edison science corner
Published © CC BY
Diy Seven Segment Display Clock
let's build simple diy led clock
AdvancedFull instructions provided5 hours7,636
Things used in this project
Hardware components
Arduino UNO
Arduino UNO
×1
Pi RTC (DS1307)
Seeed Pi RTC (DS1307)
×1
7 Segment LED Display, Red
×1
Arduino IDE
Arduino IDE
Soldering iron (generic)
Hot glue gun (generic)
Story
Read more
Custom parts and enclosures
circuit diagram
Schematics
circuit diagram
Code
code.ino
C/C++
int digit1 = 11; //PWM Display pin 12 (digit1 is common anonds A1 from right side)
int digit2 = 10; //PWM Display pin 9 (digit2 is  common A2)
int digit3 = 9; //PWM Display pin 8 (digit3 is common anods A3)
int digit4 = 6; //PWM Display pin 6 (digit4 is common anods, from left side)
int segA = 2; //Display pin 11
int segB = 3; //Display pin 7
int segC = 4; //Display pin 4
int segD = 5; //Display pin 2
int segE = 12; //Display pin 1
int segF = 7; //Display pin 10
int segG = 8; //Display pin 5
int segDP = 13; // Display pin 3
int pin = 1;
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
byte SW0 = A0;
byte SW1 = A1;
byte SW2 = A2;
// use for hexa in zecimal conversion
int zh, uh, ore;
int zm, um, miniti;
 //  Serial.begin(57600);
  Wire.begin();
  RTC.begin();
// RTC.adjust(DateTime(__DATE__, __TIME__));
// if you need set clock... just remove // from line above this
// part code for flashing LED
Wire.beginTransmission(0x68);
Wire.write(0x07); // move pointer to SQW address
// Wire.write(0x00); // turns the SQW pin off
 Wire.write(0x10); // sends 0x10 (hex) 00010000 (binary) to control register - turns on square wave at 1Hz
// Wire.write(0x13); // sends 0x13 (hex) 00010011 (binary) 32kHz
Wire.endTransmission();
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
// dht.begin();
  pinMode(segA, OUTPUT);
  pinMode(segB, OUTPUT);
  pinMode(segC, OUTPUT);
  pinMode(segD, OUTPUT);
  pinMode(segE, OUTPUT);
  pinMode(segF, OUTPUT);
  pinMode(segG, OUTPUT);
  pinMode(segDP, OUTPUT);
  pinMode(pin, OUTPUT);
  pinMode(digit1, OUTPUT);
  pinMode(digit2, OUTPUT);
  pinMode(digit3, OUTPUT);
  pinMode(digit4, OUTPUT);
//  pinMode(13, OUTPUT);
// Serial.begin(9600);
 //Serial.println("test for niq_ro");
 pinMode(SW0, INPUT);  // for this use a slide switch
  pinMode(SW1, INPUT);  // N.O. push button switch
  pinMode(SW2, INPUT);  // N.O. push button switch
  digitalWrite(SW0, HIGH); // pull-ups on
  digitalWrite(SW1, HIGH);
  digitalWrite(SW2, HIGH);
  DateTime now = RTC.now();
  int timp = now.hour()*100+now.minute();
//   int timp = (now.minute(), DEC);
//   displayNumber(12); // this is number to diplay
//   int timp = 1234;
// Serial.print(now.hour(), DEC);
 // Serial.print(":");
 // Serial.print(now.minute(), DEC);
 // Serial.print(" -> ");
 // Serial.print(timp);
 // Serial.println(" !");
// display parts
   for(int i = 250 ; i >0  ; i--) {
     if (timp >= 1000) displayNumber01(timp);
     else displayNumber02(timp);
     if (timp >= 1000) displayNumber03(timp);
     else displayNumber04(timp);
  if (!(digitalRead(SW0))) set_time(); // hold the switch to set time
  //blinking
void set_time()   {
  byte minutes1 = 0;
  byte hours1 = 0;
  byte minutes = 0;
  byte hours = 0;
  while (!digitalRead(SW0))  // set time switch must be released to exit
    minutes1=minutes;
    hours1=hours;
    while (!digitalRead(SW1)) // set minutes
     minutes++;
   // converting hexa in zecimal:
    zh = hours / 16;
    uh = hours - 16 * zh ;
    ore = 10 * zh + uh;
    zm = minutes / 16;
    um = minutes - 16 * zm ;
    miniti = 10 * zm + um;
     for(int i = 20 ; i >0  ; i--) {
     displayNumber01(ore*100+miniti);
      if ((minutes & 0x0f) > 9) minutes = minutes + 6;
      if (minutes > 0x59) minutes = 0;
    //  Serial.print("Minutes = ");
      if (minutes >= 9) Serial.print("0");
    //  Serial.println(minutes, HEX);
    delay(150);
    while (!digitalRead(SW2)) // set hours
     hours++;
    zh = hours / 16;
    ore = 10 * zh + uh;
    zm = minutes / 16;
      if ((hours & 0x0f) > 9) hours =  hours + 6;
      if (hours > 0x23) hours = 0;
  //    Serial.print("Hours = ");
      if (hours <= 9) Serial.print("0");
      Serial.println(hours, HEX);
    delay(150);
    Wire.beginTransmission(0x68); // activate DS1307
    Wire.write(0); // where to begin
    Wire.write(0x00);          //seconds
    Wire.write(minutes);          //minutes
    Wire.write(0x80 | hours);    //hours (24hr time)
    Wire.write(0x06);  // Day 01-07
    Wire.write(0x01);  // Date 0-31
    Wire.write(0x05);  // month 0-12
    Wire.write(0x09);  // Year 00-99
    Wire.write(0x10); // Control 0x10 produces a 1 HZ square wave on pin 7.
    zh = hours / 16;
    ore = 10 * zh + uh;
    zm = minutes / 16;
 //  delay(150);
void displayNumber01(int toDisplay) {
#define DISPLAY_BRIGHTNESS  500
#define DIGIT_ON  HIGH
#define DIGIT_OFF  LOW
  for(int digit = 4 ; digit > 0 ; digit--) {
    //Turn on a digit for a short amount of time
    switch(digit) {
    case 1:
     digitalWrite(digit1, DIGIT_ON);
     digitalWrite(segDP, HIGH);
      break;
   case 2:
      digitalWrite(digit2, DIGIT_ON);
      digitalWrite(segDP, LOW);
      break;
    case 3:
      digitalWrite(digit3, DIGIT_ON);
      break;
    case 4:
      digitalWrite(digit4, DIGIT_ON);
      break;
    lightNumber(toDisplay % 10);
    toDisplay /= 10;
    delayMicroseconds(DISPLAY_BRIGHTNESS);
     //Turn off all segments
    lightNumber(10);
    //Turn off all digits
    digitalWrite(digit1, DIGIT_OFF);
    digitalWrite(digit2, DIGIT_OFF);
    digitalWrite(digit3, DIGIT_OFF);
    digitalWrite(digit4, DIGIT_OFF);
void displayNumber02(int toDisplay) {
    switch(digit) {
    case 1:
     lightNumber(10);
     break;
   case 2:
      break;
    case 3:
      break;
    case 4:
      break;
    toDisplay /= 10;
    lightNumber(10);
void displayNumber03(int toDisplay) {
    switch(digit) {
    case 1:
      break;
   case 2:
      break;
    case 3:
      break;
    case 4:
      break;
    toDisplay /= 10;
    lightNumber(10);
void displayNumber04(int toDisplay) {
    switch(digit) {
    case 1:
     lightNumber(10);
     break;
   case 2:
      break;
    case 3:
      break;
    case 4:
      break;
    toDisplay /= 10;
    lightNumber(10);
//Given a number, turns on those segments
//If number == 10, then turn off number
void lightNumber(int numberToDisplay) {
#define SEGMENT_ON  LOW
#define SEGMENT_OFF HIGH
  switch (numberToDisplay){
  case 0:
    digitalWrite(segA, SEGMENT_ON);
    digitalWrite(segB, SEGMENT_ON);
    digitalWrite(segC, SEGMENT_ON);
    digitalWrite(segD, SEGMENT_ON);
    digitalWrite(segE, SEGMENT_ON);
    digitalWrite(segF, SEGMENT_ON);
    digitalWrite(segG, SEGMENT_OFF);
    break;
  case 1:
    digitalWrite(segA, SEGMENT_OFF);
    digitalWrite(segD, SEGMENT_OFF);
    digitalWrite(segE, SEGMENT_OFF);
    digitalWrite(segF, SEGMENT_OFF);
    break;
  case 2:
    digitalWrite(segC, SEGMENT_OFF);
    digitalWrite(segG, SEGMENT_ON);
    break;
  case 3:
    break;
  case 4:
    break;
  case 5:
    digitalWrite(segB, SEGMENT_OFF);
    break;
  case 6:
    break;
  case 7:
    break;
  case 8:
    break;
  case 9:
    break;
  // all segment are ON
  case 10:
    break;
Credits
1 project • 15 followers
Electronic enthusiast
Comments
Add projectSign up / Login
