Gary LiWinnie LiYiyang Xu
Published
Two-in-One Radar System
This system can be used as both a backup radar and a collision warning system.
BeginnerFull instructions provided513
Things used in this project
Hardware components
EK-TM4C123GXL TM4C Tiva LaunchPad
Texas Instruments EK-TM4C123GXL TM4C Tiva LaunchPad
×1
Grove starter kit plus for Intel Edison
Seeed Grove starter kit plus for Intel Edison
×1
Energia
Texas Instruments Energia
Story
Read more
Schematics
Code
Source Code
C/C++
#include "Ultrasonic.h"
#define BUZZER_PIN               39            /* sig pin of the Grove Buzzer */
#define ULTRASONIC_PIN           38            /* pin of the Ultrasonic Ranger */
Ultrasonic ultrasonic(ULTRASONIC_PIN);    /* Ultrasonic Ranger object */
int distance = 0;                         /* variable to store the distance to obstacles in front */
int tempo = 200;
/* set buzzer pin as output */
  pinMode(BUZZER_PIN, OUTPUT);
  distance = ultrasonic.MeasureInCentimeters();   /* read the value from the sensor */
  if (distance<30)
    tempo=100;
    playTone(1200,tempo);
  else if(distance<50)
    tempo=200;
    playTone(1400,tempo);
  else if (distance<80)
    tempo=300;
    playTone(1500,tempo);
  else if (distance<100)
    tempo=400;
    playTone(1700,tempo);
  else if (distance<150)
    tempo=500;
    playTone(1900,tempo);
  delay(tempo / 2);
/* play tone */
void playTone(int tone, int duration)
  for (long i = 0; i < duration * 1000L; i += tone * 2)
    digitalWrite(BUZZER_PIN, HIGH);
    delayMicroseconds(tone);
    digitalWrite(BUZZER_PIN, LOW);
Credits
Gary Li
Gary Li
1 project • 0 followers
Winnie Li
Winnie Li
1 project • 1 follower
Yiyang Xu
Yiyang Xu
Comments
Add projectSign up / Login
