Peter MaMica Wong
Published © LGPL
Internet of Toiletries
Making your toiletries smart, automatically reorder them when they are under 1/4 of the weight.
AdvancedWork in progressOver 1 day1,257
Things used in this project
Hardware components
Android device
Android device
×1
LinkIt Smart 7688 Duo
MediaTek Labs LinkIt Smart 7688 Duo
×1
Arduino 101 & Genuino 101
×1
Arduino Wifi Shield 101
×1
uxcell 100kg 42mmx38mmx3mm Electronic Scale Body Load Cell Weighing Sensor
×2
Weight Weighing Load Cell Conversion Module Sensors
×1
Fusion 360
Autodesk Fusion 360
Arduino IDE
Arduino IDE
Android Studio
Android Studio
AWS SNS
Amazon Web Services AWS SNS
Amazon Web Services Login with Amazon
Amazon Dash Replenishment Service
Amazon Web Services Amazon Dash Replenishment Service
3D Printer (generic)
Story
Read more
Custom parts and enclosures
Unit Scale
Scale attached to the Unit, we are using 2 of these, the electrical scale is attached to the unit
Top portion
Top portion of the Unit
Top part lock
Locking mechanism for the top portion to attach to the bottom portion
Bottom portion
Bottom portion of Internet of Toiletries, this portion holds all the components as well as the battery.
Bottom Lock
Bottom lock for Internet of Toiletries, this part locks the bottom which contains all the components
Schematics
Wiring for Internet of Toiletries
This is the wiring for Internet of Toiletries from a photo perspective.
Img 20170225 183712 qgssvycheb
Wiring using Arduino 101
This is the wiring of Internet of Toiletries using Arduino 101
Img 20170226 012045 ftrccff0vx
Wiring between HX711 to Arduino
This is how HX711 connects to Arduino
61bliydhhbl  sl1001  1 b7fkv52qsb
HX711 diagram
How the scales are attached to HX711
510ihq5hshl  sl1038  ogv2giop9m
Code
Arduino Code For LinkIt Smart 7688 Duo and and Arduino 101
Arduino
This is the code used for Arduino C which uploads the IoT data to the cloud every 5 seconds (for the demo, in reality it would be much less)
Server code and Android code will be posted separately on github
#include "HX711.h"
#include <SPI.h>
#include <WiFi.h>
WiFiClient client;
char clientServer[] = "shrouded-citadel-97257.herokuapp.com";
IPAddress ip(192,168,2,3);
char ssid[] = "";     //  your network SSID (name)
char pass[] = "";    // your network password
int status = WL_IDLE_STATUS;
HX711 scale1;//(A1,A0);
HX711 scale2;//(A3,A2);
  Serial.begin(9600);
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while(true);
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
//    status = WiFi.begin(ssid);
    // wait 10 seconds for connection:
    delay(20000);
  printWifiStatus();
    // parameter "gain" is ommited; the default value 128 is used by the library
  // HX711.DOUT  - pin #A1
  // HX711.PD_SCK - pin #A0
  scale1.begin(A1, A0);
  scale2.begin(A3, A2);
  scale1.set_scale(2280.f);                      // this value is obtained by calibrating the scale with known weights; see the README for details
  scale2.tare();               // reset the scale to 0
  scale2.tare();
  Serial.print("one reading:\t");
  Serial.print(scale1.get_units(10), 1);
  Serial.print("two reading:\t");
  Serial.println(scale2.get_units(10), 1);
  String PostData = "{\"product1weight\":" + String(scale1.get_units(10), 1) + ",\"product2weight\":" + String(scale2.get_units(10), 1) + " }";
    Serial.println(PostData);
  if (client.connect(clientServer, 80)) {
    Serial.println("connected");
    Serial.println("POST /updatevalue HTTP/1.1");
    client.println("POST /updatevalue HTTP/1.1");
    client.println("Host: shrouded-citadel-97257.herokuapp.com");
    client.println("User-Agent: Internet of Toiltries");
    client.println("Content-Type: application/json");
    client.print("Content-Length: ");
    client.println(PostData.length());
    client.println();
    client.println(PostData);
    client.println();
    client.println("Connection: close");
    while(client.connected() && !client.available()) delay(1); //waits for data
    while (client.connected() && client.available()) { //connected or data available
      char c = client.read(); //gets byte from ethernet buffer
      Serial.print(c); //prints byte to serial monitor
    Serial.println();
    Serial.println("disconnecting.");
    Serial.println("==================");
    Serial.println();
    client.stop(); //stop client
  scale1.power_down();             // put the ADC in sleep mode
  scale2.power_down();             // put the ADC in sleep mode
  delay(5000);
  scale1.power_up();
  scale2.power_up();
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
    // check firmware version
  Serial.print("Firmware version: ");
  Serial.println(WiFi.firmwareVersion());
Android code
Java
This is the main portion for Android
package hack.internetoftoiletries;
import android.app.Activity;
import android.content.Context;
import android.content.SharedPreferences;
import android.os.AsyncTask;
import android.os.Bundle;
import android.os.Handler;
import android.support.v7.app.AppCompatActivity;
import android.util.Base64;
import android.util.Log;
import android.view.Gravity;
import android.view.View;
import android.view.ViewGroup;
import android.widget.Button;
import android.widget.ProgressBar;
import android.widget.TextView;
import android.widget.Toast;
import com.amazon.identity.auth.device.AuthError;
import com.amazon.identity.auth.device.api.Listener;
import com.amazon.identity.auth.device.api.authorization.AuthCancellation;
import com.amazon.identity.auth.device.api.authorization.AuthorizationManager;
import com.amazon.identity.auth.device.api.authorization.AuthorizeListener;
import com.amazon.identity.auth.device.api.authorization.AuthorizeRequest;
import com.amazon.identity.auth.device.api.authorization.AuthorizeResult;
import com.amazon.identity.auth.device.api.authorization.ProfileScope;
import com.amazon.identity.auth.device.api.authorization.Scope;
import com.amazon.identity.auth.device.api.authorization.User;
import com.amazon.identity.auth.device.api.workflow.RequestContext;
import com.amazon.identity.auth.device.authorization.api.AmazonAuthorizationManager;
import com.amazon.identity.auth.device.authorization.api.AuthorizationListener;
import com.amazon.identity.auth.device.authorization.api.AuthzConstants;
import org.codeandmagic.android.gauge.GaugeView;
import org.json.JSONArray;
import org.json.JSONException;
import org.json.JSONObject;
import java.io.BufferedOutputStream;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import java.io.OutputStream;
import java.io.UnsupportedEncodingException;
import java.net.HttpURLConnection;
import java.net.MalformedURLException;
import java.net.URL;
import java.net.URLEncoder;
import java.util.concurrent.Executors;
import java.util.concurrent.ScheduledExecutorService;
import java.util.concurrent.ScheduledFuture;
import java.util.concurrent.TimeUnit;
import okhttp3.FormBody;
import okhttp3.MediaType;
import okhttp3.OkHttpClient;
import okhttp3.Request;
import okhttp3.RequestBody;
import okhttp3.Response;
public class MainActivity extends AppCompatActivity {
    private static final String TAG = MainActivity.class.getName();
    public static final MediaType JSON
            = MediaType.parse("application/json; charset=utf-8");
    public static final MediaType STRING
            = MediaType.parse("application/x-www-form-urlencoded");
    public String DRS_URL = "https://dash-replenishment-service-na.amazon.com/replenish/";
    private TextView mProfileText;
    private TextView mProfileText2;
    private TextView mLogoutTextView;
    private ProgressBar mLogInProgress;
    private RequestContext requestContext;
    private boolean mIsLoggedIn;
    private View mLoginButton;
    private ViewGroup mWrapperProfile;
    private GaugeView mGaugeView1;
    private GaugeView mGaugeView2;
    private TextView product1;
    private TextView product2;
    private ScheduledFuture<?> future;
    private ScheduledExecutorService scheduler = Executors.newScheduledThreadPool(1);
    OkHttpClient client = new OkHttpClient();
    private String slot1 = "f76a78ff-d73b-4c64-967f-d28f54645c9d";
    private String slot2 = "59a29d6d-39f3-4adb-8b88-96fc5e2261cc";
        private AmazonAuthorizationManager mAuthManager;
    private boolean started = false;
    private Handler handler = new Handler();
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        mAuthManager = new AmazonAuthorizationManager(this, Bundle.EMPTY);
        requestContext = RequestContext.create(this);
        requestContext.registerListener(new AuthorizeListener() {
            @Override
            public void onSuccess(AuthorizeResult authorizeResult) {
                runOnUiThread(new Runnable() {
                    @Override
                    public void run() {
                        // At this point we know the authorization completed, so remove the ability to return to the app to sign-in again
                        setLoggingInState(true);
                fetchUserProfile();
            @Override
            public void onError(AuthError authError) {
                Log.e(TAG, "AuthError during authorization", authError);
                    @Override
                    public void run() {
                        showAuthToast("Error during authorization.  Please try again.");
                        resetProfileView();
                        setLoggingInState(false);
            @Override
            public void onCancel(AuthCancellation authCancellation) {
                Log.e(TAG, "User cancelled authorization");
                    @Override
                    public void run() {
                        showAuthToast("Authorization cancelled");
                        resetProfileView();
        setContentView(R.layout.activity_main);
        initializeUI();
        //new HttpGetRequestRefill().execute("");
        start();
        //Schedule for every 24 hours, this is just for demo, will be used in the future
        Runnable runnable = new Runnable() {
            @Override
            public void run() {
                    SharedPreferences sharedPref = MainActivity.this.getPreferences(Context.MODE_PRIVATE);
                    if(sharedPref.contains("access_token") && sharedPref.contains("refresh_token"))
        //schedule this once every day
        future = scheduler.scheduleAtFixedRate(runnable, 0, 1, TimeUnit.DAYS);
    private Runnable runnable = new Runnable() {
        @Override
        public void run() {
            new HttpGetRequest().execute("");
            start();
    public void start() {
        started = true;
        handler.postDelayed(runnable, 2000);
    @Override
    protected void onResume() {
        super.onResume();
        requestContext.onResume();
    @Override
    protected void onStart() {
        super.onStart();
        if(sharedPref.contains("refresh_token") && sharedPref.contains("access_token"))
            mLoginButton.setVisibility(View.GONE);
            mWrapperProfile.setVisibility(View.VISIBLE);
        else
            mLoginButton.setVisibility(View.VISIBLE);
            mWrapperProfile.setVisibility(View.GONE);
        Scope[] scopes = {ProfileScope.profile(), ProfileScope.postalCode()};
        AuthorizationManager.getToken(this, scopes, new Listener<AuthorizeResult, AuthError>() {
            @Override
            public void onSuccess(AuthorizeResult result) {
                if (result.getAccessToken() != null) {
                    fetchUserProfile();
                    mAccessToken = result.getAccessToken();
                } else {
            @Override
            public void onError(AuthError ae) {
    private void fetchUserProfile() {
        User.fetch(this, new Listener<User, AuthError>() {
            /* fetch completed successfully. */
            @Override
            public void onSuccess(User user) {
                final String name = user.getUserName();
                final String email = user.getUserEmail();
                final String account = user.getUserId();
                final String zipCode = user.getUserPostalCode();
                    @Override
                    public void run() {
                        updateProfileData(name, email, account, zipCode);
            /* There was an error during the attempt to get the profile. */
            @Override
                    @Override
                    public void run() {
                        setLoggedOutState();
                        String errorMessage = "Error retrieving profile information.\nPlease log in again";
                        Toast errorToast = Toast.makeText(getApplicationContext(), errorMessage, Toast.LENGTH_LONG);
                        errorToast.setGravity(Gravity.CENTER, 0, 0);
                        errorToast.show();
    private void updateProfileData(String name, String email, String account, String zipCode) {
        StringBuilder profileBuilder = new StringBuilder();
        profileBuilder.append(String.format("Welcome, %s!\n", name));
        profileBuilder.append(String.format("Your email is %s\n", email));
        profileBuilder.append(String.format("Your zipCode is %s\n", zipCode));
        final String profile = profileBuilder.toString();
        Log.d(TAG, "Profile Response: " + profile);
            @Override
            public void run() {
                updateProfileView(profile);
                setLoggedInState();
     * Initializes all of the UI elements in the activity
    private void initializeUI() {
        mWrapperProfile = (ViewGroup)findViewById(R.id.wrapperProfile);
        mLoginButton = findViewById(R.id.login_with_amazon);
        mLoginButton.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View view) {
                Bundle options = new Bundle();
                // device_model is generated by the wizard when you create a device - replace "modelX"; serial is something you provide and should be visible to the customer - replace "serialY".
                String scope_data = "{\"dash:replenish\":{\"device_model\":\"Internet_of_Toiletries\", \"serial\":\"0\", \"is_test_device \":\"true\"} }";
                options.putString(AuthzConstants.BUNDLE_KEY.SCOPE_DATA.val, scope_data);
                // Request the authorization code instead of an access token
                options.putBoolean(AuthzConstants.BUNDLE_KEY.GET_AUTH_CODE.val, true);
                // Plain = code verifier; S256 uses a Base64url encoding of the code verifier's hash
                options.putString(AuthzConstants.BUNDLE_KEY.CODE_CHALLENGE.val, "e9598da04c204deaf2dff8892efdd9cb0e180b44f406c31ee916175a99511231");
                // Set code challenge method - "plain" or "S256"
                options.putString(AuthzConstants.BUNDLE_KEY.CODE_CHALLENGE_METHOD.val, "plain");
                mAuthManager.authorize(new String []{"dash:replenish"}, options, new AuthorizeListener());
                AuthorizationManager.authorize(
                        new AuthorizeRequest.Builder(requestContext)
                                .addScopes(ProfileScope.profile(), ProfileScope.postalCode())
                                .build()
        mGaugeView1 = (GaugeView)findViewById(R.id.gauge_view1);
        mGaugeView1.setTargetValue(0);
        mGaugeView1.initDrawingRects();
        mGaugeView2 = (GaugeView)findViewById(R.id.gauge_view2);
        mGaugeView2.setTargetValue(0);
        mGaugeView2.initDrawingRects();
        product1 = (TextView)findViewById(R.id.product1);
        product2 = (TextView)findViewById(R.id.product2);
        // Find the button with the logout ID and set up a click handler
        View logoutButton = findViewById(R.id.logout);
        logoutButton.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View v) {
                AuthorizationManager.signOut(getApplicationContext(), new Listener<Void, AuthError>() {
                    @Override
                    public void onSuccess(Void response) {
                            @Override
                            public void run() {
                    @Override
                        Log.e(TAG, "Error clearing authorization state.", authError);
        String logoutText = getString(R.string.logout);
        mProfileText = (TextView) findViewById(R.id.profile_info);
        mProfileText2 = (TextView) findViewById(R.id.profile_info_2);
        mLogoutTextView = (TextView) logoutButton;
        mLogoutTextView.setText(logoutText);
        mLogInProgress = (ProgressBar) findViewById(R.id.log_in_progress);
     * Sets the text in the mProfileText {@link TextView} to the value of the provided String.
     * @param profileInfo the String with which to update the {@link TextView}.
    private void updateProfileView(String profileInfo) {
        Log.d(TAG, "Updating profile view");
        mProfileText.setText(profileInfo);
        mProfileText2.setText(profileInfo);
     * Sets the text in the mProfileText {@link TextView} to the prompt it originally displayed.
    private void resetProfileView() {
        mProfileText.setText(getString(R.string.default_message));
     * Sets the state of the application to reflect that the user is currently authorized.
    private void setLoggedInState() {
        mLoginButton.setVisibility(Button.GONE);
        setLoggedInButtonsVisibility(Button.VISIBLE);
        mIsLoggedIn = true;
     * Sets the state of the application to reflect that the user is not currently authorized.
    private void setLoggedOutState() {
        mLoginButton.setVisibility(Button.VISIBLE);
        setLoggedInButtonsVisibility(Button.GONE);
        mIsLoggedIn = false;
        resetProfileView();
     * Changes the visibility for both of the buttons that are available during the logged in state
     * @param visibility the visibility to which the buttons should be set
    private void setLoggedInButtonsVisibility(int visibility) {
        mLogoutTextView.setVisibility(visibility);
     * Turns on/off display elements which indicate that the user is currently in the process of logging in
     * @param loggingIn whether or not the user is currently in the process of logging in
    private void setLoggingInState(final boolean loggingIn) {
        if (loggingIn) {
            mLogInProgress.setVisibility(ProgressBar.VISIBLE);
            mProfileText.setVisibility(TextView.GONE);
        } else {
            if (mIsLoggedIn) {
                mProfileText.setVisibility(TextView.VISIBLE);
            } else {
            mLogInProgress.setVisibility(ProgressBar.GONE);
    private void showAuthToast(String authToastMessage) {
        Toast authToast = Toast.makeText(getApplicationContext(), authToastMessage, Toast.LENGTH_LONG);
        authToast.setGravity(Gravity.CENTER, 0, 0);
        authToast.show();
    public class DashAuthorize extends AsyncTask<String, Void, String> {
        @Override
        protected String doInBackground(String... params){
            String result = null;
            try {
                if(params.length == 0 || params[0] == null)
                    return null;
                RequestBody body = RequestBody.create(STRING, params[0]);
                Request AMZNrequest = new Request.Builder()
                        .url("https://api.amazon.com/auth/O2/token")
                        .post(body)
                        .build();
                Response AMZNresponse = client.newCall(AMZNrequest).execute();
                String responseBody = AMZNresponse.body().string();
                Log.e("responseBody", responseBody);
                JSONObject authData = new JSONObject(responseBody);
                SharedPreferences.Editor editor = sharedPref.edit();
                if(authData.has("access_token"))
                    editor.putString("access_token", authData.getString("access_token"));
                    editor.commit();
                if(authData.has("refresh_token"))
                    editor.putString("refresh_token", authData.getString("refresh_token"));
                    editor.commit();
                return responseBody;
            catch(IOException e){
                e.printStackTrace();
                result = null;
            } catch (JSONException e) {
            return result;
        protected void onPostExecute(String result){
            super.onPostExecute(result);
            if(result != null)
                try {
                    JSONObject authData = new JSONObject(result);
                    if(authData.has("refresh_token")) {
                Log.e("stuff", result);
    public class DashRefresh extends AsyncTask<String, Void, String> {
        @Override
            try {
                if(!sharedPref.contains("access_token") || !sharedPref.contains("refresh_token") || !sharedPref.contains("client_id"))
                    return null;
                String bodyraw = "grant_type=refresh_token&refresh_token=" + sharedPref.getString("sharedPref", "")
                        + "&client_id=" + sharedPref.getString("client_id", "");
                RequestBody body = RequestBody.create(STRING, bodyraw);
                        .post(body)
                        .build();
                    editor.commit();
                    editor.commit();
                result = null;
            return result;
            if(result != null)
                try {
    public class HttpGetRequest extends AsyncTask<String, Void, String> {
        @Override
            String result;
            String inputLine;
            try {
                Request request = new Request.Builder()
                        .url("https://shrouded-citadel-97257.herokuapp.com/getproduct")
                        .build();
                Response response = client.newCall(request).execute();
                if (!response.isSuccessful()) {
                    return null;
                return response.body().string();
                result = null;
            return result;
            if(result != null)
                try {
                    JSONArray data = new JSONArray(result);
                    if(data.length() > 0)
                        JSONObject item = data.getJSONObject(0);
                        String product1_desc = item.optString("Product1Name", "");
                        String product2_desc = item.optString("Product2Name", "");
                        float product_ratio1 = (float) (item.getDouble("Product1weight") / item.getDouble("Product1Max"));
                        float product_ratio2 = (float) (item.getDouble("Product2weight") / item.getDouble("Product2Max"));
                        product1.setText(product1_desc);
                        product2.setText(product2_desc);
                        mGaugeView1.setTargetValue(product_ratio1 * 100.0f);
                        mGaugeView2.setTargetValue(product_ratio2 * 100.0f);
    //Amazon Dash
    public class HttpGetRequestRefill extends AsyncTask<String, Void, String> {
        @Override
            try {
                        .build();
                    return null;
                String jsonresult = response.body().string();
                Log.e("result", jsonresult);
                JSONArray data = new JSONArray(jsonresult);
                    String url = "";
                    //If first product is smaller than 25%
                    //if(product_ratio1 * 100.0f < 25.0f)
                    url = DRS_URL + slot1;
                    //If second product is smaller than 25%
                    if(product_ratio2 * 100.0f < 25.0f)
                        url = DRS_URL + slot2;
                    RequestBody body = RequestBody.create(JSON, "");
                            .addHeader("Authorization", "Bearer " + sharedPref.getString("access_token", ""))
                            .addHeader("x-amzn-accept-type", "com.amazon.dash.replenishment.DrsReplenishResult@1.0")
                            .addHeader("x-amzn-type-version", "com.amazon.dash.replenishment.DrsReplenishInput@1.0")
                            .url(url)
                            .post(body)
                            .build();
                result = null;
                result = null;
            return result;
            if(result != null)
                JSONObject order = null;
                try {
                    order = new JSONObject(result);
                    if(!order.has("eventInstanceId"))
                        new DashRefresh().execute("");
                Log.e("result", result);
    public class AuthorizeListener implements AuthorizationListener {
        /* Authorization was completed successfully. */
        @Override
        public void onSuccess(Bundle response) {
            try {
                String authorizationCode = response.getString(AuthzConstants.BUNDLE_KEY.AUTHORIZATION_CODE.val);
                String clientId = mAuthManager.getClientId();
                String redirectUri = mAuthManager.getRedirectUri();
                editor.putString("client_id", clientId);
                editor.commit();
                RequestBody body = new FormBody.Builder()
                        .add("grant_type", "authorization_code")
                        .add("code", authorizationCode)
                        .add("redirect_uri", redirectUri)
                        .add("client_id", clientId)
                        .add("code_verifier", "e9598da04c204deaf2dff8892efdd9cb0e180b44f406c31ee916175a99511231")
                        .build();*/
                String body = "grant_type=authorization_code&code=" + authorizationCode + "&redirect_uri=" + redirectUri
                        + "&client_id=" + clientId + "&code_verifier=e9598da04c204deaf2dff8892efdd9cb0e180b44f406c31ee916175a99511231";
                Log.e("doh", body);
                //Getting authorized
                new DashAuthorize().execute(body);
            } catch (AuthError authError) {
                authError.printStackTrace();
        /* There was an error during the attempt to authorize the application. */
        @Override
            String errorResponse = ae.getMessage();
            if(errorResponse != null)
                Log.e("doh", errorResponse);
        /* Authorization was cancelled before it could be completed. */
        @Override
        public void onCancel(Bundle cause) {
server portion
JavaScript
This is the server portion where the activity is handled via node.js
var express = require('express');
var mysql = require('mysql');
var app = express();
var bodyParser = require('body-parser');
var jsonParser = bodyParser.json();
require('dotenv').config()
var connection = mysql.createConnection({
  host     : process.env.RDS_HOSTNAME,
  user     : process.env.RDS_USERNAME,
  password : process.env.RDS_PASSWORD,
  port     : process.env.RDS_PORT,
  database : process.env.RDS_DB
app.set('port', (process.env.PORT || 5000));
app.use(express.static(__dirname + '/public'));
// views is directory for all template files
app.set('views', __dirname + '/views');
app.set('view engine', 'ejs');
app.get('/', function(request, response) {
	console.log(process.env.RDS_HOSTNAME);
  	response.render('pages/index');
connection.connect(function(err) {
  if (err) {
    console.error('error connecting: ' + err.stack);
    return;
  console.log('connected as id ' + connection.threadId);
app.get('/getproduct', function(request, response) {
		connection.query('Select * from products where id = 0', function(err, results) {
			if(err) throw err;
			console.log(results);
			response.send(results);
//just updating demo unit for now, in the future we will update it by id
//this portion requires the service to allow me to change items on the slots
app.post('/updateproduct', jsonParser, function(request, response) {
    if (!request.body) return response.sendStatus(400);
	connection.query('UPDATE products SET Product1 = ?, Product2 = ?, Product1Max= ?, Product2Max = ?, Product1Name = ?, Product2Name =? WHERE id = 0',
	[request.body.product1, request.body.product2, request.body.product1max, request.body.product2max, request.body.product1name, request.body.product2name], function(err, results) {
	    if(err) throw err;
		console.log("success");
  	response.sendStatus(200);
app.post('/updatevalue', jsonParser, function(request, response) {
	connection.query('UPDATE products SET Product1weight = ?, Product2weight = ? WHERE id = 0',
		[request.body.product1weight, request.body.product2weight], function(err, results) {
	                	if(err) throw err;
app.listen(app.get('port'), function() {
  console.log('Node app is running on port', app.get('port'));
Internet of Toiletries source code
Github that contains all the project files
Credits
Peter Ma
Peter Ma
25 projects • 172 followers
Prototype Hacker, Intel Software Innovator, Hackathon Goer, World Traveler, Ecological balancer, integrationist, technologist, futurist.
Mica Wong
Mica Wong
3 projects • 10 followers
Self taught 3D modeling and printing skills. Work at a grooming salon part time and delve into projects and hackathons as hobby.
Comments
Add projectSign up / Login
