Pratik_Roy98
Published © LGPL
WaterTank Supervisory control and Data visualization
WaterTank Supervisory control and Data visulaization using NODE-RED and MQTT protocol with data storage in MySQL.
IntermediateFull instructions provided15 hours502
Things used in this project
Hardware components
Flow Sensor, Analog Output
×1
Soil Moisture & Temperature Sensor
Seeed Soil Moisture & Temperature Sensor
×1
Ultrasonic Sensor - HC-SR04 (Generic)
×1
Solenoid Valve, 2 Way
×1
water pump
×1
NodeMCU ESP8266 Breakout Board
×1
Raspberry Pi 3 Model B
×1
4-CHANNEL RELAY CONTROLLER FOR I2C
ControlEverything.com 4-CHANNEL RELAY CONTROLLER FOR I2C
×1
Node-RED
Node-RED
Arduino IDE
Arduino IDE
MQTT
MQTT
Story
Read more
Code
Tank Control
C/C++
Node MCU controls for the switches using SUB client MQTT
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
const char* ssid = "ssid";
const char* password = "pwd";
const char* mqtt_server = "192.168.x.xxx";
WiFiClient espClient;
PubSubClient client(espClient);
const int valve1=14;//D5
const int pump=12;//D6
const int valve2=13;//D7
long now = millis();
long lastMeasure = 0;
  pinMode(valve1,OUTPUT);
  pinMode(valve2,OUTPUT);
  pinMode(pump,OUTPUT);
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.print("WiFi connected - ESP IP address: ");
  Serial.println(WiFi.localIP());
void callback(String topic, byte* message, unsigned int length) {
  Serial.print("Message arrived on topic: ");
  Serial.print(topic);
  Serial.print(". Message: ");
  String messageTemp;
  for (int i = 0; i < length; i++) {
    Serial.print((char)message[i]);
    messageTemp += (char)message[i];
  Serial.println();
  // Feel free to add more if statements to control more GPIOs with MQTT
  // If a message is received on the topic valves/pump, you check if the message is either on or off. Turns the valves/pump GPIO according to the message
  if(topic=="valve1"){
      Serial.print("Switching valve1 to ");
      if(messageTemp == "1"){
        digitalWrite(valve1, HIGH);
        Serial.print("On");
      else if(messageTemp == "0"){
        digitalWrite(valve1, LOW);
        Serial.print("Off");
  if(topic=="valve2"){
      Serial.print("Switching valve2 to  ");
        digitalWrite(valve2, HIGH);
        Serial.print("On");
        digitalWrite(valve2, LOW);
  if(topic=="pump"){
      Serial.print("Switching pump to  ");
        digitalWrite(pump, HIGH);
        Serial.print("On");
        digitalWrite(pump, LOW);
  Serial.println();
// This functions reconnects your ESP8266 to your MQTT broker
// Change the function below if you want to subscribe to more topics with your ESP8266
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("ESP8266Client")) {
      Serial.println("connected");
      // Subscribe or resubscribe to a topic
      // You can subscribe to more topics
      //Serial.println("msg valve1");
      client.subscribe("valve1");
      //Serial.println("msg pump");
      client.subscribe("pump");
      //Serial.println("msg valve2");
      client.subscribe("valve2");
    } else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(3000);
  if (!client.connected()) {
    reconnect();
  if(!client.loop())
    client.connect("ESP8266Client");
Tank Data Visualization
C/C++
Node MCU data publish to dashboard using MQTT pub client.
const int trig_pin_u1 = 16;//D0
const int echo_pin_u1 = 5;//D1
const int trig_pin_u2 = 4;//D2
const int echo_pin_u2 = 0;//D3
long duration_u1, duration_u2;
int distance_u1, distance_u2;
  pinMode(trig_pin_u1, OUTPUT);
  pinMode(echo_pin_u1, INPUT);
  pinMode(trig_pin_u2, OUTPUT);
  pinMode(echo_pin_u2, INPUT);
  setup_wifi();
void setup_wifi() {
  delay(10);
  Serial.println();
    delay(500);
    Serial.print(".");
  Serial.println("");
void level()
  digitalWrite(trig_pin_u1, LOW);
  delayMicroseconds(2);
  digitalWrite(trig_pin_u1, HIGH);
  delayMicroseconds(10);
  duration_u1 = pulseIn(echo_pin_u1, HIGH);
  distance_u1 = (duration_u1 / 2) / 29.41;
  distance_u1=9-distance_u1;
  delay(500);
  digitalWrite(trig_pin_u2, LOW);
  digitalWrite(trig_pin_u2, HIGH);
  duration_u2 = pulseIn(echo_pin_u2, HIGH);
  distance_u2 = (duration_u2 / 2) / 29.41;
  distance_u2=9-distance_u2;
  Serial.println(distance_u2);
  if (!client.loop())
    level();
    static char d_u1[7];
    static char d_u2[7];
    dtostrf(distance_u1, 3, 0, d_u1);
    dtostrf(distance_u2, 3, 0, d_u2);
    Serial.println(d_u1);
    Serial.println(d_u2);
    client.publish("u1", d_u1);
    client.publish("u2", d_u2);
Soil data
C/C++
Node MCU soil mositure data publlish
const long soil=A0;//A0
  pinMode(soil,INPUT);
  setup_wifi();
void setup_wifi() {
  delay(10);
  Serial.println();
    delay(500);
    Serial.print(".");
  Serial.println("");
void reconnect() {
     YOU MIGHT NEED TO CHANGE THIS LINE, IF YOU'RE HAVING PROBLEMS WITH MQTT MULTIPLE CONNECTIONS
     To change the ESP device ID, you will have to give a new name to the ESP8266.
     Here's how it looks:
     You can do it like this:
       if (client.connect("ESP1_Office")) {
     Then, for the other ESP:
       if (client.connect("ESP2_Garage")) {
      That should solve your MQTT multiple connections problem
    } else {
      delay(5000);
    reconnect();
  if(!client.loop())
    double soil_value=analogRead(soil);
    static char soil_v[7];
    dtostrf(soil_value, 6, 2, soil_v);
    client.publish("soil", soil_v);
    Serial.println(soil_value);
    delay(10000);
Flow sensor data
C/C++
Arduino Interrupt pin is used for Flow sensor data acquisition
#include <SoftwareSerial.h>
SoftwareSerial s(5,6);
unsigned long currentTime;
unsigned long cloopTime;
volatile int flow_frequency1;
unsigned int l_hour1;
const  int flowsensor1 = 2;
volatile int flow_frequency2;
unsigned int l_hour2;
const  int flowsensor2 = 2;
void flow1()
   flow_frequency1++;
void flow2()
   flow_frequency2++;
   pinMode(flowsensor1, INPUT);
   digitalWrite(flowsensor1, HIGH);
    pinMode(flowsensor2, INPUT);
   digitalWrite(flowsensor2, HIGH);
   Serial.begin(9600);
   s.begin(9600);
   attachInterrupt(0, flow1, RISING);
   attachInterrupt(1, flow2, RISING);
   sei(); // Enable interrupts
   currentTime = millis();
   cloopTime = currentTime;
void loop ()
   // Every second, calculate and print litres/hour
   if(currentTime >= (cloopTime + 1000))
      cloopTime = currentTime; // Updates cloopTime
      // Pulse frequency (Hz) = 7.5Q, Q is flow rate in L/min.
      l_hour1 = (flow_frequency1 * 60 / 7.5); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
      flow_frequency1 = 0; // Reset Counter
      Serial.print(l_hour1, DEC); // Print litres/hour
      Serial.println(" 1 L/hour ");
     // s.write(" 1 L/hour ");
       s.write(l_hour1);
      l_hour1 = (flow_frequency2 * 60 / 7.5); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
      flow_frequency2 = 0; // Reset Counter
      Serial.print(l_hour2, DEC); // Print litres/hour
      Serial.println(" 2 L/hour ");
      //s.write(" 2 L/hour ");
       s.write(l_hour2);
Flow sensor data
C/C++
Node MCU serially reading the data from Arduino UNO and publishing in the Dashboard using MQTT PUB.
SoftwareSerial s(D6,D5);
int flowdata1;
int flowdata2;
s.begin(9600);
Serial.begin(9600);
  setup_wifi();
void setup_wifi() {
  delay(10);
  Serial.println();
    delay(500);
    Serial.print(".");
  Serial.println("");
  //s.write("s");
  if (s.available()>0)
    flowdata1=s.read();
    flowdata2=s.read();
    Serial.println(flowdata1);
    Serial.println(flowdata2);
  if (!client.loop())
    static char d_f1[7];
    static char d_f2[7];
    dtostrf(flowdata1, 3, 0, d_f1);
    dtostrf(flowdata2, 3, 0, d_f2);
    Serial.println(d_f1);
    Serial.println(d_f2);
    client.publish("f1", d_f1);
    client.publish("f2", d_f2);
    delay(500);
Node Red flow code
JSON
        "id": "c855e9c5.011388",
        "type": "tab",
        "label": "Water scada",
        "disabled": false,
        "info": ""
        "id": "478bd80d.d86d98",
        "type": "ui_switch",
        "z": "c855e9c5.011388",
        "name": "valve1",
        "label": "Valve 1",
        "tooltip": "",
        "group": "3220d566.3df42a",
        "order": 26,
        "width": 3,
        "height": 2,
        "passthru": true,
        "decouple": "false",
        "topic": "",
        "style": "",
        "onvalue": "1",
        "onvalueType": "num",
        "onicon": "",
        "oncolor": "",
        "offvalue": "0",
        "offvalueType": "num",
        "officon": "",
        "offcolor": "",
        "x": 630,
        "y": 520,
        "wires": [
                "66a7b37f.1dbe3c",
                "e8c3b069.5d3e8"
        "id": "dfb491d5.b4d48",
        "name": "",
        "label": "Pump",
        "tooltip": "",
        "order": 28,
        "width": 3,
        "height": 2,
        "passthru": true,
        "topic": "",
        "style": "",
        "onvalue": "1",
        "onicon": "",
        "oncolor": "",
        "offvalue": "0",
        "officon": "",
        "offcolor": "",
        "x": 630,
        "y": 600,
        "wires": [
                "6f556440.9993ac",
                "89af0749.ee26f8"
        "id": "7e4780f6.043cf",
        "name": "",
        "label": "Valve 2",
        "tooltip": "",
        "order": 30,
        "width": 3,
        "height": 2,
        "passthru": true,
        "topic": "",
        "style": "",
        "onvalue": "1",
        "onicon": "",
        "oncolor": "",
        "offvalue": "0",
        "officon": "",
        "offcolor": "",
        "x": 640,
        "y": 700,
        "wires": [
                "53308e00.f4e86",
                "530efc4c.279294"
        "id": "dabdca45.254408",
        "type": "ui_gauge",
        "name": "f1",
        "order": 11,
        "width": 4,
        "height": 4,
        "gtype": "gage",
        "title": "",
        "label": "L/min",
        "format": "{{value}}",
        "min": 0,
        "max": "1000",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 930,
        "y": 200,
        "wires": []
        "id": "8ff1e461.64ee78",
        "type": "ui_chart",
        "name": "f1",
        "order": 38,
        "width": 4,
        "height": 4,
        "label": "Supply Tank Inlet Flow",
        "chartType": "line",
        "legend": "false",
        "xformat": "HH:mm:ss",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "3600",
        "cutout": 0,
        "useOneColor": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "useOldStyle": false,
        "outputs": 1,
        "x": 930,
        "y": 280,
        "wires": [
        "id": "4234eb21.e8d9a4",
        "type": "mqtt in",
        "name": "F1",
        "topic": "f1",
        "qos": "2",
        "datatype": "auto",
        "broker": "7cb01c98.abb984",
        "x": 800,
        "y": 240,
        "wires": [
                "dabdca45.254408",
                "8ff1e461.64ee78",
                "5aa82413.e6a61c"
        "id": "27afcc60.e307c4",
        "type": "ui_gauge",
        "name": "u2",
        "order": 13,
        "width": 4,
        "height": 4,
        "gtype": "wave",
        "title": "",
        "label": "cm",
        "min": 0,
        "max": "10",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1270,
        "y": 140,
        "wires": []
        "id": "f369e81e.4a7d28",
        "type": "ui_chart",
        "name": "u2",
        "order": 40,
        "width": 4,
        "height": 4,
        "label": "Supply Tank Level",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 1270,
        "y": 240,
        "wires": [
        "id": "391458e0.2db318",
        "type": "mqtt in",
        "name": "U2",
        "topic": "u2",
        "qos": "2",
        "datatype": "auto",
        "broker": "2be9a8c0.b410d8",
        "x": 1140,
        "y": 200,
        "wires": [
                "27afcc60.e307c4",
                "f369e81e.4a7d28",
                "876a0ee9.4524e"
        "id": "f1da0f51.9d594",
        "type": "ui_gauge",
        "name": "f2",
        "order": 15,
        "width": 4,
        "height": 4,
        "gtype": "gage",
        "title": "",
        "label": "L/min",
        "min": 0,
        "max": "1000",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1800,
        "y": 260,
        "wires": []
        "id": "edf62057.5ad1b",
        "type": "ui_chart",
        "name": "f2",
        "order": 42,
        "width": 4,
        "height": 4,
        "label": "Outlet Flow",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 1800,
        "y": 360,
        "wires": [
        "id": "d6780b91.d5c718",
        "type": "mqtt in",
        "name": "F2",
        "topic": "f2",
        "qos": "0",
        "datatype": "auto",
        "x": 1670,
        "y": 300,
        "wires": [
                "f1da0f51.9d594",
                "edf62057.5ad1b",
                "96ec9075.82fdf"
        "id": "ec92c37b.00f0b",
        "type": "ui_chart",
        "name": "u1",
        "order": 36,
        "width": 4,
        "height": 4,
        "label": "Reserve Tank Level",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 290,
        "y": 200,
        "wires": [
        "id": "17b8d16f.6cec6f",
        "type": "ui_gauge",
        "name": "u1",
        "order": 9,
        "width": 4,
        "height": 4,
        "gtype": "wave",
        "title": "",
        "label": "cm",
        "min": 0,
        "max": "10",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 290,
        "y": 80,
        "wires": []
        "id": "99f522db.3849f",
        "type": "mqtt in",
        "name": "U1",
        "topic": "u1",
        "qos": "2",
        "datatype": "auto",
        "x": 140,
        "y": 140,
        "wires": [
                "17b8d16f.6cec6f",
                "ec92c37b.00f0b",
                "fa621d17.e7174"
        "id": "19290f7d.3ef741",
        "type": "ui_text",
        "order": 2,
        "width": 4,
        "height": 1,
        "name": "u1",
        "label": "",
        "format": "Reserve Tank Level",
        "layout": "row-left",
        "x": 300,
        "y": 140,
        "wires": []
        "id": "3c6653ed.128c3c",
        "type": "ui_text",
        "order": 4,
        "width": 4,
        "height": 1,
        "name": "f1",
        "label": "",
        "format": "Supply Tank Inlet Flow",
        "x": 960,
        "y": 240,
        "wires": []
        "id": "4d9f620e.8a1f0c",
        "type": "ui_text",
        "order": 6,
        "width": 4,
        "height": 1,
        "name": "u2",
        "label": "",
        "format": "Supply Tank Level",
        "x": 1300,
        "y": 200,
        "wires": []
        "id": "1964483a.9f7538",
        "type": "ui_text",
        "order": 8,
        "width": 4,
        "height": 1,
        "name": "f2",
        "label": "",
        "format": "Outlet Flow",
        "x": 1820,
        "y": 320,
        "wires": []
        "id": "365f0927.ca4716",
        "type": "ui_gauge",
        "name": "soil",
        "group": "b935fee8.94039",
        "order": 6,
        "width": 4,
        "height": 4,
        "gtype": "donut",
        "title": "",
        "label": "MU",
        "min": 0,
        "max": "1000",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1190,
        "y": 800,
        "wires": []
        "id": "f726206d.21911",
        "type": "ui_chart",
        "name": "soil",
        "order": 14,
        "width": 30,
        "height": 5,
        "label": "Soil moisture",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "removeOlderUnit": "86400",
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 1190,
        "y": 880,
        "wires": [
        "id": "4d9aef11.e81fc",
        "type": "mqtt in",
        "name": "soil",
        "topic": "soil",
        "qos": "0",
        "datatype": "auto",
        "x": 1010,
        "y": 840,
        "wires": [
                "365f0927.ca4716",
                "f726206d.21911",
                "1ac88e8a.700581"
        "id": "8910f631.89f088",
        "type": "ui_text",
        "order": 3,
        "width": 4,
        "height": 1,
        "name": "soil",
        "label": "",
        "format": "Soil Moisture",
        "x": 1220,
        "y": 840,
        "wires": []
        "id": "d5622bb9.f0c828",
        "type": "moment",
        "name": "",
        "topic": "",
        "input": "payload",
        "inputType": "msg",
        "inTz": "Asia/Calcutta",
        "adjAmount": "",
        "format": "DD/MM/YYYY HH:mm:ss",
        "locale": "en_IN",
        "output": "payload",
        "outputType": "msg",
        "outTz": "Asia/Calcutta",
        "x": 380,
        "y": 860,
        "wires": [
                "d1e1e651.de1458",
                "b1947baf.8e27f8"
        "id": "c03d22c3.5548a",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "repeat": "1",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 170,
        "y": 860,
        "wires": [
                "d5622bb9.f0c828"
        "id": "9cb38005.a4c36",
        "type": "moment",
        "name": "",
        "topic": "",
        "input": "payload",
        "inputType": "msg",
        "adjAmount": "",
        "locale": "en_IN",
        "x": 360,
        "y": 820,
        "wires": [
                "72b2ba1f.09a4a4",
                "f85ed5b2.5063b8"
        "id": "3bff87fc.ef1478",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "",
        "repeat": "1",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 170,
        "y": 820,
        "wires": [
                "9cb38005.a4c36"
        "id": "72b2ba1f.09a4a4",
        "type": "ui_text",
        "order": 1,
        "width": 0,
        "height": 0,
        "name": "SCADA d/m",
        "label": "Date/Time",
        "format": "{{msg.payload}}",
        "layout": "row-right",
        "x": 620,
        "y": 800,
        "wires": []
        "id": "d1e1e651.de1458",
        "type": "ui_text",
        "order": 1,
        "width": 0,
        "height": 0,
        "name": "soil d/m",
        "x": 610,
        "y": 840,
        "wires": []
        "id": "6e3f2fee.53562",
        "type": "mysql",
        "mydb": "2e1d0fc3.f11a9",
        "name": "",
        "x": 570,
        "y": 980,
        "wires": [
        "id": "cc7909ca.6941f8",
        "name": "override",
        "label": "Override",
        "tooltip": "",
        "group": "82ffe014.05f45",
        "order": 3,
        "width": 7,
        "height": 4,
        "passthru": false,
        "topic": "override",
        "style": "",
        "onvalue": "1",
        "onicon": "",
        "oncolor": "",
        "offvalue": "0",
        "officon": "",
        "offcolor": "",
        "x": 100,
        "y": 420,
        "wires": [
                "d321a497.1a8d88",
                "bab5ef72.33a34"
        "id": "249010e9.b2078",
        "type": "ui_text",
        "order": 6,
        "width": 7,
        "height": 4,
        "name": "Status",
        "label": "Status",
        "layout": "col-center",
        "x": 390,
        "y": 420,
        "wires": []
        "id": "96ec9075.82fdf",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "$number(payload)",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1780,
        "y": 420,
        "wires": [
                "aa82cc44.de1bc"
        "id": "aa82cc44.de1bc",
        "type": "function",
        "name": "",
        "func": "global.set(\"flow2\",msg.payload);",
        "outputs": 1,
        "noerr": 0,
        "x": 1870,
        "y": 480,
        "wires": [
        "id": "66a7b37f.1dbe3c",
        "type": "mqtt out",
        "name": "",
        "topic": "valve1",
        "qos": "2",
        "retain": "true",
        "broker": "5e8739b4.e25bd8",
        "x": 800,
        "y": 520,
        "wires": []
        "id": "6f556440.9993ac",
        "type": "mqtt out",
        "name": "",
        "topic": "pump",
        "qos": "2",
        "retain": "true",
        "x": 810,
        "y": 600,
        "wires": []
        "id": "53308e00.f4e86",
        "type": "mqtt out",
        "name": "",
        "topic": "valve2",
        "qos": "2",
        "retain": "true",
        "x": 810,
        "y": 700,
        "wires": []
        "id": "d321a497.1a8d88",
        "type": "function",
        "name": "",
        "func": "if (msg.payload==1) {\n    msg.payload=\"Override\";\n} if(msg.payload===0) {\n    msg.payload=\"Automatic\";\n}\n\n   return(msg);",
        "outputs": 1,
        "noerr": 0,
        "x": 250,
        "y": 420,
        "wires": [
                "249010e9.b2078"
        "id": "b7b6d358.f3295",
        "type": "function",
        "name": "pump auto",
        "func": "var f1=global.get(\"level2\");\nvar ov=global.get(\"override\");\nif(ov==1)\n{\n}\nelse\n{\n    if(f1<3)\n    {\n        msg.payload=1;\n    }\n    else\n    {\n        msg.payload=0;\n    }\n\n    return(msg);\n}\n",
        "outputs": 1,
        "noerr": 0,
        "x": 350,
        "y": 560,
        "wires": [
                "478bd80d.d86d98",
                "dfb491d5.b4d48"
        "id": "876a0ee9.4524e",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1260,
        "y": 300,
        "wires": [
                "cda63c53.03412"
        "id": "cda63c53.03412",
        "type": "function",
        "name": "",
        "func": "global.set(\"level2\",msg.payload);",
        "outputs": 1,
        "noerr": 0,
        "x": 1350,
        "y": 360,
        "wires": [
        "id": "5aa82413.e6a61c",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 860,
        "y": 320,
        "wires": [
                "e1439452.e3d798"
        "id": "e1439452.e3d798",
        "type": "function",
        "name": "",
        "func": "global.set(\"flow1\",msg.payload);",
        "outputs": 1,
        "noerr": 0,
        "x": 950,
        "y": 380,
        "wires": [
        "id": "fa621d17.e7174",
        "type": "change",
        "name": "",
        "rules": [
This file has been truncated, please download it to see its full contents.
Credits
Pratik_Roy98
Pratik_Roy98
2 projects • 1 follower
IOT Hobbyist.
Comments
Add projectSign up / Login
