.print(sec);
       if(motor_rotation==0)
        u8g.drawStr( 0,47,"  WASHING MOTOR CW Spin");
        digitalWrite(5,HIGH);
       if(motor_rotation==1)
        u8g.drawStr( 0,47,"  WASHING MOTOR STOPPED ");
        digitalWrite(5,LOW);digitalWrite(4,LOW);
       if(motor_rotation==2)
        u8g.drawStr( 0,47,"  WASHING MOTOR CCW Spin");
        digitalWrite(4,HIGH);
       if(motor_rotation==3)
void ISR_SW_RED()
  sei();
  rbc++;
  cli();
void ISR_SW_BLACK()
  sei();
  bbc++;
  cli();
void control_motor()
 motor_rotation++;
 if(motor_rotation>3)
 motor_rotation = 0;
Credits
Shahariar
Shahariar
47 projects • 153 followers
"What Kills a 'Great life' is a 'Good Life', which is Living a Life Inside While Loop"
Comments
Add projectSign up / Login
