Nicholas GlazeArtun Bayer
Published
Baker Old Wing Door 2.0
State-of-the-art door security system. Keep out all unwanted guests!
IntermediateFull instructions provided2 hours343
Things used in this project
Hardware components
Grove Starter Kit for LaunchPad
Seeed Grove Starter Kit for LaunchPad
×1
Rotary potentiometer (generic)
×1
EK-TM4C123GXL TM4C Tiva LaunchPad
Texas Instruments EK-TM4C123GXL TM4C Tiva LaunchPad
×1
Grove - Ultrasonic Ranger
Seeed Grove - Ultrasonic Ranger
×1
Grove - Light Sensor
Seeed Grove - Light Sensor
×1
Seeed Grove - Buzzer
×1
7 Segment LED Display, InfoVue
×1
Energia
Texas Instruments Energia
Story
Read more
Schematics
Flowchart
Proof of concept
In a real-world implementation, the sensor would sit above the door, preferably at an intersection of a wall and the ceiling.
block diagram
Code
door.ino
Arduino
 * Baker Old Wing Door 2.0
 * Created by:  Nicholas Glaze (nkg2)
 *              Artun Bayer    (ab116)
 * ELEC 220
#include "TM1637.h"
#include "Ultrasonic.h"
/* Macro Define */
#define CLK               39          /* 4-Digit Display clock pin */
#define DIO               38          /* 4-Digit Display data pin */
#define ROTARY_ANGLE_P    24          /* pin of rotary angle sensor */
#define BUZZER            40
#define LIGHT_SENSOR      23
#define ULTRASONIC        25
/* Global Variables */
TM1637 tm1637(CLK, DIO);              /* 4-Digit Display object */
int analog_value = 0;                 /* variable to store the value coming from rotary angle sensor */
    /* Initialize 4-Digit Display */
    tm1637.init();
    tm1637.set(BRIGHT_TYPICAL);
    pinMode(BUZZER, OUTPUT);
    update_clock(0);
boolean door_open(){//True if door is open
  return analogRead(ROTARY_ANGLE_P) > 100;
int time_limit(){//Compute time limit with linear function
  return floor(.004082*analogRead(LIGHT_SENSOR)+5.102);
void scream(){//Display "AAAA" on 4-digit display
  for(int i = 0; i < 4; i++){
    tm1637.display(i, 10);
void sound_open_alarm()
{//Play alarm (sick beat)
  scream();
  while(door_open()) drop_beat();
int pitch(int dist){//Calculate pitch based on linear function
  return floor(45*dist+55)/2;
void sound_tamper_alarm(){//Sound alarm based on object distance from ultrasonic sensor
  scream();
  long dist = measure_dist();
  int p;
  while(dist < 3000){
    for(int i = 0; i < 10; i++){
    p = pitch(dist);
    //update_clock(dist);
    digitalWrite(BUZZER, HIGH);
    delayMicroseconds(p);
    digitalWrite(BUZZER, LOW);
  update_clock(0000);
void update_clock(int n){
  //Displays the number n on the 4-digit display
  for(int i = 3; i > -1; i--){
    tm1637.display(i, n % 10);
    n /= 10;
void count_down(int time_limit){//Run countdown on timer, starting from time_limit
  //Counts the timer down from time_limit to 0
  int time_left = time_limit;
  while (time_left >= 0 and door_open()){
    if(measure_dist() < 3000) sound_tamper_alarm();
    update_clock(time_left);
    time_left -= 1;
  if(door_open()){
    sound_open_alarm();
  update_clock(0);
/* the loop() method runs over and over again */
    if(door_open()){
      count_down(time_limit());
    if(measure_dist() < 3000){
void drop_beat(){//Play a sick beat
  int length = 16;         /* the number of notes */
  char notes[] = "121 12123 3 4546"; //notes in the song
  float beats[] = { 1, 1, 1,    1,    1, 1, 1, 1, 0.6,       1 ,    0.6,      1,        1, 1, 1, 1}; //length of each note
  int tempo = 150;
  /* the setup() method runs once, when the sketch starts */
    int i = 0;
      //Loop through each note
    while(i < length && door_open())
      //space indicates a pause
      if(notes[i] == ' ')
        delay(beats[i] * tempo);
      else
        playNote(notes[i], beats[i] * tempo);
      delay(tempo / 2);    /* delay between notes */
      i++;
  /* play tone */
  void playTone(int tone, int duration)
    for (long i = 0; i < duration * 1000L; i += tone * 2)
      delayMicroseconds(tone);
  char names[] = { '2', '1', '6', '5', '4', '3',};
  float tones[] = { 587/2, 698/2, 880/2, 554/2, 659/2, 440/2};
  void playNote(char note, int duration)
    // play the tone corresponding to the note name
    for (int i = 0; i < 6; i++)
      if (names[i] == note)
        playTone(tones[i], duration);
long measure_dist(){//Measure object distance from ultrasonic sensor
  pinMode(ULTRASONIC, OUTPUT);
  digitalWrite(ULTRASONIC, LOW);
  delayMicroseconds(2);
  digitalWrite(ULTRASONIC, HIGH);
  digitalWrite(ULTRASONIC,LOW);
  pinMode(ULTRASONIC,INPUT);
  long duration;
  duration = pulseIn(ULTRASONIC,HIGH);
  long RangeIndist;
  RangeIndist = duration;
  return RangeIndist;
Credits
Nicholas Glaze
Nicholas Glaze
2 projects • 1 follower
Artun Bayer
Artun Bayer
1 project • 0 followers
Comments
Add projectSign up / Login
