Seeed
Published © MIT
Using Magnetic to Measure Angle Changes
This demonstrates how to use the Grove - 12 bit Magnetic Rotary Position Sensor(AS5600) to accurately measure angle changes.
BeginnerProtip30 minutes2,261
Things used in this project
Hardware components
Seeed Grove - 12 bit Magnetic Rotary Position Sensor(AS5600)
×1
Seeeduino V4.2
Seeeduino V4.2
×1
Arduino IDE
Arduino IDE
Laser cutter (generic)
Story
Read more
Custom parts and enclosures
Calibrators design file
Code
readAngle.ino
C/C++
#include <Wire.h>
#include <AS5600.h>
  #define SERIAL SerialUSB
  #define SYS_VOL   3.3
#else
  #define SYS_VOL   5
#endif
AMS_5600 ams5600;
int ang, lang = 0;
  SERIAL.begin(115200);
  Wire.begin();
  SERIAL.println(">>>>>>>>>>>>>>>>>>>>>>>>>>> ");
  if(ams5600.detectMagnet() == 0 ){
    while(1){
        if(ams5600.detectMagnet() == 1 ){
            SERIAL.print("Current Magnitude: ");
            SERIAL.println(ams5600.getMagnitude());
            break;
        else{
            SERIAL.println("Can not detect magnet");
/* Function: convertRawAngleToDegrees
/* In: angle data from AMS_5600::getRawAngle
/* Out: human readable degrees as float
/* Description: takes the raw angle and calculates
/* float value in degrees.
float convertRawAngleToDegrees(word newAngle)
  /* Raw data reports 0 - 4095 segments, which is 0.087 of a degree */
  float retVal = newAngle * 0.087;
  ang = retVal;
  return ang;
    SERIAL.println(String(convertRawAngleToDegrees(ams5600.getRawAngle()),DEC));
Credits
Seeed
Seeed
82 projects • 80 followers
Seeed R&D Team
Comments
Add projectSign up / Login
