Seeed
Published
DIY a Simple Automatic Humidifier
This device can monitor the indoor temperature and humidity, it will automatically open the humidifier when the humidity below the values.
BeginnerProtip3 hours3
Things used in this project
Hardware components
Seeeduino V4.2
Seeeduino V4.2
×1
Grove - Water Atomization
×1
Grove - Temperature&Humidity Sensor (DHT11)
×1
I2C_LCD (With universal Grove cable)
×1
Grove – Button
×1
Arduino IDE
Arduino IDE
Story
Read more
Code
Humidifier.c
C/C++
 * Humidifier.c
 * This is a demo for Water
 * Copyright (c) 2015 seeed technology inc.
 * Author      : Jiankai Li
 * Create Time:  Oct 2015
 * Change Log :
 * The MIT License (MIT)
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 * THE SOFTWARE.
#include <Wire.h>
#include <I2C_LCD.h>
#include "DHT.h"
#define DEBUG 1
enum status{
  Standby            = 0,
  Humidification     = 1,
  AutoHumidification = 2,
typedef enum status SystemStatus;
SystemStatus WorkingStatus;
I2C_LCD LCD;
uint8_t I2C_LCD_ADDRESS = 0x51; //Device address configuration, the default value is 0x51.
#define DHTPIN A0     // what pin we're connected to
// Uncomment whatever type you're using!
#define OneSecond     1000
#define DHTTYPE       DHT11   // DHT 11
#define WaterAtomPin  5
#define ButtonPin     2
#define DateUpdateInterval 5   // unit seconds
#define HumidityLimen 50
uint8_t StartTime;
uint8_t ButtonFlag;
//For detials of the function useage, please refer to "I2C_LCD User Manual".
//You can download the "I2C_LCD User Manual" from I2C_LCD WIKI page: http://www.seeedstudio.com/wiki/I2C_LCD
//The usage of LCD.print() is same to the Serial.print().
//For more informations about print, please visit: http://www.arduino.cc/en/Serial/Print
DHT dht(DHTPIN, DHTTYPE);
void setup(void)
    Wire.begin();         //I2C controller initialization.
    LCD.CleanAll(WHITE);    //Clean the screen with black or white.
    LCD.WorkingModeConf(ON, ON, WM_CharMode);
    LCD.BacklightConf(LOAD_TO_RAM, 20);
    LCD.FontModeConf(Font_10x20, FM_ANL_AAA, BLACK_BAC);
    LCD.DispStringAt("SeeedStudio", 10, 20);    //Display "Sparking" on coordinate of (0, 20).
    delay(3000);
#if DEBUG
    Serial.begin(9600);
    Serial.println("Enable Debug");
#endif
    pinMode(WaterAtomPin,OUTPUT);
    pinMode(ButtonPin,INPUT);
    attachInterrupt(0,Buttonclick,RISING);
    dht.begin();
    DisableWaterAtom();
    WorkingStatus = Standby;
    StartTime = millis()/OneSecond + DateUpdateInterval;
void loop(void)
    float humidity    = dht.readHumidity();
    float temperature = dht.readTemperature();
    switch (WorkingStatus) {
    case Standby:
        if(((millis()/OneSecond) - StartTime) > DateUpdateInterval) {
            if (isnan(temperature) || isnan(humidity)) {
                Serial.println("Failed to read from DHT");
            } else {
                LCD.FontModeConf(Font_8x16_1, FM_ANL_AAA, BLACK_BAC);
                //Set the start coordinate.
                LCD.CharGotoXY(0,0);
                //Print string on I2C_LCD.
                LCD.print("Temp: ");
                //Print float on I2C_LCD.
                LCD.print(((float)((int)(temperature*10))/10), 1);
                LCD.println("`C");
                LCD.print("Hum : ");
                LCD.print(((float)((int)(humidity*10))/10), 1);
                LCD.println(" %");
                //Print the number of seconds since reset:
                LCD.FontModeConf(Font_6x8, FM_ANL_AAA, BLACK_BAC);
                LCD.CharGotoXY(0,48);
                LCD.print("Hum Limen : ");
                LCD.print(HumidityLimen);
                LCD.println(" %");
                //LCD.CharGotoXY(0,56);
                LCD.println("Prs BTN to moisturize");
                //LCD.CharGotoXY(68,48);
                //LCD.print(millis()/1000,DEC);
                StartTime = millis()/OneSecond;
#if DEBUG
            Serial.println("StandBy");
#endif
        if (ButtonFlag == true) {
            delay(200);
            ButtonFlag = false;
            WorkingStatus = Humidification;
        if (humidity <= HumidityLimen) {
            WorkingStatus = AutoHumidification;
        break;
    case Humidification:
        if(ButtonFlag == true) {
            delay(200);
            ButtonFlag = false;
            DisableWaterAtom();
        } else {
            EnableWaterAtom();
            LCD.println("`C");
            LCD.println(" %");
            LCD.println("Prs BTN to STOP");
#if DEBUG
    Serial.println("Humidification");
#endif
        break;
    case AutoHumidification:
            delay(200);
            ButtonFlag = false;
            DisableWaterAtom();
        } else {
            EnableWaterAtom();
            LCD.println("`C");
            LCD.println(" %");
        if (humidity > HumidityLimen) {
            DisableWaterAtom();
        break;
    default:
        break;
void EnableWaterAtom()
    digitalWrite(WaterAtomPin, HIGH);
void DisableWaterAtom()
    digitalWrite(WaterAtomPin, LOW);
void Buttonclick()
    ButtonFlag = true;
#if DEBUG
    Serial.println("Buttonclick");
#endif
  END FILE
Github file
https://github.com/Lee-Kevin/7.AutomaticHumidifier/tree/master/Code
Credits
Seeed
Seeed
60 projects • 74 followers
Seeed R&D Team
Comments
Add projectSign up / Login
