Billy King
Published © CC BY-NC-SA
Mini GreenHouse 1.20X0.60X0.60
Objectives: Heating, aeration, and irrigation. Behavior: Event when the temperature is low or high and the soil is dry. (Videos on Story)
IntermediateShowcase (no instructions)4 hours27,903
Things used in this project
Hardware components
Arduino UNO & Genuino UNO
×1
Adafruit 1.8TFT V1.0 ST7735
×1
SparkFun Breadboard Power Supply 5V/3.3V
×1
12V/29A Power Supply
OpenBuilds 12V/29A Power Supply
×1
290 LED 8W Grow Light Panel Lamp for Plant Hydroponic Growing Full Spectrum Hot
×1
Fan Kit, 120 mm Fan
Fan Kit, 120 mm Fan
×2
SparkFun Soil Moisture Sensor (with Screw Terminals)
×1
Grove - 4-Channel Solid State Relay
Seeed Grove - 4-Channel Solid State Relay
×1
Rotary potentiometer (generic)
×2
DHT22 Temperature Sensor
×1
DHT11 Temperature & Humidity Sensor (4 pins)
×1
Windows 10
Microsoft Windows 10
Story
Read more
Schematics
Greenhouse
Code
Greenhouse1.8
C/C++
File: GreenHouse1.8_par1.ino
Processor: Arduino UNO, MEGA
Language: Wiring / C / Arduino IDE
Objectives: Heating - Aeration - Irrigation
Note: 1.8 TFT LCD 128Χ160
DHT-11 Sensor of Temperature and Humitide
DHT-21 Sensor of Temperature and Humitide
Soil Moisture Sensor and Hygrometer Module
Potentiometer1 change limit Moisture
Potentiometer2 change limit Temperature
Relay1_AirIn to Blower Fan IN
Relay2_AirOut to Blower Fan OUT
Relay3_Lamp to Hot Lamp
Relay4_Water to Water Pump
Author: Billy Gkekas
Starting Date: Saturday, 29-10-2018
Place: Greece, Ptolemaida
This project contains public domain code.
The modification is allowed without notice.
  #   File:       Arduino_GreenHouse_Controling_sustem.ino   #
  #   Processor:  Arduino UNO, MEGA                          #
  #   Language:   Wiring / C / Arduino IDE                   #
  #   Objectives: Heating - Aeration - Irrigation            #
  #   Behavior:   Event when the temperature is low          #
  #               or high and the soil is dry                #
  #   Note:       1.8 TFT LCD 128160                        #
  #               DHT-22 Sensor of Temperature and Humitide  #
  #               Sensor Temperature and Humidity External   #
  #               Soil Moisture Sensor and Hygrometer Module #
  #               Potentiometer1 change limit Moisture       #
  #               Potentiometer2 change limit Temperature    #
  #               Relay1_AirIn to Blower Fan IN              #
  #               Relay2_AirOut to Blower Fan OUT            #
  #               Relay3_Lamp to Hot Lamp                    #
  #               Relay4_Water to Water Pump                 #
  #   Author:     Billy Gkekas                               #
  #   Date:       Saturday, 29-10-2018                       #
  #   place:      Greece, Ptolemaida                         #
  #   This project contains public domain code.              #
  #   The modification is allowed without notice.            #
// DHT22
#include <DHT.h>
#define DHTPIN 1
#define DHTPIN21 3
// #define DHTTYPE DHT11     // DHT 11)
#define DHTTYPE DHT22   // DHT 22 (AM2302), AM2321
#define DHTTYPE21 DHT21   // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE); // Initialize DHT sensor for normal 16mhz Arduino
DHT dht21(DHTPIN21, DHTTYPE21); // Initialize DHT sensor for normal 16mhz Arduino
// 1.8 TFT LCD 128X 160
#include  <Adafruit_GFX.h>
#include  <Adafruit_ST7735.h>
#include <SPI.h>
//#include "Adafruit_SHT31.h"
//Adafruit_SHT31 sht31 = Adafruit_SHT31();
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#define GRAY    0x7BEF
#define LIGHT_GRAY 0xC618
#define LIME    0x87E0
#define AQUA    0x5D1C
#define CYAN    0x07FF
#define DARK_CYAN 0x03EF
#define ORANGE  0xFCA0
#define PINK    0xF97F
#define BROWN   0x8200
#define VIOLET  0x9199
#define SILVER  0xA510
#define GOLD    0xA508
#define NAVY    0x000F
#define MAROON  0x7800
#define PURPLE  0x780F
#define OLIVE   0x7BE0
#define TFT_SCLK  13
#define TFT_MOSI  11
#define TFT_CS    10
#define TFT_RST    9
#define TFT_DC     8
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS,  TFT_DC, TFT_RST);
// Variable Definitions
float temp_internal;    // Stores internal temperature value
float hum_internal;     // Stores internal humidity value
float temp_external;    // Stores external temperature value
float hum_external;     // Stores external humidity value
int state;              // Condition of pins
int valMoisture = 0;    // Stores Moisture value
int kath = 5000;        // Delay
int LimM = 1023 ;       // Stores value after edit
int LimT = 25 ;         // Stores value after edit
int manytimes = 1;
int total;
//pin definitions
int MoisturePin = A0;   // Moisture Analog pin
int potention1 = A2;    // Potentiometer to change Temperature Limit
int potention2 = A1;    // Potentiometer to change Moisture Limit
int Relay1_AirIn = 4;   // airRelay1 Blower Air Fan IN
int Relay2_AirOut = 5;  // airRelay2 Blower Air Fan OUT
int Relay3_Lamp = 6;    // Relay3_Lamp Hot Lamp
int Relay4_Water = 7;   // Relay4_Water Pump
int soilPower = 2;      // Moisture Soil power
  Serial.begin(9600);
  dht.begin();  // DHT22 Starts
  dht21.begin();  // DHT21 Starts
  tft.initR(INITR_BLACKTAB);  // Initialize 1.8 TFT LCD 128 X 160
  tft.fillScreen(BLACK);
  tft.setRotation(0);
  // Initialize Sensor Moisture
  pinMode(soilPower, OUTPUT);   // Set D7 as an OUTPUT
  digitalWrite(soilPower, LOW); // Set to LOW, no power in the sensor
  // Initialize Relays
  pinMode(potention1, INPUT);
  pinMode(potention2, INPUT);
  pinMode(Relay1_AirIn, OUTPUT);
  pinMode(Relay2_AirOut, OUTPUT);
  pinMode(Relay3_Lamp, OUTPUT);
  pinMode(Relay4_Water, OUTPUT);
  digitalWrite(Relay1_AirIn, LOW);
  digitalWrite(Relay2_AirOut, LOW);
  digitalWrite(Relay3_Lamp, LOW);
  digitalWrite(Relay4_Water, LOW);
  // Read data from Sensors
  // 1. Read data from Internal Sensor and store it to variables temp_internal and hum_internal
  hum_internal = dht21.readHumidity();
  temp_internal = dht21.readTemperature();
  // 2. Read data from DHT22 and store it to variables hum and temp
  hum_internal = dht.readHumidity();
  temp_internal = dht.readTemperature();
  // This Function send power and then reads from Moisture Sensor
  int readSoil() ;
  digitalWrite(soilPower, HIGH); // turn D2 "On"
  delay(10); // wait 10 milliseconds giving time to Moisture Sensor
  // 3. Read the SIG value (data) from the sensor and counted percent degrees
  valMoisture = (analogRead(MoisturePin) - 23) / 10;
  digitalWrite(soilPower, LOW); // turn power on D2 "Off"
  // 4. Read from potentiometers limit of Temperature and Humidity
  LimT = (analogRead(potention1) - 23) / 10; // Read limit from Potentiometer
  LimM = (analogRead(potention2) - 21) / 10; // Read limit from Potentiometer
  // Print readed values of External and Internal Temperature
  tft.fillRect(0, 0, 64, 20, RED);
  printText1(temp_external, WHITE, 2, 2, 2);
  tft.fillRect(64, 0, 64, 20, MAGENTA);
  printText1(temp_internal, WHITE, 66, 2, 2);
  tft.fillRect(43, 20, 45, 20, CYAN);
  printText("EXT", WHITE, 2, 23, 2);
  tft.setCursor(50, 23);
  tft.setTextColor(BLACK);
  tft.print(LimT);
  printText("INT", WHITE, 90, 23, 2);
  // Print readed values of Internal and Internal Humidity
  tft.fillRect(0, 40, 64, 20, VIOLET);
  printText1(hum_external, WHITE, 2, 43, 2);
  tft.fillRect(64, 40, 64, 20, YELLOW);
  printText1(hum_internal, BLACK, 66, 43, 2);
  tft.fillRect(58, 60, 128, 20, CYAN);
  printText("LimM", WHITE, 2, 63, 2);
  tft.setCursor(65,63);
  tft.print(LimM);
  tft.print(" %");
  // Print on Serial Window readed values
  Serial.print("Counter = ");
  Serial.println(manytimes);
  Serial.print("TOTAL = ");
  Serial.println(total);
  state = digitalRead(Relay1_AirIn);
  Serial.print("Air In = ");
  Serial.println(state);
  state = digitalRead(Relay2_AirOut);
  Serial.print("Air Out = ");
  state = digitalRead(Relay3_Lamp);
  Serial.print("Lamp = ");
  state = digitalRead(Relay4_Water);
  Serial.print("Water = ");
  Serial.println("");
  // 1. Check limit value for Moisture Soil Sensor and control Relay4_Water
  Serial.print("Soil: ");
  Serial.println(valMoisture);
  printText("SOIL", WHITE, 2, 83, 2);
  printText("WATER", WHITE, 5, 143, 2);
  if (valMoisture >= LimM) {
    digitalWrite(Relay4_Water, HIGH);
    tft.fillRect(58, 80, 128, 20, AQUA);
    printText1(valMoisture, WHITE, 65, 83, 2);
    tft.fillRect(80, 140, 128, 20, AQUA);
    printText("ON", WHITE, 85, 143, 2);
  else {
    tft.fillRect(58, 80, 128, 20, BLUE);
    tft.fillRect(80, 140, 128, 20, RED);
    printText("OFF", WHITE, 85, 143, 2);
  printText("AIR ", WHITE, 2, 103, 2);
  printText("LAMP", WHITE, 5, 123, 2);
  // 2. Check greenhouse's Internal Condition and control Relays of Fans & Hot Lamp
  if (temp_internal >= LimT) {
    if (temp_internal > temp_external) {
      Serial.println("1. t_int >= LimT & t_int > t_ext");
      Serial.print(temp_internal);
      Serial.print(" >= ");
      Serial.print(LimT);
      Serial.print(" & > ");
      Serial.print(temp_external);
      Serial.println("   AirIn On - AirOut On - Lamp Off");
      tft.fillRect(40, 100, 42, 20, GREEN);
      printText("IN ", BLACK, 45, 103, 2);
      if (state == 1) {
        // do nothing
      else {
        digitalWrite(Relay1_AirIn, HIGH);
      tft.fillRect(80, 100, 128, 20, GREEN);
      printText("OUT", BLACK, 85, 103, 2);
      if (state == 1) {
        // do nothing
      else {
        digitalWrite(Relay2_AirOut, HIGH);
      tft.fillRect(80, 120, 128, 20, RED);
      printText("OFF", WHITE, 85, 123, 2);
      if (state == 0) {
        // do nothing
      else {
    else {
      Serial.println("else 1. t_int >= LimT & t_int < t_ext");
      Serial.print(" > ");
      Serial.print(LimT);
      Serial.println("   AirIn Off - AirOut On - Lamp Off");
      tft.fillRect(40, 100, 42, 20, RED);
      printText("IN ", WHITE, 45, 103, 2);
      if (state == 0) {
        // do nothing
      else {
      if (state == 1) {
        // do nothing
      else {
      if (state == 0) {
        // do nothing
      else {
  if (temp_internal < LimT) {
    if (temp_internal <= temp_external) {
      Serial.println("2. t_int < LimT & t_int >= t_ext");
      Serial.print(" <= ");
      Serial.print(" < ");
      Serial.print(LimT);
      Serial.println("   AirIn ON - AirOut Off - Lamp On");
      printText("IN", BLACK, 50, 103, 2);
      if (state == 1) {
        // do nothing
      else {
      tft.fillRect(80, 100, 128, 20, RED);
      printText("OUT", WHITE, 85, 103, 2);
      if (state == 0) {
        // do nothing
      else {
      tft.fillRect(80, 120, 128, 20, GREEN);
      printText("ON", BLACK, 85, 123, 2);
      if (state == 1) {
        // do nothing
      else {
        digitalWrite(Relay3_Lamp, HIGH);
    else {
      Serial.println("else 2. t_int < LimT & t_int < t_ext");
      Serial.print(LimT);
      Serial.print(" & ");
      Serial.println("AirIn OFF - AirOut Off - Lamp On");
      printText("IN", WHITE, 44, 103, 2);
      if (state == 0) {
        // do nothing
      else {
      if (state == 0) {
        // do nothing
      else {
      if (state == 1) {
        // do nothing
      else {
  // 3. Refresh screen after 50 times
  manytimes++;
  total++;
  if (manytimes == 50) {
    printText("Smart", LIME, 15, 20, 2);
    printText("GreenHouse", GREEN, 5, 50, 2);
    printText("v4.0", AQUA, 15, 80, 2);
    delay(3000);
    manytimes = 0;
  delay(kath);
  tft.setTextSize(1);
  tft.fillRect(50, 80, 128, 40, BLACK);
  tft.setTextColor(WHITE);
// Function Print Text
void printText(char *text, uint16_t color, int x, int y, int textSize)
  tft.setCursor(x, y);
  tft.setTextColor(color);
  tft.setTextSize(textSize);
  tft.setTextWrap(true);
  tft.print(text);
  // printText("MAX", RED,18,130,1);
// Function Print float
void printText1(float num, uint16_t color, int x, int y, int textSize)
  tft.print(num);
  // printText1(value, RED,18,130,1);
Credits
Billy King
Billy King
1 project • 20 followers
Comments
Add projectSign up / Login
