陳亮Royry1031
Published © MIT
Pill Machine
Smart way to take medicine without worry schedule, miss medicines or wrong pills
AdvancedFull instructions providedOver 3 days1,355
Pill Machine
Things used in this project
Hardware components
LinkIt Smart 7688 Duo
MediaTek Labs LinkIt Smart 7688 Duo
×1
SG90 Micro-servo motor
×2
2.4 inch USART HMI serial LCD display
×1
JQ8400 MP3 voice module
×1
3W 1.5 inches speaker
×1
Pen holder
2nd item
×1
0.4 mm thick*3mm torsion spring
16th item (50 per pack)
×8
M1*6mm screw
4th item, it is very easily broke, you should order more than 18
×18
m3*5mm screw
13th item (10 per pack)
×2
m3*8mm screw
14th item (10 per pack)
×4
Evian 500ml bottle
For pill container, you should buy one at the store near you :P
×1
2*10mm axle
1st row 1st item (20 per pack)
×8
Arduino IDE
Arduino IDE
USART HMI
for display module deployment
3D Printer (generic)
Story
Read more
Custom parts and enclosures
Pill container cover
A simple decoration for the pill container
Wheel
Pill container wheel frame
Ejector 7mm
Pill ejector for 7mm x 7mm x 12mm pill
Ejector 8.5mm
Pill ejector for 8.5mm x 8.5mm x 5mm pill
Ejector 10mm
Pill ejector for 10mm x 10mm x 5mm pill
Plug
Plug on the spinner servo, for plug on the pill container
Gear
Pill ejector gear on the ejector servo
Internal base
Core internal base frame
Internal base support
Support between PCB and internal base part
PCB support
Support between the pen holder and PCB
Slide
Pill slide, guide the pill slide out after eject
LCD support
Support between LCD frame and slide
LCD frame
Frame for the LCD module
Schematics
USART HMI design file
Pill Slot Cutout
Print it with a transparency and cut it out.
Pill Machine main circuit board
Test it with bread board first before soldering work.
Code
PillMachino.ino
Arduino
IoT Pill Machine core program
#include <Servo.h>
#include <SoftwareSerial.h>
#include <Process.h>
#define VOICE_MODULE
#define DEMO_ONLY
//#define VIDEO_TAKING_ONLY
#define SPINNER_PIN 5
#define EJECTOR_PIN 6
#define DISPLAY_RX 8
#define DISPLAY_TX 9
#ifdef VOICE_MODULE
#define VOICE_RX 10
#define VOICE_TX 11
#endif
#define EJECT_ANGLE 35
#define REST_ANGLE 180
#define USER_INFO_URL "http://YOUR_IP:YOUR_PORT/user_info"
#define NEXT_SCHEDULE_URL "http://YOUR_IP:YOUR_PORT/next_schedule"
#define TAKEN_URL "http://YOUR_IP:YOUR_PORT/taken"
Servo spinner_servo;
Servo ejector_servo;
SoftwareSerial display_serial(DISPLAY_RX, DISPLAY_TX);
#ifdef VOICE_MODULE
SoftwareSerial voice_serial(VOICE_RX, VOICE_TX);
#endif
int pill_slot_angle[] = {15, 60, 105, 150};
byte buf_page_cmd[] = {'p', 'a', 'g', 'e', ' ', '0', 0xFF, 0xFF, 0xFF};
byte buf_set_str_cmd[] = {'s', 'c', 'h', 'e', '_', 's', 't', 'r', '.', 't', 'x', 't', '=', '"', '0', '0', ':', '0', '0', '"', 0xFF, 0xFF, 0xFF};
#ifdef VOICE_MODULE
// voice volume 1-30
//byte buf_voice_vol[] = {0xAA, 0x13, 0x01, 0x0F, 0xCD}; // command to set volume 15
//byte buf_voice_vol[] = {0xAA, 0x13, 0x01, 0x14, 0xD2}; // command to set volume 20
byte buf_voice_vol[] = {0xAA, 0x13, 0x01, 0x19, 0xD7}; // command to set volume 25
//byte buf_voice_vol[] = {0xAA, 0x13, 0x01, 0x1E, 0xDC}; // command to set volume 30
byte buf_play[4][6] = {
  {0xAA, 0x07, 0x02, 0x00, 0x01, 0xB4}, // command to play 01.mp3
  {0xAA, 0x07, 0x02, 0x00, 0x02, 0xB5}, // command to play 02.mp3
  {0xAA, 0x07, 0x02, 0x00, 0x03, 0xB6}, // command to play 03.mp3
  {0xAA, 0x07, 0x02, 0x00, 0x04, 0xB7}  // command to play 04.mp3
#endif
// function declaration
void ui_page(byte page);
void wait_next_schedule();
void eject_pill(byte pill_slot);
void get_user_info();
void get_next_schedule();
void push_taken();
int cur_step = 0;
int delay_time = 0;
  // Initialize Serial For Debug Output
  Serial.begin(9600);
  // Initialize Pill Ejection Module
  spinner_servo.attach(SPINNER_PIN);
  spinner_servo.write(0);
  ejector_servo.attach(EJECTOR_PIN);
  ejector_servo.write(REST_ANGLE);
  // Initialize Display Module
  display_serial.begin(9600);
#ifdef VOICE_MODULE
  // Initialize Voice Module
  voice_serial.begin(9600);
  voice_serial.write(buf_voice_vol, 5);
#endif
  // display loading screen
  ui_page(0);
  // Initialize Bridge
  Bridge.begin();
  // display splash screen
  ui_page(1);
// the loop routine runs over and over again forever:
  display_serial.listen();
  while (display_serial.available() > 0) {
    char in_char = display_serial.read();
    Serial.write(in_char);
    switch (in_char) { // check signal from which screen
      case '1':
        // display user info screen
        ui_page(2);
        break;
      case '2':
        // display next schedule screen
        ui_page(3);
        break;
#ifdef VIDEO_TAKING_ONLY
      case '3': // should be triggered by timer
        break;
#endif
      case '4':
        if (cur_step == 0) {
          eject_pill(0);
          eject_pill(1);
          eject_pill(2);
          ui_page(5);
        } else if (cur_step == 1) {
          eject_pill(0);
          eject_pill(2);
          ui_page(6);
        } else {
          eject_pill(1);
          ui_page(7);
        break;
      case '5':
        push_taken();
        cur_step = 1;
        ui_page(3);
        break;
      case '6':
        push_taken();
        cur_step = 2;
        ui_page(3);
        break;
      case '7':
        push_taken();
        cur_step = 0;
        ui_page(3);
        break;
      default:
        break;
      char c = display_serial.read();
void ui_page(byte page) {
  switch (page) {
    case 0:
      buf_page_cmd[5] = '0';
      display_serial.write(buf_page_cmd, sizeof(buf_page_cmd));
      break;
    case 1:
      buf_page_cmd[5] = '1';
      break;
    case 2:
      buf_page_cmd[5] = '2';
      //TODO: get and display user info from cloud server
      //get_user_info();
#ifdef VOICE_MODULE
      voice_serial.write(buf_play[0], 6);
#endif
      break;
    case 3:
      buf_page_cmd[5] = '3';
      buf_set_str_cmd[0] = 's';
      buf_set_str_cmd[1] = 'c';
      buf_set_str_cmd[2] = 'h';
#ifdef DEMO_ONLY
        buf_set_str_cmd[14] = '1';
        buf_set_str_cmd[15] = '4';
        display_serial.write(buf_set_str_cmd, sizeof(buf_set_str_cmd));
        buf_set_str_cmd[14] = '2';
        buf_set_str_cmd[15] = '0';
      } else {
        buf_set_str_cmd[14] = '0';
        buf_set_str_cmd[15] = '8';
#else
      //TODO: get and display time from cloud schedule
      //get_next_schedule();
      //buf_set_str_cmd[14] =
      //buf_set_str_cmd[15] =
      //buf_set_str_cmd[17] =
      //buf_set_str_cmd[18] =
      //display_serial.write(buf_set_str_cmd, sizeof(buf_set_str_cmd));
#endif
#ifdef VOICE_MODULE
      voice_serial.write(buf_play[1], 6);
#endif
      // do nothing
#else
#endif
      break;
    case 4:
      buf_page_cmd[5] = '4';
      buf_set_str_cmd[0] = 't';
      buf_set_str_cmd[1] = 'i';
      buf_set_str_cmd[2] = 'm';
#ifdef DEMO_ONLY
      } else {
#else
      //TODO: display time from cloud schedule
#endif
#ifdef VOICE_MODULE
      voice_serial.write(buf_play[2], 6);
#endif
      break;
    case 5:
      buf_page_cmd[5] = '5';
#ifdef VOICE_MODULE
      voice_serial.write(buf_play[3], 6);
#endif
      break;
    case 6:
      buf_page_cmd[5] = '6';
#ifdef VOICE_MODULE
#endif
      break;
    case 7:
      buf_page_cmd[5] = '7';
#ifdef VOICE_MODULE
#endif
      break;
    default:
      break;
void wait_next_schedule() {
  //TODO: use timer
#ifdef DEMO_ONLY
  Serial.println("wait 10 seconds");
  delay(10000);
#else
  Serial.print("wait ");
  Serial.print(delay_time);
  Serial.println(" milliseconds");
  delay(delay_time);
#endif
  ui_page(4);
void eject_pill(byte pill_slot) {
  spinner_servo.write(pill_slot_angle[pill_slot]);
  ejector_servo.write(EJECT_ANGLE);
void get_user_info() {
  // Launch "curl" command and get Arduino ascii art logo from the network
  // curl is command line program for transferring data using different internet protocols
  Process p;        // Create a process and call it "p"
  p.begin("curl");  // Process that launch the "curl" command
  // Add the URL parameter to "curl"
  p.addParameter("--data");
  p.addParameter("id=pill_machine");
  p.addParameter(USER_INFO_URL);
  p.run();      // Run the process and wait for its termination
  // A process output can be read with the stream methods
  while (p.available()>0) {
    char c = p.read();
    Serial.print(c);
    //TODO: save user info to variable
  // Ensure the last bit of data is sent.
  Serial.flush();
void get_next_schedule() {
  p.addParameter(NEXT_SCHEDULE_URL);
    char c = p.read();
    Serial.print(c);
    //TODO: save next schedule to variable
    //delay_time =
  Serial.flush();
void push_taken() {
  p.addParameter(TAKEN_URL);
    char c = p.read();
    Serial.print(c);
  Serial.flush();
IoT Pill Machine Mobile App
Credits
陳亮
陳亮
1 project • 1 follower
Roy
Roy
ry1031
ry1031
Comments
Add projectSign up / Login
