Darian Johnson
Published © GPL3+
DIY Smart Lamp - Controlled by Toggle Switch and Alexa
Build a smart lamp that can be controlled by flipping a switch and Alexa, for only $35.
IntermediateFull instructions provided20 hours6,726
Things used in this project
Hardware components
LinkIt Smart 7688 Duo
MediaTek Labs LinkIt Smart 7688 Duo
×1
Relay (generic)
×1
Toggle Switch
You could also use a push button
×1
Floor Lamp
×1
Plastic Project Box
×1
Prototype PCB Board
×1
Jumper wires (generic)
×1
22 awg wire
×1
Alexa Skills Kit
Amazon Alexa Alexa Skills Kit
AWS Lambda
Amazon Web Services AWS Lambda
AWS IoT
Amazon Web Services AWS IoT
Soldering iron (generic)
Story
Read more
Schematics
Schematic for smart lamp
Smart lamp bb rl39wfnw8t
Code
Button.py
Python
Python Code to control button
import mraa
import time
# Refer to the pin-out diagram for the GPIO number
#button pnb
buttonpin = mraa.Gpio(43)
buttonpin.dir(mraa.DIR_IN)
current_button = buttonpin.read()
relaypin = mraa.Gpio(3)
relaypin.dir(mraa.DIR_IN)
relaypin_out = mraa.Gpio(3)
relaypin_out.dir(mraa.DIR_OUT)
while True:
	if buttonpin.read() != current_button: #button was flipped
		time.sleep(0.25)
		print "button flipped"
		print "relay:", relaypin.read()
		if relaypin.read() == 0:
			relaypin_out.write(1)
		else:
			relaypin_out.write(0)
LAMPBUTTON
SH
Script that defines service for button.py
#!/bin/sh /etc/rc.common
START=99
STOP=15
boot() {
    # launch the python script
    python /root/button.py &
start() {
   echo start
   # commands to launch application
stop() {
   pid=`ps -ef | grep '[p]ython /root/button.py' | awk '{ print $2 }'`
   echo $pid
   kill $pid
   sleep 2
   echo "Server killed."
   # commands to kill application
restart() {
LAMPMQTT
SH
script that defines service for mqtt.py
START=99
STOP=15
boot() {
    python /root/mqtt.py &
start() {
   python /root/lamp/mqtt.py &
   echo start
stop() {
   pid=`ps -ef | grep '[p]ython /root/mqtt.py' | awk '{ print $2 }'`
   echo $pid
   kill $pid
   sleep 2
restart() {
MQTT.py
Python
Code to receive MQTT messages
import mraa
import time
import paho.mqtt.client as paho
import ssl
import json
# relay pin out
# Parameters
topic = "user@emal.com"
applianceId = "DEVICE-NAME"
def on_connect(client, userdata, flags, rc):
	print("Connection returned result: " + str(rc) )
	# Subscribing in on_connect() means that if we lose the connection and
	# reconnect then subscriptions will be renewed.
	#client.subscribe("#" , 1 )
	client.subscribe(topic + "/" + applianceId + "/#" ,1)
def on_message(client, userdata, msg):
	print("payload: " + msg.payload)
	parsed_json = json.loads(msg.payload)
	if msg.topic ==topic + "/" + applianceId + "/on":
	if msg.topic ==topic + "/" + applianceId + "/off":
mqttc = paho.Client()
mqttc.on_connect = on_connect
mqttc.on_message = on_message
#variables to connect to AWS IoT
#Note these certs allow access to send IoT messages
awshost = "data.iot.us-east-1.amazonaws.com"
awsport = 8883
clientId = applianceId
thingName = applianceId
caPath = "certs/verisign-cert.pem"
certPath = "certs/Light.certificate.pem.crt"
keyPath = "certs/Light.private.pem.key"
mqttc.tls_set(caPath, certfile=certPath, keyfile=keyPath, cert_reqs=ssl.CERT_REQUIRED, tls_version=ssl.PROTOCOL_TLSv1_2, ciphers=None)
mqttc.connect(awshost, awsport, keepalive=60)
mqttc.loop_forever()
index.sh
JavaScript
AWS Lambda code that defines the Alexa Skill
var AWS = require('aws-sdk');
var iotdata = new AWS.IotData({endpoint: 'XXXXXXXX.iot.us-east-1.amazonaws.com'});
var request = require('request');
// namespaces
const NAMESPACE_CONTROL = "Alexa.ConnectedHome.Control";
const NAMESPACE_DISCOVERY = "Alexa.ConnectedHome.Discovery";
// discovery
const REQUEST_DISCOVER = "DiscoverAppliancesRequest";
const RESPONSE_DISCOVER = "DiscoverAppliancesResponse";
// control
const REQUEST_TURN_ON = "TurnOnRequest";
const RESPONSE_TURN_ON = "TurnOnConfirmation";
const REQUEST_TURN_OFF = "TurnOffRequest";
const RESPONSE_TURN_OFF = "TurnOffConfirmation";
// errors
const ERROR_UNSUPPORTED_OPERATION = "UnsupportedOperationError";
const ERROR_UNEXPECTED_INFO = "UnexpectedInformationReceivedError";
// entry
exports.handler = function (event, context, callback) {
  log("Received Directive", event);
  var requestedNamespace = event.header.namespace;
  var response = null;
  try {
    switch (requestedNamespace) {
      case NAMESPACE_DISCOVERY:
        response = handleDiscovery(event);
        break;
      case NAMESPACE_CONTROL:
        response = handleControl(event);
        break;
      default:
        log("Error", "Unsupported namespace: " + requestedNamespace);
        response = handleUnexpectedInfo(requestedNamespace);
        break;
    }// switch
  } catch (error) {
    log("Error", error);
  }// try-catch
  callback(null, response);
};// exports.handler
var handleDiscovery_old = function(event) {
  var header = createHeader(NAMESPACE_DISCOVERY, RESPONSE_DISCOVER);
  var payload = {
    "discoveredAppliances": []
  return createDirective(header,payload);
};// handleDiscovery
var handleDiscovery = function(event, context) {
  var header = createHeader(NAMESPACE_DISCOVERY,RESPONSE_DISCOVER);
  // initialize empty payload
  var payload = {};
  if (event.header.name == REQUEST_DISCOVER) {
   // function to retrieve device info from device cloud
   var appliances = getAppliances(event);
   payload = {
      "discoveredAppliances": appliances
var handleControl = function(event) {
  var requestedName = event.header.name;
  switch (requestedName) {
    case REQUEST_TURN_ON :
      response = handleControlTurnOn(event);
      break;
    case REQUEST_TURN_OFF :
      response = handleControlTurnOff(event);
      break;
    default:
      log("Error", "Unsupported operation" + requestedName);
      response = handleUnsupportedOperation();
      break;
  }// switch
  return response;
};// handleControl
var handleControlTurnOn = function(event) {
  var header = createHeader(NAMESPACE_CONTROL,RESPONSE_TURN_ON);
  var payload = {};
  callDeviceCloud(event,"state","on");
};// handleControlTurnOn
var handleControlTurnOff = function(event) {
  var header = createHeader(NAMESPACE_CONTROL,RESPONSE_TURN_OFF);
  callDeviceCloud(event,"state","off");
  var payload = {};
};// handleControlTurnOff
var handleUnsupportedOperation = function() {
  var header = createHeader(NAMESPACE_CONTROL,ERROR_UNSUPPORTED_OPERATION);
  var payload = {};
};// handleUnsupportedOperation
var handleUnexpectedInfo = function(fault) {
  var header = createHeader(NAMESPACE_CONTROL,ERROR_UNEXPECTED_INFO);
  var payload = {
    "faultingParameter" : fault
};// handleUnexpectedInfo
// ------------------------------support functions---------------------------------------------
var createMessageId = function() {
  var d = new Date().getTime();
  var uuid = 'xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'.replace(/[xy]/g, function(c) {
    var r = (d + Math.random()*16)%16 | 0;
    d = Math.floor(d/16);
    return (c=='x' ? r : (r&0x3|0x8)).toString(16);
  return uuid;
};// createMessageId
var createHeader = function(namespace, name) {
  return {
    "messageId": createMessageId(),
    "namespace": namespace,
    "name": name,
    "payloadVersion": "2"
};// createHeader
var createDirective = function(header, payload) {
  return {
    "header" : header,
    "payload" : payload
};// createDirective
var log = function(title, msg) {
  console.log('**** ' + title + ': ' + JSON.stringify(msg));
};// log
//--------------messages to device---------------------//
var getAppliances = function(event) {
  // var accessToken = event.payload.accessToken
  return [
        "applianceId": "DEVICE-NAME",
        "manufacturerName": "Your Name",
        "modelName": "DIY Lamp",
        "version": "1",
        "friendlyName": "ROOM",
        "friendlyDescription": "DIY Smart Light",
        "isReachable": true,
        "actions": [
            "turnOn",
            "turnOff"
        "additionalApplianceDetails": {
            "extraDetail1": "This is a light that is reachable"
};// getSampleAppliances
var callDeviceCloud = function(event, command, commandValue) {
  var deviceId = event.payload.appliance.applianceId;
  log(deviceId, command + " = " + commandValue);
  var email = 'user@email.com';
  var iotTopic = email + "/" + deviceId + "/" + commandValue;
  var iotPayload = '{ "message": "Toggle Light"}';
  publishMessage(iotTopic,iotPayload);
};// callDeviceCloud
function publishMessage(iotTopic, iotPayload){
	var iotParams = {
		topic: iotTopic, // required
		//payload: new Buffer('...') || payload,
		payload: iotPayload,
		qos: 1
	iotdata.publish(iotParams, function(err, data) {
		if (err) console.log(err, err.stack); // an error occurred
		else     console.log(data);
function getProfileInfo(){
    var accessToken = event.payload.accessToken;
    var amznProfileURL = 'https://api.amazon.com/user/profile?access_token=';
    request(amznProfileURL, function(error, response, body) {
        if (response.statusCode == 200) {
                var profile = JSON.parse(body);
                console.log(profile.CustomerId);
                return profile.CustomerId;
            } else {
                console.log("Customer not found");
                return null;
Credits
Darian Johnson
Darian Johnson
7 projects • 93 followers
Technologist. Music lover. Fitness enthusiast. Movie buff. Fan of sci-fi and comic books.
Comments
Add projectSign up / Login
