Moheeb ZaraPrentice BjerkesethJustin Lassen
Published © MIT
BluSpike - Community Driven BLE Sensor Network
Easy to build w/ off the shelf parts, BLE solar powered sensor array. Connect and share its data to the cloud and be rewarded with ethereum
EasyFull instructions provided1 hour1,470
Things used in this project
Hardware components
Solar Yard Lamp
×1
PVC Pipe 2ft x 1.25 in
×2
Arduino 101 & Genuino 101
×1
Grove starter kit plus for Intel Edison
Seeed Grove starter kit plus for Intel Edison
×1
Metal Round Box for Wiring
×1
PVC Couple with Thread
×1
Threaded bolt for PVC coupler
×1
Friction Tape
×1
9V to Barrel Jack Connector
×1
Story
Read more
Custom parts and enclosures
Sensor Carriage
Brackets
Code
sensorRead
Arduino
#include <CurieBLE.h>
BLEPeripheral blePeripheral;
BLEService customService("19B10000-E8F2-537E-4F6C-D104768A1216");
BLEUnsignedCharCharacteristic tempCharacteristic("5667f3b1-d6a2-4fb2-a917-4bee580a9c84", BLERead | BLENotify);
BLEUnsignedCharCharacteristic dustCharacteristic("5667f3b1-d6a2-4fb2-a917-4bee580a9c85", BLERead | BLENotify);
BLEUnsignedCharCharacteristic humidityCharacteristic("5667f3b1-d6a2-4fb2-a917-4bee580a9c86", BLERead | BLENotify);
BLEUnsignedCharCharacteristic carbonCharacteristic("5667f3b1-d6a2-4fb2-a917-4bee580a9c87", BLERead | BLENotify);
const int B = 4275;               // B value of the thermistor
const int R0 = 100000;            // R0 = 100k
  Serial.begin(9600);
  blePeripheral.setLocalName("Curie");
  blePeripheral.setAdvertisedServiceUuid(customService.uuid());
  blePeripheral.addAttribute(customService);
  blePeripheral.addAttribute(tempCharacteristic);
  blePeripheral.addAttribute(dustCharacteristic);
  blePeripheral.addAttribute(humidityCharacteristic);
  blePeripheral.addAttribute(carbonCharacteristic);
  tempCharacteristic.setValue(0);
  dustCharacteristic.setValue(0);
  humidityCharacteristic.setValue(0);
  carbonCharacteristic.setValue(0);
  blePeripheral.begin();
  BLECentral central = blePeripheral.central();
  if (central) {
    Serial.print("Connected to central: ");
    Serial.println(central.address());
    while (central.connected()) {
      int dust = analogRead(1);
      int humidity = analogRead(2);
      int carbon = analogRead(3);
      int a = analogRead(0);
      float R = 1023.0/a-1.0;
      R = R0*R;
      float temperature = 1.0/(log(R/R0)/B+1/298.15)-273.15;
      tempCharacteristic.setValue(temperature);
      dustCharacteristic.setValue(dust);
      humidityCharacteristic.setValue(humidity);
      carbonCharacteristic.setValue(carbon);
Github
Credits
Moheeb Zara
Moheeb Zara
28 projects • 105 followers
Software Evangelist at Hologram.io - . Co-founder - South West Maker Festival. Hardware hacker, artist, robotics mentor, HeatSync Labs
Prentice Bjerkeseth
Prentice Bjerkeseth
0 projects • 2 followers
Web and Design Generalist
Justin Lassen
Justin Lassen
0 projects • 0 followers
Award winning VR developer, Intel Innovator
Comments
Add projectSign up / Login
